Bonjour tout le monde ,j'ai droit a mon premier crash et j'aimerais etre sur du probleme , (entre la carte graphique et la memoire ) mais vos avis m'interessent merciiiiiiiiiiiiiiiiiiiiiiiiiiiii
On Mon 16/04/2012 10:19:25 GMT your computer crashed crash dump file: C:\Windows\Minidump\041612-6536-01.dmp This was probably caused by the following module: dxgmms1.sys (dxgmms1+0x1D6BC) Bugcheck code: 0x1000008E (0xFFFFFFFFC0000005, 0xFFFFFFFF958EE6BC, 0xFFFFFFFFC12DD850, 0x0) Error: KERNEL_MODE_EXCEPTION_NOT_HANDLED_M file path: C:\Windows\system32\drivers\dxgmms1.sys product: Microsoft® Windows® Operating System company: Microsoft Corporation description: DirectX Graphics MMS Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch. This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
On Mon 16/04/2012 10:19:25 GMT your computer crashed crash dump file: C:\Windows\memory.dmp This was probably caused by the following module: dxgmms1.sys (dxgmms1!VidMmInterface+0xE953) Bugcheck code: 0x8E (0xFFFFFFFFC0000005, 0xFFFFFFFF958EE6BC, 0xFFFFFFFFC12DD850, 0x0) Error: KERNEL_MODE_EXCEPTION_NOT_HANDLED file path: C:\Windows\system32\drivers\dxgmms1.sys product: Microsoft® Windows® Operating System company: Microsoft Corporation description: DirectX Graphics MMS Bug check description: This bug check indicates that a kernel-mode application generated an exception that the error handler did not catch. The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
Marsh Posté le 16-04-2012 à 11:40:28
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
