Problèmes de freeze avec démos Driv3r et Trackmania - Carte graphique - Hardware
Marsh Posté le 11-05-2005 à 16:15:06
Comme d'habitude on va devoir le dire combien de fois, preciser, votre config complete avec les temperatures.
Marsh Posté le 11-05-2005 à 17:05:32
Désolé, je voulais déjà savoir si quelqu'un a déjà eu ce problème, avant de commencer à chercher une solution...
Je n'ai pu vérifier que la température du processeur graphique : 55 degrés Celsius (après le redémarrage, évidemment).
Concernant la config complète, voici un extrait (j'ai un peu épuré) du fichier dxdiag :
System Information
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: French (Regional Setting: French)
System Manufacturer: MEDIONPC
System Model: MS-7046
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Intel(R) Pentium(R) 4 CPU 3.00GHz (2 CPUs)
Memory: 1024MB RAM
Page File: 208MB used, 2252MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found. DirectDraw test results: All tests were successful. Direct3D 7 test results: All tests were successful. Direct3D 8 test results: All tests were successful. Direct3D 9 test results: All tests were successful.
Sound Tab 1: DirectSound test results: All tests were successful.
Sound Tab 2: DirectSound test results: All tests were successful.
Music Tab: DirectMusic test results: All tests were successful.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 6200 TurboCache(TM)
Manufacturer: NVIDIA
Chip type: GeForce 6200 TurboCache(TM)
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0161&SUBSYS_F853107D&REV_A1
Display Memory: 256.0 MB
Current Mode: 1024 x 768 (32 bit) (75Hz)
Monitor: Écran Plug-and-Play
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.7644 (English)
DDI Version: 9 (or higher)
WHQL Logo'd: Yes
Mini VDD: nv4_mini.sys
Mini VDD Date: 12/15/2004 13:01:00, 3329504 bytes
Device Identifier: {D7B71E3E-4221-11CF-1968-59D800C2CB35}
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: All tests were successful.
D3D7 Test Result: All tests were successful.
D3D8 Test Result: All tests were successful.
D3D9 Test Result: All tests were successful.
Sound Devices
Description: C-Media Rear Panel Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_434D&DEV_4980&SUBSYS_70461462&REV_0904
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: cmudax.sys
Driver Version: 5.12.0001.0008 (English)
Driver Attributes: Final Debug
WHQL Logo'd: Yes
Date and Size: 10/1/2004 14:58:10, 1272000 bytes
Other Files:
Driver Provider: C-Media Electronics Inc.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 100, 192000
Static/Strm HW Mix Bufs: 17, 16
Static/Strm HW 3D Bufs: 17, 16
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): Yes
Registry: OK
Sound Test Result: All tests were successful.
Description: Lecture sur modem n° 0 (émulé)
Default Sound Playback: No
Default Voice Playback: No
Hardware ID:
Manufacturer ID: 1
Product ID: 81
Type: Émulé
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Marsh Posté le 11-05-2005 à 17:13:52
tu as quoi comme driver graphique, les 76.44 si j'ai bien vu?
Marsh Posté le 11-05-2005 à 17:14:58
magnifique, un 3ghz avec 1Go et...
une Geforce 6200 turbocache ![]()
Marsh Posté le 11-05-2005 à 17:16:19
Ça serait-y pas un problème de mémoire ???
Passe la sous memtest pour la vérifier.
Marsh Posté le 11-05-2005 à 17:17:27
c'est vrai que 6200 est "très" faible il aurait du mettre une 6600, mais bon on passe...
peu etre ton pilote pour ton turbocache qui merde
Marsh Posté le 12-05-2005 à 09:09:05
J'ai acheté le PC tout fait, et je compte bien changer de CG d'ici un an (après extinction de la garantie
Je l'ai acheté en toute connaissance de cause, et je n'en suis pas du tout déçu. Je n'ai pas constaté (en tous cas pour l'instant) ce problème avec d'autres jeux.
Concernant les pilotes graphiques, j'ai effectivement installé les 76.44 (WHQL), mais que très récemment (peut-être est-ce lié ?)...
Je pensais à un problème de son 3D (je n'ai que 2 enceintes : mauvaise configuration ?).
Malheureusement, je n'ai pas eu le temps de réaliser des tests hier soir, mais je compte bien me rattraper d'ici ce week-end ! (je vous tiendrai au courant)
En tous cas, merci pour vos suggestions (je vais quand-même essayer memtest, au cas où).
