Le 3.3V monte à plus de 150V
Le 3.3V monte à plus de 150V - Boitier - Hardware
Marsh Posté le 19-09-2005 à 21:36:57
Bonsoir.
Mon Pc me joue actuellement de drôles de tours.
Il reboote sauvagement et de façon assez aléatoire.
Quand je vais voir les logs de µGuru, il s'avère que l'erreur qui me fait rebooter est ne erreur de voltage.
Voici le log :
2005/09/19 19:44:04 Warning:=3.3V Voltage: 154V
2005/09/19 19:44:05 Warning:=3.3V Voltage: 153V
2005/09/19 19:44:06 Warning:=3.3V Voltage: 154V
2005/09/19 19:54:15 Warning:=3.3V Voltage: 154V
2005/09/19 19:54:22 Warning:=3.3V Voltage: 156V
2005/09/19 19:54:24 Warning:=3.3V Voltage: 155V
2005/09/19 19:54:28 Warning:=3.3V Voltage: 154V
2005/09/19 19:54:37 Warning:=3.3V Voltage: 154V
2005/09/19 19:55:02 Warning:=3.3V Voltage: 156V
2005/09/19 19:56:51 Warning:=3.3V Voltage: 156V
2005/09/19 19:58:11 Warning:=3.3V Voltage: 158V
2005/09/19 19:58:57 Warning:=3.3V Voltage: 156V
2005/09/19 19:59:51 Warning:=3.3V Voltage: 154V
2005/09/19 19:59:52 Warning:=3.3V Voltage: 156V
2005/09/19 20:00:07 Warning:=3.3V Voltage: 156V
2005/09/19 20:00:15 Warning:=3.3V Voltage: 155V
2005/09/19 20:00:16 Warning:=3.3V Voltage: 156V
2005/09/19 20:00:19 Warning:=3.3V Voltage: 155V
2005/09/19 20:00:20 Warning:=3.3V Voltage: 153V
2005/09/19 20:00:23 Warning:=3.3V Voltage: 152V
2005/09/19 22:17:27 Warning:=3.3V Voltage: 156V
2005/09/19 22:17:43 Warning:=3.3V Voltage: 156V
2005/09/19 22:17:44 Warning:=3.3V Voltage: 156V
2005/09/19 22:17:57 Warning:=3.3V Voltage: 156V
2005/09/19 22:18:13 Warning:=3.3V Voltage: 156V
2005/09/19 22:18:19 Warning:=3.3V Voltage: 155V
2005/09/19 22:19:08 Warning:=3.3V Voltage: 155V
2005/09/19 22:19:15 Warning:=3.3V Voltage: 155V
2005/09/19 22:19:19 Warning:=3.3V Voltage: 154V
2005/09/19 22:19:22 Warning:=3.3V Voltage: 155V
2005/09/19 22:20:16 Warning:=3.3V Voltage: 154V
2005/09/19 22:20:24 Warning:=3.3V Voltage: 159V
2005/09/19 22:21:08 Warning:=3.3V Voltage: 156V
2005/09/19 22:21:20 Warning:=3.3V Voltage: 156V
2005/09/19 22:21:23 Warning:=3.3V Voltage: 155V
2005/09/19 22:21:24 Warning:=3.3V Voltage: 152V
2005/09/19 22:21:29 Warning:=3.3V Voltage: 155V
2005/09/19 22:21:36 Warning:=3.3V Voltage: 154V
2005/09/19 22:21:41 Warning:=3.3V Voltage: 155V
2005/09/19 22:21:48 Warning:=3.3V Voltage: 154V
2005/09/19 22:21:51 Warning:=3.3V Voltage: 156V
2005/09/19 22:21:52 Warning:=3.3V Voltage: 156V
2005/09/19 22:21:53 Warning:=3.3V Voltage: 155V
2005/09/19 22:21:54 Warning:=3.3V Voltage: 156V
2005/09/19 22:21:55 Warning:=3.3V Voltage: 155V
2005/09/19 22:21:59 Warning:=3.3V Voltage: 153V
2005/09/19 22:22:01 Warning:=3.3V Voltage: 155V
2005/09/19 22:22:02 Warning:=3.3V Voltage: 152V
2005/09/19 22:22:32 Warning:=3.3V Voltage: 156V
2005/09/19 22:22:33 Warning:=3.3V Voltage: 155V
2005/09/19 22:22:34 Warning:=3.3V Voltage: 154V
2005/09/19 22:22:35 Warning:=3.3V Voltage: 155V
2005/09/19 22:22:38 Warning:=3.3V Voltage: 155V
2005/09/19 22:22:39 Warning:=3.3V Voltage: 156V
2005/09/19 22:22:43 Warning:=3.3V Voltage: 153V
2005/09/19 22:22:47 Warning:=3.3V Voltage: 152V
2005/09/19 22:22:49 Warning:=3.3V Voltage: 153V
2005/09/19 22:22:51 Warning:=3.3V Voltage: 155V
2005/09/19 22:22:52 Warning:=3.3V Voltage: 154V
2005/09/19 22:22:53 Warning:=3.3V Voltage: 148V
2005/09/19 22:22:54 Warning:=3.3V Voltage: 150V
2005/09/19 22:22:55 Warning:=3.3V Voltage: 153V
2005/09/19 22:22:56 Warning:=3.3V Voltage: 154V
2005/09/19 22:22:58 Warning:=3.3V Voltage: 152V
Alors voilà ma question :
Est-il possible que les 3.3V monte autant ?? :pt1cable:
150V ça m'a l'air un peu abérant, je me demade si ce n'est pas plutôt la sonde qui aurait grillée...
