pb sur comparaison de 2 fichier text
pb sur comparaison de 2 fichier text - VB/VBA/VBS - Programmation
Marsh Posté le 16-07-2004 à 16:50:28
voici mon code j'ai un probleme car il reste dans ma 2éme boucle il ne ve pas sortir pouvez vous m'aider
dim nom, prenom, classe, total
dim nom1, prenom1, classe1, total1
dim pb
set fs = CreateObject("Scripting.FileSystemObject" )
set ff = fs.GetFile("Comptes1.txt" )
set t = ff.OpenAsTextStream(1, -2)
do
 q = t.ReadLine   'Read a line in the file, put the line in s
    fields = Split(q, ";" )  'Separate the fields and put them in the array fields
 nom1 = trim(fields(0))
    prenom1 = trim(fields(1))
     classe1 = trim(fields(2))
    'wscript.echo ("NOM 1 " + nom1)
    'wscript.echo ("PRENOM 1 " +prenom1)
    'wscript.echo ("Statuts 1 " +classe1)
 total1=nom1+prenom1
set fso = CreateObject("Scripting.FileSystemObject" )
set f = fso.GetFile("Comptes2.txt" )
set ts = f.OpenAsTextStream(1, -2)
do
 s = ts.ReadLine   'Read a line in the file, put the line in s
    fields = Split(s, ";" )  'Separate the fields and put them in the array fields
 nom = trim(fields(0))
    prenom = trim(fields(1))
     classe = trim(fields(2))
    'wscript.echo ("NOM 2 " + nom)
    'wscript.echo ("PRENOM 2 " +prenom)
    'wscript.echo ("Statuts 2 " +classe)
 total=nom+prenom
 if (total1 = total) then
  pb="sortir"
  wscript.echo ("bon "+total)
 Else
  pb="delete"
  wscript.echo ("Pas bon " +total +" et "+total1)
 End If
loop While ((Not ts.AtEndOfStream) Or (Not pb="sortir" ))
loop While (Not t.AtEndOfStream)
Marsh Posté le 16-07-2004 à 16:56:38
c'est pas
loop While ((Not ts.AtEndOfStream) And (Not pb="sortir" ))
plutot que
"I wonder if the internal negative pressure in self pumping toothpaste tubes is adjusted for different market altitudes." John Carmack
Marsh Posté le 16-07-2004 à 17:09:18
merci c'etait bien ca mon erreur
