Afox Radeon HD 7850 (Single Slot) AF7850-2048D5S1 - Carte graphique - Hardware
MarshPosté le 13-08-2012 à 01:49:09
Pas de trace de Afox sur ce forum... etrange.
Voici un produit interessant une carte graphique Radeon HD 7850 simple emplacement.
Marque et modele : Afox Radeon HD 7850 (Single Slot) AF7850-2048D5S1
Photo marketage :
Fiche technique :http://www.afox-corp.com/en/produc [...] d=46&id=46 Graphics Engine AMD Radeon HD7850 Bus Standard PCI Express 3.0 Video Memory GDDR5 2048MB Engine Clock 860 MHz Memory Clock 4800 MHz ( 1200 MHz GDDR5 ) RAMDAC 400MHz Memory Interface 256-Bit D-Sub Max Resolution 2048 x 1536 DVI Max Resolution 2560 x 1600 DVI Output Yes x 1 Display Port Yes x 2 HDMI Yes x 1 HDCP Support Yes Accessories 1 x Driver CD 1 x Quick Guide 1 x Power cable
Test : http://www.tomshardware.de/Afox-Radeon-HD_7850-Single-Slot,testberichte-241012.html (en allemand )
Excusez le traducteur automatique, il ne sait pas vraiment traduire... Volume You at a constant room temperature of 22 ° C measured values expose now ruthlessly the problems of single-slot design. Just over 42 dB(A) for the hardware-accelerated video output are actually already way too much and disqualify this card thus in the original condition for use in a HTPC very clearly. With a manually adjusted fan curve you can express but quickly this value dB(A) under 39, if you can live with chip temperatures of abundant 80 ° C and ensures that the room temperature does not exceed 25 ° C. Otherwise, it will again according to.
What is gone in a melodrama by the winds of the fan, is gaming then quickly forgotten, because the values determined during the gaming are tolerable, if the in-game sound with a certain minimum level will be held again. The significantly above 50 dB at the stress test are however really annoying and demonstrate the limitations of the design.
Donc pas dans un mini-ITX a priori.
A vous de jouer, si vous avez des informations complementaires postez !
Marsh Posté le 13-08-2012 à 01:49:09
Photo marketage
Fiche technique : http://www.afox-corp.com/en/produc [...] d=46&id=46
RAMDAC 400MHz
DVI Output Yes x 1
HDMI Yes x 1
HDCP Support Yes
1 x Quick Guide
1 x Power cable
Ou acheter ? http://www.afox-corp.com/en/where_to_buy.asp?Id=19
En Europe de l'ouest des revendeurs en Belgique, Pays-Bas et Royaume-Uni de Grande Bretagne et d'Irlande. Ca fait pas besef...
Volume
Message édité par eiktee le 13-08-2012 à 02:02:45