N'hésitez pas à continuer à proposer des trucs : tout conseil sera le bienvenu !
Newmagic
Marsh Posté le 12-05-2005 à 10:04:30
essaye d'installer les dernier driver 76.45 http://www.station-drivers.com/pag [...] ceware.htm sinon fait comme ils te l'ont dis: un memtest, et au dernier cas installe les drivers sur le site http://www.nvidia.fr
Marsh Posté le 12-05-2005 à 10:30:45
Bonne idée concernant les 76.45 !
Par contre, j'ai déjà essayé les pilotes officiels 71.89, mais ils ne vont pas : les Sims2 ne se lancent pas avec ces pilotes et ma carte graphique (problème corrigé avec les 76.10 ou même avant)...
Marsh Posté le 12-05-2005 à 10:58:33
moi je tien à te dire que j'avais un soucis avec ses deux jeux: brother in arms et swat 4.
mon problème c'était qu'ils faisaient rebouter mon PC quand je quittais le jeu (c'est assez ennuyant),donc j'ai installer hier les 76.45 et puis là j'ai aucun soucis,mais pour toi par contre j'en sais rien!!!
bon courage...
Marsh Posté le 12-05-2005 à 11:24:12
En poursuivant mes recherches sur le net, j'ai eu l'occasion de lire que des gens ont déjà eu ce problème et l'ont "réglé" en coupant le son dans la config du jeu (en tous cas pour Trackmania).
Je testerai cela d'abord ![]()
Marsh Posté le 12-05-2005 à 11:25:06
J'ai un peu peur de Memtest : n'y a-t-il aucun risque pour les barettes (de trop les solliciter) ?
Marsh Posté le 12-05-2005 à 11:27:43
logiquement non...
et puis tu verras si tu as des erreurs sur tes chipset.
Marsh Posté le 13-05-2005 à 08:51:22
J'ai pu réaliser quelques tests hier soir, et il semble que le problème soit résolu : il suffisait apparemment de réduire d'un "cran" l'accélération matérielle pour la gestion du son (dxdiag, onglet Son), pour se positionner sur "accélération standard".
J'émets tout de même des réserves car je n'ai pas eu beaucoup de temps (j'ai testé Driv3r pendant environ 1/4 heure, mais pas du tout Trackmania Sunrise).
De plus, ce n'est qu'une solution de contournement (l'idéal serait de savoir exactement d'où vient le problème : pilote(s), jeu(x) ou matériel...).
Je referai des essais plus poussés durant le week-end.
Newmagic
Marsh Posté le 14-05-2005 à 18:22:35
effectivement ca arrive quelque fois ce probleme. tente une mise a jour des pilotes de carte son, si ca merde encore, une Sound Blaster Live 24bits coute pas trop cher
si tu as les moyens, change aussi de carte graphique, car tu as un bon pc mais ta carte est vraiment mauvaise, si tu veux jouer c'est dommage
Marsh Posté le 16-05-2005 à 11:04:26
Merci WipEout 2097 pour ta réponse,
J'ai effectivement l'intention de changer de carte graphique , mais lorsque la garantie du PC aura expiré (dans un an). Pour l'instant, elle me convient (par exemple, Doom3 ne rame pas du tout en 1024*768, High quality).
Concernant mon problème de son, j'ai essayé avec Trackmania hier et... ça plante encore !
Par contre, si je désactive le son dans le jeu, aucun problème...
Je pense en effet que je vais passer au cran suivant des tests : mettre à jour les pilotes avec ceux proposés par Medion.
Marsh Posté le 21-06-2005 à 09:45:29
J'ai résolu le problème en installant la toute dernière mise à jour des pilotes sons disponibles en téléchargement sur le site de Medion ! Tout refonctionne normalement !
Marsh Posté le 11-05-2005 à 12:31:03
J'ai installé les démos de Trackmania Sunrise et de Driv3r et, après avoir joué quelques secondes, les jeux se bloquent, image fixe avec un son qui boucle, puis j'ai l'écran bleu indiquant un vidage de la mémoire => reboot obligatoire...
Pourtant, au début, je peux jouer sans problème (frame rate et qualité graphique excellents) !
Quelqu'un a-t-il déjà eu ce problème ?
Cela peut-il venir du son (chipset 6.1 intégré), ou de la carte graphique (Carte GeForce 6200 turboCache avec pilotes 76.44 WHQL) ?
Merci d'avance.
