A moins d'un miracle: Xerox à virer! --> Maj: Miracle il y a: vive XP! - Hardware
Marsh Posté le 05-08-2002 à 19:49:22
Je sens que je vais au gros bide
Marsh Posté le 05-08-2002 à 19:52:25
euh au taff j'ai du xerox (impriamnte n2125 * 3 + N17 *3 copieur DC432ST Pro + DCCS50)
et bien leurs drivers quels que soit l'os (NT, win2k, 98, 95, MacOS) sont merdiques
remarque j'ai po testé linux
alors si tu peux
vires le xerox !!!!
Marsh Posté le 05-08-2002 à 19:57:05
| fute77 a écrit a écrit : euh au taff j'ai du xerox (impriamnte n2125 * 3 + N17 *3 copieur DC432ST Pro + DCCS50) et bien leurs drivers quels que soit l'os (NT, win2k, 98, 95, MacOS) sont merdiques remarque j'ai po testé linux alors si tu peux vires le xerox !!!! |
En tout cas je tiens à mon XP.
Merci.
Marsh Posté le 06-08-2002 à 17:33:20
Dernier espoir: mail à la maison mère; hier soir je sors mon Harraps.
Et, il y a une heure:
Thank you for your information.
In response to your note, due to the age of the Docuprint XJ8c and Xj9c, Xerox will most likely not produce a fully functional driver for that
particular operating system. However, with PCL3+ emulation compliance, you can use a secondary driver in place of our software that will allow you to
print both Black & white and/or color documents.
The Lexmark 5700 driver is the only emulation driver available at this
time. You will need to add this driver through your "add printer wizard" utilities. You do not need to download the driver. Close all background
programs or applications.
Go to Start -> Settings -> and Printers. Once you have gained access to the printers folder double left click on the Add Printer icon. You need to
follow the onscreen instructions until you come to Manufacturers and printers. On this screen please select Lexmark as the manufacturer and "5700" as
the printer and click next. You will need to set the printer as the default machine (if prompted) and proceed with the installation. If you receive
an error message that a disk is needed you need to load the Windows XP system CD-ROM and click next to complete the installation.
Thank you for using Xerox e-mail support services.
Retail Products Supplies & Support,
TEAMXRX@usa.xerox.com
Bon, j'ai testé, ça a l'air de marcher!
Et l'info n'est sur aucun site Xerox:
Exclu HFR!
Marsh Posté le 06-08-2002 à 17:38:17
mouai
ca fait tou zarb d'utiliser des drivers lexmark pour sdu xerox
enfin ca confirme de que j'ai constaté
donc en 2003 je vire les Xerox !
Marsh Posté le 07-08-2002 à 00:10:21
Voilà un gars qui a du mordant!
Faut virer aussi Lexmark
Bon, tout est bien qui finit bien!
Marsh Posté le 05-08-2002 à 19:47:59
Salut à tous.
Bon , voilà, je viens de tomber sur mon premier matos incompatible avec XP.
Une imprimante Xerox Docuprint XJ8C.
Bien entendu j'ai contacté Xerox (driver pas développé!).
Surfé tous leurs sites.
Essayé les drivers de W95, 98, 2000, NT.
Fait fonctionner l'assistant de compatibilité.
Par miracle, avant que je ne jette l'éponge, personne n'aurait réussi à faire marcher cette cochonne sous XP?
J'aime pas jeter l'éponge sans être sûr que...
Merci.
Message édité par x9bman le 06-08-2002 à 17:31:06
Non mais t'as rien de mieux à faire que de traîner encore sur ce forum?
