Saut de ligne en xsl - XML/XSL - Programmation
Marsh Posté le 03-03-2006 à 12:08:05
Bonjour à tous! Je suis un grand débutant avec fop, pouvez vous me dire pourquoi ce code ne permet pas de sauter des lignes? <?xml version="1.0" encoding="UTF-8"?> <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:fo="http://www.w3.org/1999/XSL/Format"> <xsl:template match="/"> <fo:root xmlns:fo="http://www.w3.org/1999/XSL/Format"> <fo:layout-master-set> <fo:simple-page-master master-name="simple" page-height="29.7cm" page-width="21cm" margin-top="1cm" margin-bottom="1cm" margin-left="1cm" margin-right="1cm"> <fo:region-body margin-top="1cm"/> <fo:region-before extent="0cm"/> <fo:region-after extent="1cm"/> </fo:simple-page-master> </fo:layout-master-set> <fo:page-sequence master-reference="simple"> <fo:flow flow-name="xsl-region-body"> <fo:block font-family="Helvetica" font-size="8pt"> <xsl:apply-templates select="root/user"/> <!--xsl:apply-templates select="root/dossier"/--> </fo:block> </fo:flow> </fo:page-sequence> </fo:root> </xsl:template> <xsl:template match="user"> <fo:table space-before="10pt"> <fo:table-column column-width="3cm"/> <fo:table-column column-width="3cm"/> <fo:table-column column-width="13cm"/> <fo:table-body> <fo:block> <fo:table-row> <fo:table-cell border-style="solid" padding="2pt" border-width="1pt" number-columns-spanned="2"> <fo:block font-weight="bold"> Service <!--xsl:value-of select="libelle/label2"/--> </fo:block> </fo:table-cell> <fo:table-cell border-style="solid" padding="2pt" border-width="1pt" number-columns-spanned="2"> <fo:block font-weight="bold"> Service <!--xsl:value-of select="libelle/label2"/--> </fo:block> </fo:table-cell> <fo:table-cell border-style="solid" padding="2pt" border-width="1pt" number-columns-spanned="2"> <fo:block font-weight="bold"> Service <!--xsl:value-of select="libelle/label2"/--> </fo:block> </fo:table-cell> </fo:table-row> </fo:block> <fo:block> <fo:table-row> <fo:table-cell border-style="solid" padding="2pt" border-width="1pt" number-columns-spanned="2"> <fo:block font-weight="bold"> Service <!--xsl:value-of select="libelle/label2"/--> </fo:block> </fo:table-cell> <fo:table-cell border-style="solid" padding="2pt" border-width="1pt" number-columns-spanned="2"> <fo:block font-weight="bold"> Service <!--xsl:value-of select="libelle/label2"/--> </fo:block> </fo:table-cell> <fo:table-cell border-style="solid" padding="2pt" border-width="1pt" number-columns-spanned="2"> <fo:block font-weight="bold"> Service <!--xsl:value-of select="libelle/label2"/--> </fo:block> </fo:table-cell> </fo:table-row> </fo:block> </fo:table-body> </fo:table> <!--/fo:block--> </xsl:template> </xsl:stylesheet> Merci à tous
Marsh Posté le 03-03-2006 à 12:31:22
Le texte à afficher qui contient des <br />, je le reformate pour remplacer les <br /> par <![CDATA[<br />]]>...Et ça marche
Bonjour à tous!
</fo:block>
</fo:flow>
</fo:page-sequence>
</fo:root>
</xsl:template>
<fo:table-body>
<fo:block>
<fo:table-row>
Service
</fo:block>
</fo:table-cell>
Service
</fo:block>
</fo:table-cell>
Service
</fo:block>
</fo:table-cell>
</fo:table-row>
</fo:block>
<fo:block>
<fo:table-row>
Service
</fo:block>
</fo:table-cell>
Service
</fo:block>
</fo:table-cell>
Service
</fo:block>
</fo:table-cell>
</fo:table-row>
</fo:block>
</fo:table-body>
</fo:table>
<!--/fo:block-->
</xsl:template>
</xsl:stylesheet>
Merci à tous
