Ecrans bleus hal.dll
Ecrans bleus hal.dll - Matériels & problèmes divers - Hardware
Marsh Posté le 27-04-2015 à 07:33:17
Depuis un certain temps j'ai pas mal d'écrans bleus qui viennent planter le PC.
Principalement lorsque je suis sur un jeu un peu gourmand, et parfois même lorsque le PC utilise pas mal de mémoire
D’après le rapport whoCrashed ca viendrait d'un probleme de driver hal.dll
Voir rapport :
Spoiler :
Welcome to WhoCrashed (HOME EDITION) v 5.03
This program checks for drivers which have been crashing your computer. If your computer has displayed a blue screen of death, suddenly rebooted or shut down then this program will help you find the root cause and possibly a solution.
Whenever a computer suddenly reboots without displaying any notice or blue screen of death, the first thing that is often thought about is a hardware failure. In reality, on Windows most crashes are caused by malfunctioning device drivers and kernel modules. In case of a kernel error, many computers do not show a blue screen unless they are configured for this. Instead these systems suddenly reboot without any notice.
This program will analyze your crash dumps with the single click of a button. It will tell you what drivers are likely to be responsible for crashing your computer. It will report a conclusion which offers suggestions on how to proceed in any situation while the analysis report will display internet links which will help you further troubleshoot any detected problems.
To obtain technical support visit www.resplendence.com/support
Click here to check if you have the latest version or if an update is available.
Just click the Analyze button for a comprehensible report ...
Home Edition Notice
This version of WhoCrashed is free for use at home only. If you would like to use this software at work or in a commercial environment you should get the professional edition of WhoCrashed which allows you to perform more thorough and detailed analysis. It also offers a range of additional features such as remote analysis on remote directories and remote computers on the network.
Click here for more information on the professional edition.
Click here to buy the the professional edition of WhoCrashed.
System Information (local)
computer name: GAUROX-PC
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
Hardware: All Series, ASUS, ASUSTeK COMPUTER INC., Z87-PRO
CPU: GenuineIntel Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz Intel586, level: 6
8 logical processors, active mask: 255
RAM: 17114509312 total
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Sun 26/04/2015 23:19:19 GMT your computer crashed
crash dump file: C:\Windows\Minidump\042715-18579-01.dmp
This was probably caused by the following module: hal.dll (hal+0x12A3B)
Bugcheck code: 0x124 (0x0, 0xFFFFFA800D4B1028, 0xBF800000, 0x124)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\Windows\system32\hal.dll
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: Hardware Abstraction Layer DLL
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: hal.dll (hal!HalBugCheckSystem+0x1E3)
On Sun 26/04/2015 22:31:58 GMT your computer crashed
crash dump file: C:\Windows\Minidump\042715-19094-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA800D494028, 0xFF800000, 0x124)
Conclusion
3 crash dumps have been found and analyzed. No offending third party drivers have been found. Connsider using WhoCrashed Professional which offers more detailed analysis using symbol resolution. Also configuring your system to produce a full memory dump may help you.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Est-ce que quelqu'un aurait une solution?
Merci d'avance
Voici ma config :
- CPU : i7 4770k
- RAM : 2x8 Go PC Trident X CAS10
- CG : NVIDIA GTX 970 Gaming 4Go
- Alim Antec 520w certifiée 80+ bronze
- SSD System 120Go
Marsh Posté le 27-04-2015 à 07:41:14
Commence par tester tes barettes de ram, une par une pendant au moins 4h par barette.
Ensuite un test OCCT PSU, puis CPU, puis GPU.
3000 tués sur les routes chaque année - c'est décidé, demain je roule sur les trottoirs ©brèves de comptoire
Marsh Posté le 27-04-2015 à 09:45:31
Merci ! Aurais tu des suggestions de logiciels pour faire cela?
J'ai pas trop l'habitude
Marsh Posté le 27-04-2015 à 09:46:35
memtest86 pour la ram
OCCT pour le reste.
