/!\ [TOPIC UNIK] ACTIVE COOL AC4G ventilo+peltier /!\
/!\ [TOPIC UNIK] ACTIVE COOL AC4G ventilo+peltier /!\ - Water & Xtreme Cooling - Overclocking, Cooling & Modding
Marsh Posté le 07-12-2002 à 00:42:40
ce couple ventirad+peltier, alimenté par une carte pci, fabriqué par la sociiété Active Cool va etre distribué par thermaltake entre autre
http://membres.lycos.fr/hooligames/ac4g.GIF
j'avais envoyé un mail en demandant komen sa marchai, les temperatures etc ya un bout de temps et je n'attendais plus de reponses et la j'ouvre ma boite et kes ke je vois ... ?
Dear Mad Cow,
Thank you for your interest in Active Cool cooling systems. You are
correct that it is includes a Peltier element powered by a
high-efficiency power converter on a PCI card. I am attaching a
description of how it works and specifications with test results.
Preliminary results with P4 3.06 GHz are as follows:
Test was run using ThermalTake XaserII case (this is a large case with
good air flow).
CPU BurnIn was run continuously to stress processor (we used to run
SiSoft Sandra, but CPU BurnIn provides considerably more heat
stress--and appears to accurately reflect the most processor-intensive
applications in the marketplace).
Maximum CPU temperature (Intel Monitor--thermal diode inside the CPU):
44°C
Maximum system temperature: 40.5°C
We are very pleased with these results. This definitely appears to
eliminate all overheating or activating Tcc. In the near future, I will
try to convince the laboratory to run the test on a smaller case with a
duct fan and sleeve (modders can easily make these at home). I expect
the results to be similar.
I hope this helps.
Yisrael van Handel, director of marketing
Active Cool Ltd.
tel: +972 (8) 6781771
voila
alors pour un p4 3.06 je sais pas trop si les temp sont si bonnes ke ça ... ils parlaient de 26° dans les 1eres infos ... sa devait etre sur un dudu600 ...
je vous met aussi les pieces jointes ke jai recues avec
http://membres.lycos.fr/hooligames/AC4GDataSheet.pdf
http://membres.lycos.fr/hooligames [...] ochure.pdf
http://membres.lycos.fr/hooligames [...] nNoise.doc
si sa vous laisse aussi perplexe ke moi vous pouvez reagir
et kom on dit ... WAIT AND SEE  :jap:
Message édité par Mad Cow le 07-12-2002 à 00:56:44
Marsh Posté le 07-12-2002 à 13:25:40
sa interessai pas mal de personnes la derniere fois ...  :heink:
Marsh Posté le 07-12-2002 à 16:09:24
c koi les specs? peltier, alim ?
Marsh Posté le 07-12-2002 à 17:18:45
tout est dans les pieces jointes  :)
Marsh Posté le 07-12-2002 à 17:26:43
ça a l'air pas mal mais pour les $$$$ ??
Sinon la carte PCI, c'est juste pour alimenter ?
Marsh Posté le 07-12-2002 à 17:31:11
elle sert aussi a brancher d'autre ventilos sur la carte mere
Marsh Posté le 07-12-2002 à 17:32:20
Ok mais Combien de $ ?
Marsh Posté le 07-12-2002 à 17:34:02
je crois kil vont sortir aux alentours de 120? ...  :pfff:  :fou:
Marsh Posté le 07-12-2002 à 17:38:26
120 euro  :pt1cable:
Si c'est vraiment efficace je m'en acheterai peut-etre un pour mon futur K8.
Mais va falloir que j'economise  :pfff:
PS: va falloir que je vois aussi si j'aurai assez d'emplacement pci parce que la geforce FX utilise aussi un port PCI pour l'evacuation de l'air non ?
Marsh Posté le 07-12-2002 à 17:46:32
oué c vrai
entre la gfFX et l'ac4g le porte monaie va souffrir  :sweat:
Marsh Posté le 07-12-2002 à 19:25:47
j'ai vu que la carte servai ossi a gerer la puissance du peltier pr éviter la condensation garce a un proc intégrés et des sondes. enfin bon avec un p4 3.06 je pense pas que la condensation soit possible ^^
La raison est la mesure de toutes choses!   Venez découvrir de la peinture pointilliste
Marsh Posté le 07-12-2002 à 21:33:43
oui ya un proco d'installé et tout mais alors pk es ce kils obtiennent des temps pareils !?!
parce ke bon c limite élevé kan meme ...  :heink:
Marsh Posté le 08-12-2002 à 00:36:56
 :non:
c'est plutot plus de 200 aux premiere information :cry:
Marsh Posté le 08-12-2002 à 00:51:45
:cry:  c encore pireeeeeeeeuuuuhhhhhhhhhh  :cry:
