Ecrans bleus - Kernel_Data_Inpage_Error
Ecrans bleus - Kernel_Data_Inpage_Error - Matériels & problèmes divers - Hardware
Marsh Posté le 28-04-2013 à 11:51:40
Depuis quelques jours j'ai des problèmes de plantage et d'écran bleu sur mon PC. Il m'indique le soucis suivant: Kernel_Data_Inpage_Error.
J'ai testé les disques durs: RAS
J'ai testé les barrettes de RAM: RAS
J'aimerai éviter de réinstaller tout le système si possible.
Voici une capture d'écran du rapport Windows:
http://img15.hostingpics.net/pics/159509IMG0080.jpg
J'ai également fait une analyse avec Whocrashed, voici le rapport:
System Information (local)
computer name: MATHIEU
windows version: Windows 8 , 6.2, build: 9200
windows dir: C:\windows
CPU: GenuineIntel Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz Intel586, level: 6
4 logical processors, active mask: 15
RAM: 8538275840 total
VM: 2147352576, free: 1929609216
Crash Dump Analysis
Crash dump directory: C:\windows\Minidump
Crash dumps are enabled on your computer.
On Sun 28/04/2013 09:17:01 GMT your computer crashed
crash dump file: C:\windows\Minidump\042813-8640-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x5A240)
Bugcheck code: 0x7A (0x4, 0x200, 0xFFFFFA8006F24780, 0x40000C)
Error: KERNEL_DATA_INPAGE_ERROR
file path: C:\windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This bug check indicates that the requested page of kernel data from the paging file could not be read into memory.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\windows\memory.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
Conclusion
2 crash dumps have been found and analyzed. No offending third party drivers have been found. Consider configuring your system to produce a full memory dump for better analysis.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is actually responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Merci d'avance pour votre aide.  :)
Mathieu
Marsh Posté le 28-04-2013 à 12:31:28
