mais avant de démonter j'aimerais savoir si le message d'erreur de nero vous dis quelques choses
mobile
1A23-0056-3030-1539-1734-2508
Windows 2000 5.0 IA32 WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0001), size=45056 bytes, created 14/08/2002 15:03:36 ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 17/06/2003 14:25:04 Nero version: 6.0.0.23 Recorder: <YAMAHA CRW-F1E> Version: 1.0g - HA 1 TA 0 - 6.0.0.23 Adapter driver: <atapi> HA 1 Drive buffer : 8192kB Bus Type : default (0) -> ATAPI, detected: ATAPI CD-ROM: <HITACHI DVD-ROM GD-2500 >Version: A011 - HA 1 TA 1 - 6.0.0.23 Adapter driver: <atapi> HA 1
=== Scsi-Device-Map === DiskPeripheral : ST3120023A atapi Port 0 ID 0 DMA: On DiskPeripheral : HDS722512VLAT80 atapi Port 0 ID 1 DMA: On CdRomPeripheral : YAMAHA CRW-F1E atapi Port 1 ID 0 DMA: On CdRomPeripheral : HITACHI DVD-ROM GD-2500 atapi Port 1 ID 1 DMA: On
19:59:58 #3 Text 0 File Reader.cpp, Line 118 Reader running
19:59:58 #4 Text 0 File Writer.cpp, Line 124 Writer YAMAHA CRW-F1E running
19:59:58 #5 ISO9660GEN -11 File geniso.cpp, Line 3882 First writeable address = 0 (0x00000000)
19:59:58 #6 Text 0 File Burncd.cpp, Line 3218 Turn on Track-at-once, using CD-R/RW media
19:59:58 #7 Text 0 File DlgWaitCD.cpp, Line 233 Last possible write address on media: 336074 (74:42.74) Last address to be written: 2106 ( 0:30.06)
19:59:58 #8 Text 0 File DlgWaitCD.cpp, Line 238 Write in overburning mode: FALSE
19:59:58 #9 Text 0 File DlgWaitCD.cpp, Line 1997 Recorder: YAMAHA CRW-F1E; CDR code: 00 97 34 21; OSJ entry from: Mitsubishi Chemical ATIP Data: Special Info [hex] 1: C0 00 98, 2: 61 22 15 (LI 97:34.21), 3: 4A 2B 00 (LO 74:43.00) Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
19:59:58 #10 Text 0 File DlgWaitCD.cpp, Line 398 >>> Protocol of DlgWaitCD activities: <<< =========================================
19:59:58 #11 Text 0 File ThreadedTransferInterface.cpp, Line 773 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 (CTransferItem) 2 indices, index0 (150) not provided original disc pos #0 + 2107 (2107) = #2107/0:28.7 relocatable, disc pos for caching/writing not required/required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2105 blocks [YAMAHA CRW-F1E ] --------------------------------------------------------------
19:59:58 #12 Text 0 File ThreadedTransferInterface.cpp, Line 942 Prepare recorder [YAMAHA CRW-F1E ] for write in TAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc not fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 4622336, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_ -150 | lead-in | 0 | 0x00 | 0x41 -150 | 1 | 0 | 0x00 | 0x41 0 | 1 | 1 | 0x00 | 0x41 2107 | lead-out | 1 | 0x00 | 0x41
19:59:58 #13 Text 0 File ThreadedTransferInterface.cpp, Line 969 Removed 2 run-out blocks from end of track 1.
19:59:58 #14 Phase 24 File dlgbrnst.cpp, Line 1803 Caching of files started
19:59:58 #15 Phase 25 File dlgbrnst.cpp, Line 1803 Caching of files completed
19:59:58 #16 Phase 36 File dlgbrnst.cpp, Line 1803 Burn process started at 8x (1 200 KB/s)
19:59:58 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2146 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
19:59:58 #18 Text 0 File Mmc.cpp, Line 19359 Set BUFE: supported -> ON , Optimum Writespeed Control : ON
20:00:09 #19 SCSI -1106 File Cdrdrv.cpp, Line 1427 SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x0CE60000 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x73 Sense Qual: 0x03 CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00 Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A 0x00 0x00 0x00 0x00 0x73 0x03
20:00:09 #20 CDR -1106 File Writer.cpp, Line 301 Power calibration error
20:00:09 #21 Text 0 File ThreadedTransfer.cpp, Line 229 all writers idle, stopping conversion
20:00:09 #22 CDR -201 File WriterStatus.cpp, Line 193 Invalid write state YAMAHA CRW-F1E\H1 T0
20:00:09 #23 TRANSFER -18 File WriterStatus.cpp, Line 193 Could not perform EndTrack
20:00:09 #24 Text 0 File Mmc.cpp, Line 14342 <YAMAHA CRW-F1E > start Close Session
20:00:09 #25 SCSI -1026 File Cdrdrv.cpp, Line 1167 SCSI Exec, HA 1, TA 0, LUN 0 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x2C Sense Qual: 0x04 CDB Data: 0x5B 0x01 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A 0x00 0x00 0x00 0x00 0x2C 0x04
20:00:09 #26 CDR -1026 File WriterStatus.cpp, Line 232 Current program area empty
20:00:09 #27 TRANSFER -19 File WriterStatus.cpp, Line 232 Could not perform Fixation
20:00:09 #28 Text 0 File WriterStatus.cpp, Line 241 falling back to disc fixation
20:00:09 #29 Text 0 File dlgbrnst.cpp, Line 1661 Set remaining time: 0:00,000 (0ms) -> OK
20:00:09 #30 Phase 38 File dlgbrnst.cpp, Line 1803 Burn process failed at 8x (1 200 KB/s)
Existing drivers: File 'Drivers\ASPI32.SYS': Ver=4.71 (0001), size=17005 bytes, created 14/08/2002 15:03:36 File 'Drivers\PXHELP20.SYS': Ver=2.03.28a, size=20640 bytes, created 12/03/2005 00:28:14 (Prassi/Veritas driver for win 2K) File 'Drivers\atapi.sys': Ver=5.00.2195.6699, size=86672 bytes, created 19/06/2003 12:05:04 (Adapter driver for rec)
Marsh Posté le 15-08-2006 à 20:19:57
bonjour tout le monde,
depuis quelques temps je n'arrive plus à graver avec mon beau graveur cd yamaha F1 ...
c'etait un graveur que la sav m'avait renvoyé mais je crois maintenant la garantie de 2 ans est largement dépassé ....
apparrement je ne suis pas le seul à avoir ce souci. Comme lemime a eu le meme pb et on lui a conseillé de démonter le graveur
http://forum.hardware.fr/hardwaref [...] 8870-1.htm
mobile
Windows 2000 5.0
IA32
=== CDRom-Device-Map ===
YAMAHA CRW-F1E I: CDRom0
HITACHI DVD-ROM GD-2500 L: CDRom1
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523764kB)
Free physical memory: 174MB (178360kB)
Memory in use : 65 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
15.8.2006
CD-ROM (ISO)
19:59:58 #1 Text 0 File Isodoc.cpp, Line 6013
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : FALSE
Burning mode : TAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
19:59:58 #2 Phase 90 File dlgbrnst.cpp, Line 1803
Buffer Underrun Protection activated
Reader running
ATIP Data:
DAO infos:
MCN: ""
Tracks 1 to 1:
DAO layout:
Sense Code: 0x73
Sense Qual: 0x03
Invalid write state
Sense Code: 0x2C
Sense Qual: 0x04
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