Merci.
Message édité par Nesis le 19-09-2005 à 21:39:02
Marsh Posté le 19-09-2005 à 21:37:50
:pt1cable: :pt1cable: :pt1cable: :pt1cable:
sauve toi !!! ton pc va exploser !!
Marsh Posté le 19-09-2005 à 21:38:37
Très constructif comme réponse... :o
Marsh Posté le 19-09-2005 à 21:39:11
oui je trouve aussie :)
Marsh Posté le 19-09-2005 à 21:39:42
Quelqu'un de plus sérieux est-il là?
Marsh Posté le 19-09-2005 à 21:44:11
nan : o) attend un peu tu va avoir des reponse mais ton probleme est vraiment etrange :???:
Message édité par old-config le 19-09-2005 à 21:44:45
Marsh Posté le 19-09-2005 à 21:46:10
Oui.
Et je précise que ces reboot sauvage (et donc cette montée en voltage) ne se fait que pendant les jeux.
Marsh Posté le 19-09-2005 à 21:47:20
Ca peut venir de ta carte mère, parce que 150V sur le 3.3, je pense pas que ton pc supporterais longtemps..  :lol:
T'as pas touché au bios ces derniers temps?
Last.fm
Marsh Posté le 19-09-2005 à 21:47:41
alim sans marque non ? la solution ===> une bonne alim :)
Marsh Posté le 19-09-2005 à 21:54:17
Ca fait deja 2 reponses de trop, c'est pas compliqué si sont alim envoyait du 150v ca carte mere serait deja morte.
C'est donc cette derniere qui doit avoir un probleme.
Marsh Posté le 19-09-2005 à 21:55:05
@Transparency:
J'ai fait un Clear CMOS il y a 40min pour voir si ça ne résolvait pas le problème, mais non. Sinon, je n'ai fait aucun overclooking sur ma machine.
@old-config:
Mon alim n'est pas une no-name, mais je la soupçone de lâcher. Pourtant elle a moins d'un mois ! Et j'ai beau débranncher des périfériques (2 lecteurs de CD et alim suplémentaire sur la carte vidéo), rien n'y fait, le problème persiste.
Marsh Posté le 19-09-2005 à 21:56:48
Pour ma carte mère (ASUS Fatal1ty AN8SLI) elle me dit l'erreur suivante : "Test DMA Channel 1". Késako?
Message édité par Nesis le 19-09-2005 à 21:57:08
Marsh Posté le 19-09-2005 à 22:40:45
Aie.
Maitenant le PC ne veut plus du tout booter.
J'ai droit à un bip log et trois bips courts au démarrage et rien d'autre.
L'écran de s'allume même pas.
Et la carte mère me donne un numéro d'erreur signifiant "Initialize EISA slot".
Quelqu'un pour me sauver ? :(
Edit: Je m'étais planté dans le nombre de bips...
Message édité par Nesis le 19-09-2005 à 22:42:18
Marsh Posté le 20-09-2005 à 08:20:54
Teste l'alim séparément (en faisant un court circuit avec un trombone sur le fil vert et un fil noir du connecteur CM).
Si l'alim est OK, c'est la carte mère qui est HS je pense.
Message édité par Lodeno le 20-09-2005 à 08:21:15
Marsh Posté le 20-09-2005 à 08:30:16
J'ai testé une autre alim sur mon PC, et il démarre.
Donc c'est encore mon alim qui a grillée (d'une drôle de façon, cette fois).
Moralité, trouver une BONNE alim bien stable ! J'ai jamais eu un PC boufant autant d'énergie...
Merci de votre aide ^^
Quelqu'un a un petit conseil pour une alim?
Marsh Posté le 20-09-2005 à 08:35:39
Tu avais quoi comme alim ?
Détails ta config pour la puissance nécessaire
Message édité par bidoulou le 20-09-2005 à 08:36:01
