Problème dans mon tracert ?
Problème dans mon tracert ? - FAI - Réseaux grand public / SoHo
Marsh Posté le 20-04-2011 à 23:34:43
J'ai des lenteurs anormales sur mon réseau :
J'ai fait un tracert vers www.bouyguestelecom.fr et j'ai la ligne 3 qui reste presque tout le temps sans réponse
04/20/11 23:23:29 Fast traceroute www.bouyguestelecom.fr
Trace www.bouyguestelecom.fr (80.156.248.24) ...
 1 192.168.1.254     3ms    3ms    3ms  TTL: 64  (pending)
 2 89.89.100.225    45ms   41ms   42ms  TTL:254  (pending)
 3   No Response      *      *      *
 4 62.34.0.94       43ms   44ms   48ms  TTL:252  (pending)
 5 195.219.224.1    48ms   43ms   44ms  TTL:251  (pending)
 6 80.231.153.37    43ms   48ms   44ms  TTL:250  (pending)
 7 195.219.241.209  45ms    *      *    TTL:249  (pending)
 8 195.219.241.94   44ms   43ms   44ms  TTL:247  (pending)
 9 62.154.5.90      45ms   45ms   45ms  TTL:247  (pending)
10 80.156.248.24    44ms   45ms   45ms  TTL: 55  (pending)
04/20/11 23:26:28 traceroute 62.34.0.94
Trace 62.34.0.94 ...
192.168.1.254   RTT:   3ms TTL: 64 (pending)
89.89.100.225   RTT:  46ms TTL:254 (pending)
* * * failed
62.34.0.94      RTT:  52ms TTL:252 (pending)
J'ai l'impression que le problème est ici :
04/20/11 23:28:02 ping 194.117.195.217
Ping 194.117.195.217 ...
  1  failed
  2  failed
  3  failed
  4  failed
  5  failed
  6  Addr:194.117.195.217, RTT: 44ms, TTL: 253
  7  failed
  8  failed
  9  Addr:194.117.195.217, RTT: 44ms, TTL: 253
 10  failed
04/20/11 23:31:32 Fast traceroute www.google.fr
Trace www.google.fr (209.85.227.104) ...
 1 192.168.1.254     3ms    3ms    3ms  TTL: 64  (FAST3504.home ok)
 2 89.89.100.225    43ms   44ms   44ms  TTL:254  (No rDNS)
 3 194.117.195.217   *     48ms    *    TTL:253  (pending)
 4 62.34.0.45       44ms   45ms   47ms  TTL:252  (No rDNS)
 5 89.89.102.33     82ms  100ms   98ms  TTL:251  (pending)
 6 89.89.101.102    44ms   47ms   52ms  TTL:250  (pending)
 7 72.14.217.60     44ms   50ms   43ms  TTL:248  (pending)
 8 72.14.238.234    45ms   49ms   59ms  TTL:247  (pending)
 9 216.239.43.233   49ms   54ms   51ms  TTL:245  (pending)
10 216.239.49.45    49ms   48ms   56ms  TTL:245  (pending)
11 209.85.243.93    61ms   52ms   49ms  TTL:243  (pending)
12 209.85.227.104   49ms   51ms   52ms  TTL: 51  (pending)
En googlant cette fameuse ip 194.117.195.217 , je trouve "G3-27.core02-m.club-internet.fr".
Et en googlant G3-27.core02-m.club-internet.fr je trouve plein de messages parlant de lenteurs...
Quelle est la procédure à suivre d'après vous pour résoudre le problème?
Marsh Posté le 20-04-2011 à 23:37:59
ce n'est pas forcément un problème. Ce n'est pas parce qu'un routeur intermédiaire ne répond pas au traceroute qu'il fonctionne mal.
Que va-t-il se passer cette gelgamar ? vous le découvrirez janamont à 20h
Marsh Posté le 21-04-2011 à 09:16:15
D'ou viendrais mes problèmes de lenteur dans ce cas?
J'ai refais un test :
--- Scany to www.google.fr ---
1) fast3504.home (192.168.1.254) 10.481 ms, 448/448 ps, 0.0% loss
2) 89.89.100.225 (89.89.100.225) 53.671 ms, 447/447 ps, 0.0% loss France
3) 194.117.195.217 (194.117.195.217) 58.479 ms, 275/447 ps, 38.5% loss France
4) 62.34.0.45 (62.34.0.45) 56.775 ms, 447/447 ps, 0.0% loss France
5) 89.89.102.33 (89.89.102.33) 143.651 ms, 447/447 ps, 0.0% loss France
6) 89.89.101.102 (89.89.101.102) 56.015 ms, 446/447 ps, 0.2% loss France
7) 72.14.217.60 (72.14.217.60) 57.563 ms, 447/447 ps, 0.0% loss États-Unis
8) 72.14.238.234 (72.14.238.234) 61.862 ms, 447/447 ps, 0.0% loss États-Unis
9) 216.239.43.233 (216.239.43.233) 62.769 ms, 447/447 ps, 0.0% loss États-Unis
10) 209.85.249.31 (209.85.249.31) 65.605 ms, 447/447 ps, 0.0% loss États-Unis
11) 216.239.46.85 (216.239.46.85) 69.128 ms, 447/447 ps, 0.0% loss États-Unis
12) 209.85.146.99 (209.85.146.99) 61.506 ms, 447/447 ps, 0.0% loss États-Unis
On voit nettement un grand nombre de paquets perdus (38,5%) :
Marsh Posté le 21-04-2011 à 10:44:54
ben oui mais si les paquets ne sont pas perdus sur les noeuds d'après c'est bien que ce routeur ne perd pas de paquets sauf quand on le ping/traceroute...
Marsh Posté le 21-04-2011 à 10:46:29
Donc tu es formel, ce n'est PAS un problème ces paquets perdus?
Marsh Posté le 21-04-2011 à 10:48:55
ben tant que tu ne perds pas de paquets quand tu communiques avec la destination, on ne peut pas dire que les routeurs perdent des paquets, donc non ce n'est pas un problème.
Marsh Posté le 21-04-2011 à 10:50:33
Comment pourrais t on diagnostiquer un soucis dans ce cas?
J'ai de réels problèmes sporadiques de lenteur...
Marsh Posté le 22-04-2011 à 21:18:31
Ca veut dire quoi des lenteurs de reseaux c tres subjectifs, et c pas avec un tracert que tu vas aboutir a quoi que soit...
Faudrait deja quantifier ton debit
Marsh Posté le 25-04-2011 à 20:59:31
Un routeur a autre chose à faire qu'à répondre à des pings (par exemple router ...) d'où le filtrage souvent présent pour bloquer les pings. Ca n'a aucune influence sur ce qui se passe apres.
