VBS...lecture ligne à ligne - VB/VBA/VBS - Programmation
Marsh Posté le 01-02-2006 à 20:56:03
bah tu lui fait lire le fichier ligne a ligne via une boucle (while .... wend)
tu mets un compteur qui incrémente chaque ligne.
si la valeur est paire (ligne 2 ...) alors rajouter "," (tu stock tout dans une varible temporaire style tmp_str = line imput & "," ) apres tu rajoute sle bout de phrase.
le tout jusqu'a la fin du fichier. et pi voila
Marsh Posté le 01-02-2006 à 14:25:52
Salut à tous!
J'ai un pb dans un fichier texte. J'ai testé de faire la manipulation voulue en batch mais je bloque...je pense que VBS sera plus puissant pour faire cela mais je suis completement newbies...Voici l'exemple du fichier texte que j'ai appelé toto.txt
"PRODUIT","0101"
"00911550150","4075001","TEST","SU","106-22-9","203-375-0","","","","","1"
"0","","",""
"00911550150","1360203","ESSAI","SU","112-31-2","203-957-4","","","","","1"
"0","","",""
"00911550150","1366501","TEST-ESSAI","SU","112-54-9","203-983-6","","","","","1"
"0","","",""
En sachant que je dois faire cet manip sur plusieurs fichiers différentes (nombre de lignes change sur chaque fichier) mais de structure identiques, c'est à dire que la premiere ligne sera toujours "PRODUIT","0101" et qu'il ne faut rien ajouter derriere. J'aimerais arriver à un résultat du type:
"PRODUCT","0101"
"00911550150","4075001","6-OCTEN-1-OL,3,7-DIMETHYL-","SU","106-22-9","203-375-0","","","","","1","0","","",""
"00911550150","1360203","DECANAL","SU","112-31-2","203-957-4","","","","","1","0","","",""
"00911550150","1366501","DODECANAL","SU","112-54-9","203-983-6","","","","","1","0","","",""
Il faut donc ajouter une "," a la fin de la ligne 1 et mettre a la suite la ligne 2...
J'ai testé plusieurs chose mais je suis bloqué... Pouvez m'aider ???......
Merci d'avance
Fab
