New lecteur MP3 I Audio G3 : 1Go et 50h de batterie !
New lecteur MP3 I Audio G3 : 1Go et 50h de batterie ! - Matériel - Video & Son
Marsh Posté le 04-12-2004 à 04:05:34
Voilà la bête !  :D
http://eng.iaudio.com/
http://eng.iaudio.com/zeroboard/new_img/product/iaudioG3/g3_01.jpg
http://eng.iaudio.com/zeroboard/new_img/product/iaudioG3/g3_10.jpg
Ca a l'air pas mal :
Spécifications
Bit Rate MPEG 1/2/2.5 layer 3 (8Kbps ~ 320Kbps) (8kHz ~ 48kHz) and VBR
All ranges of WMA7 WMA (20Kbps ~ 192Kbps) (8kHz ~ 48kHz)
WMA9 CBR(5Kbps Mono ~ 320Kbps Stereo)
VBR(48Kbps ~ 256Kbps)
    * WMA9 Pro, Lossless and Voice Codec not supported.
OGG (Currently support up to Q8)
WAV (Up to 44.1Khz Stereo)
 Memory 256MB/512MB/1GB
 Battery AA battery X1
 Power play up to 50 hours, based on company's self-test
 Buttons 8 buttons (Play, REC, MODE, Menu, FF, REW, VOL+, VOL-)
 Switch Hold
 Display 128 X 64 full graphic LCD
 SNR 95 dB
 Max Output 16 Ohm earphone : 13mW + 13mW
 Frequency Range 20Hz ~ 20KHz
 Size 64.0mm X 45.0mm X 17.10mm (H X W X D)
 Weight 36g (exclude battery)
Feature
MP3, MP2, OGG, WMA, ASF and WAV (Up to 48khz Stereo) Playback, Voice Recording, FM Radio, Listening and Recording, Direct MP3 Encoding, Removable Disk
 Built-in Flash Memory (256MB / 512MB / 1GB)
 4 Lines of Graphic LCD (Indigo Blue Backlight)
 USB 2.0 Interface
 Long Playback Time: Up to 50 hours (Based on company's self-test, Used AA Alkaline battery)
 Multilingual Support (iAUDIO G3 uses common fonts and over 40 thousand character to display languages from all over the world)
 Enhanced Integrated Navigator
 Play/Pause/Play Intro, Stop/Power Off, Record
 Next Track/Previous Track, Fast Forward/Fast Rewind
 Infinite Loop
 Supports Resume. Fade In, Auto Play
 Search Speed & Skip Speed Setting
 40 levels of digital volume control
 Various EQ and sound field effects
  - User adjustable 5-band Equalizer
  - Normal, Rock, Pop, Jazz, Classic, Vocal, User
  - Supports BBE, Mach3Bass, MP Enhance, 3D Surround
 Resume, Auto Power Off
 Hold
 Backlight ON Time Control, Scroll Speed
 Firmware & Logo Download
 ID3V2, ID3V1, Filename Support
 Product Info Display (Firmware version, Memory Capacity/Usage)
 Software
  - JetShell (File Transfer, MP3/WMA/WAV/Audio CD Play, MP3 Encoding)
  - JetAudio (Integrated multimedia playing software)
Vous en pensez quoi ? Point de vue qualités et défauts qqun connait ? J'aimerais bien m'en prendre un.  :D
Il fait fonction timer (= réveil ?) et est directement reconnu en tant que support de données amovible par l'ordinateur !  :)
Prix :
256 Mo : 161€
512 Mo : 210€
1 Go : 280€
(sur ce site : http://www.uhu.ch/setfr.htm?/francais/iAUDIO_G3/G3.htm )
PS : socle et sacoche en option on dirait...
Message édité par Prophet_ch le 04-12-2004 à 04:22:23
Marsh Posté le 04-12-2004 à 04:16:46
Dommage qu'il soit si epais. Question de pile AA, surement...
Message édité par A S H le 04-12-2004 à 04:17:01
" ...arrêté par les flics avec 4g de sang par litre d'alcool... "
Marsh Posté le 04-12-2004 à 04:24:19
1.7cm ca me semble pas épais.  :??:
Je ne connais pas spécialement les autres, mais les Iriver avec leur formes arondies pour la pile ne sont en tout cas pas plus mince à première vue !
Message édité par Prophet_ch le 04-12-2004 à 04:24:40
Marsh Posté le 04-12-2004 à 04:39:44
Le iAudio M3 (meme marque) fait 1.4cm d'epaisseur (20go)
L'ipod G4 20go, pareil
Le jukebox Sony (20go), pareil
Et on descend encore plus bas avec les mini jukebox (ipod mini, Rio Carbon)
D'un autre coté, ils sont plus longs et plus larges, alors j'imagine que chacun voit midi a sa porte. Pour ma part l'epaisseur est le critere preponderant dans la compacité d'un baladeur (poche de falzard oblige). La bonne chose pour ce iAudio G3 est que contrairement aux iRiver, il n'a pas une forme batarde (triangulaire) qui complique les choses selon moi...
Marsh Posté le 05-12-2004 à 02:52:42
Dans la poche je préfère un truc carré qu'un long truc rond.  :D
Marsh Posté le 07-12-2004 à 19:48:15
Si le son son est aussi bon qu'un i-river il ne me manque qu'une seule carac pour l'acheter:
est-il UMS (non precise sur le site)
Perso je refuse d'avoir a passer par le software d'upload/download proprietaire
Et j'ai l'impression que c'est de plus en plus rare les walkman mp3 UMS.
Serait-ce la pression des majors pour empecher l'upload. (en l'occurence pour ma part c'est pas pour pirater par upload, mais c'est juste que je veux pas avoir a me faire c...r a me trimballer un driver proprietaire)
Marsh Posté le 08-12-2004 à 00:07:42
Concernant un autre baladeur Cowon, le M3, il y a 2 maniere de transferer, et le site ne precise pas  que les transferts de mp3 peuvent etre faits par simples copier/coller via explorateur de l'OS. Il se contente de mettre en avant la solution via leur propre logiciel. A verifier, donc...
Marsh Posté le 08-12-2004 à 00:12:24
[:drapal]
Marsh Posté le 08-12-2004 à 00:13:50
ça à l'air d'être le cas
Marsh Posté le 08-12-2004 à 00:48:18
Encore un bon point :
Use Mac or Linux? No problem!!
iAUDIO G3 is available to be used on Mac or Linux OS.
Et pour finir j'ajoueterais que 280€ pour la version 1Go c'est vraiment pas cher si on le compare au iRiver iFP-999 (100€ plus cher, plus lourd et plus gros) !
Marsh Posté le 08-12-2004 à 04:31:19
L'a de la gueule... :)
Cowon m'a tt l'air d'etre le nouvel iRiver, esperons qu'il ne suivent pas le meme chemin... :)
• • • "La démocratie c'est bien mais il faudrait que les gens soient pas cons..." © Alpacou aux Nouilles • • •
Marsh Posté le 08-12-2004 à 14:40:47
La version 1Go est à 187,02€ (=249USD) sur jetaudio.com !!
