Adaptateur EPS 12V? (Résolu) - Matériels & problèmes divers - Hardware
Marsh Posté le 22-12-2009 à 21:38:38
Résolu
http://www.playtool.com/pages/psucompat/compat.html
==> The 12V CPU power cables
CPUs used to be powered by the 20 pin main power cable. Almost all current motherboards power their CPU with a 12 volt CPU power cable. There are two kinds: the 4 pin 12V cable and the 8 pin 12V cable. The 4 pin cable is often called a P4 cable (although it's a very bad name) and the 8 pin cable is called an EPS12V cable. You must plug a cable into this motherboard connector or the CPU will receive no power. The compatibility rules between 4 and 8 pin connectors have a lot in common with the rules for 20 and 24 pin connectors. The best choice is to plug a 4 pin cable into a 4 pin connector, an 8 pin cable into an 8 pin connector, or a 4+4 cable into either kind of connector. You can get adapters which will convert various kinds of power supply cables into both 4 pin and 8 pin 12V cables. You can plug a 4 pin 12V cable into an 8 pin motherboard and it will sometimes work properly but other times it won't work at all or will burn/melt the connector. As with plugging a 24 pin cable into a 20 pin motherboard connector, you can plug an 8 pin cable into a 4 pin connector and leave 4 pins hanging over the end but you can also have the same problems with things preventing it from fitting. It will work fine if it fits. If you're buying a new power supply then the safest choice for the long haul is to get one with a 4+4 power cable because it's compatible with both 4 and 8 pin connectors.
Marsh Posté le 22-12-2009 à 20:59:44
Bonsoir
J'ai acheté des pièces par ci par la toute à l'heure et parmis celles ci, une carte mère qui me pose problèmes... En effet, elle comprend une alim cpu 8 broches et une alim carte mère 24 broches... Pas de problèmes pour la 24 broches que j'ai en 20+4 mais je n'ai qu'une 4 broches sur mon alimentation, alors je me demandais si le fait que la carte mère ne se mettes pas sous tension soit dus à ça?
Je compte acheter un adaptateur demain de type 4 broches F vers 4x2 broches M, et je voudrais savoir si le problème est bien dus à ça ou s'il peut s'agir d'autre chose?
L'alim a été testé sur un autre ordi et elle marche sans problèmes, je pense donc qu'il s'agit bien de ça...
Au passage je voudrais savoir si ça se vend à Mongalet, ces type d'adaptateurs? ^-^
Bon, je sais que le topic est balo, que je ne donnes aucun élément précis, et que ça craint mais bon... Je voulais juste que certaines personnes me confortent dans mon idée d'achat d'adaptateur 4P F vers 4x2P M lol, histoire de ne pas déprimer...
J'espère qu'il s'agit réellement de ça et pour ceux qui voudrais m'aider, la carte mère est une Gigabite MA770-UD3 équipée d'un AMD Quad core 3.4ghz
Je ne pense pas que le reste de la config soit éssentiel à vos yeux? L'alim est une 550W de chez MAD-X (j'avais pas de frix =_=) avec LED bleues hihihihih merci d'avance
Message édité par Latnok le 22-12-2009 à 21:39:18
