Abit NV7-133R <-- compatibilité --> CPU Barton 2500+ [MOBO] - Carte mère - Hardware
Marsh Posté le 11-06-2003 à 19:00:30
ben je crois deja que ton fsb max est de 133 donc le barton passe pas
Marsh Posté le 11-06-2003 à 22:52:35
Ispider a écrit : ben je crois deja que ton fsb max est de 133 donc le barton passe pas |
non il est à 266.
Voici toutes les spécificités de cette carte :
Specifications:
CPU
Supports AMD-K7 Athlon /Athlon XP Socket A 200/266MHz FSB Processors
Supports AMD-K7 Duron Socket A 200/266MHz FSB Processors
Chipset
nVIDIA chipset (nForce 415 & MCP-D)
Integrated 128-bit memory controller (Dual independent 64-bit memory controllers)
4.2GB/sTotal Maximum Memory Bandwidth
Supports Advanced Configuration and Power Management Interface (ACPI)
Supports AGP 4X, 1.5V only
Memory
Three 184-pin DIMM sockets support DDR SDRAM modules
Supports up to 1.5 GB MAX (64, 128, 256, 512MB DDR SDRAM)
Supports unbuffered Non-ECC type DDR DIMMs
Audio
nVIDIA MCP-D built in Audio Processing Unit w/ 256 total voices
Supports AC3 encoding
Realtek ALC650 (AC-Link)
Supports 6CH DAC for AC3 5.1 CH output
Professional digital audio interface supporting 24-bit SPDIF OUT
BIOS
SoftMenuTM II Technology to set CPU parameters
Award Plug and Play BIOS
Supports Advanced Configuration Power Interface (ACPI)
Supports Desktop Management Interface (DMI)
Multi I/O
2 Channels Bus Master IDE Ports supporting up to four Ultra DMA 33/66/100
2 Channels Bus Master IDE Ports supporting up to four Ultra DMA 33/66/100/133 (RAID 0/1/1+0)
PS/2 Keyboard and PS/2 Mouse Connectors
1 Floppy Port (up to 2.88MB)
1 Parallel Port (EPP/ECP)
2 Serial Ports
2 USB Connectors
On board USB header for two extra USB channels
10/100Mb LAN port connector
Audio connector (Line-in, Line-out, Mic-in, and Game Port)
On board VIA VT6202 USB 2.0 header for four extra USB 2.0 channels
Marsh Posté le 11-06-2003 à 22:56:29
Citation : ben je crois deja que ton fsb max est de 133 donc le barton passe pas |
Tomilou a écrit : |
Marsh Posté le 11-06-2003 à 23:05:32
Neo_XP a écrit :
C une gaffe ou kwa ?
Marsh Posté le 11-06-2003 à 23:10:44
Tomilou a écrit : |
vi
fsb 133 (=) 266
fsb 166 (=) 333
fsb 200 (=) 400
c'est a cause du markéting DDR ca
Donc ta mobo ne supporte pas les fsb supérieur a 133 (ou 266 si tu préfères ) donc les barton avec un fsb a 166 (ou 333 ) ne passeront pas de + avec ses 512ko de cache L2, la mobo doit pas supporté
Marsh Posté le 11-06-2003 à 23:14:01
Neo_XP a écrit : vi |
Ah bon ... eh bien merci pour les infos ... finalement c'est uen question de gros bleu
De toute manière bye bye la promo, ma MOBO supportera pas snif snif
Marsh Posté le 11-06-2003 à 23:15:42
vi vi cai une kestion de noob mais bon spagrave
ben kler ke la promo était bien, mais bon tu peus pas essaye de voir pour un 2400+
Marsh Posté le 12-06-2003 à 11:24:31
Au passage voici le topic officiel de la NV7-133R sur le forum -> http://forum.hardware.fr/forum2.ph [...] h=&subcat=
Officiellement la NV7-133R supporte au maximum l'AthlonXP Thoroughbred 2600+ en fsb 266 modèle très rare semble t-il (réglé en 16 x 133 et cadencé à 2133Mhz) et que je recherche actuellement par rapport au modèle fsb 333 (réglé en 12,5 x 166 et cadencé à 2083Mhz), cf cette page d'Abit -> http://www.abit.fr/faqs.php?action=view&id=7
Le Barton 2500+ tourne par défaut à seulement 1833 Mhz et est réglé par défaut en 11 x 166 (au passage devrait sortir sous peu le modèle Barton 2600+ ), outre le petit problème du fsb à 166 (néanmoins je pense que l'on pourrait le faire tourner en fsb 133), il faudrait pour que la NV7-133R le supporte qu'elle reconnaisse correctement le core Barton (qui diffère principalement du Thoroughbred par le cache L2 qui passe de 256Ko à 512Ko).
C'est tout à fait possible mais il vaudrait tester pour en être sûr, voir deja si elle veut bien booter avec, et ensuite si le système est stable après, reste à lui affecter un autre coeff X pour le faire tourner à peu près à sa frèquence normale en fsb 133 donc en 14x133 ou plutot 15x133 (les coeffs 14,5 et 15,5 sont exclus de toute façon)
Je dis ça car j'ai eu par le passé l'expèrience de mon Abit KT7A revision 1.1 qui fonctionnait parfaitement avec mon AthlonXP 1800+ Palomino alors qu'il n'y avait de support officiel des AthlonXP qu'avec la révision 1.3 de la MoBo!
Marsh Posté le 11-06-2003 à 14:03:33
Bjour à tous,
Voilà plusieurs mois que j'ai acheté une Abit NV7-133R avec comme CPU un AMD XP 1800+. Jusqu'ici j'en suis très content !
Dans un magasin près de chez moi il font une promo pour un AMD Barton 2500+ à 99?!
J'ai été voir sur le site de Abit, mais je ne trouve pas d'info sur une éventuelle compatibilité avec les Barton 2500 +.
J'ai mis mon BIOS à jour avec la dernière version, mais je n'ai pass trouvé d'info spécifique http://www.abit.com.tw/abitweb/web [...] E=NV7-133R sur les 2500.. est-ce que qqn aurait plus d'info là-dessus ??
Merci d'avance
Tom
EDIT : j'ai trouvé ceci : http://65.68.55.12/inetpub/ftproot [...] t_abit.htm il semble que la NV7-133R ne soit pas compatible avec les barton !!! Est-ce que qqn aurait d'autres infos ????
Message édité par tomilou le 11-06-2003 à 14:05:55
