MySQL commands: Note that all text commands must be first on line and end with ';' help (\h) Display this help. ? (\?) Synonym for `help'. clear (\c) Clear command. connect (\r) Reconnect to the server. Optional arguments are db and host. edit (\e) Edit command with $EDITOR. ego (\G) Send command to mysql server, display result vertically. exit (\q) Exit mysql. Same as quit. go (\g) Send command to mysql server. nopager (\n) Disable pager, print to stdout. notee (\t) Don't write into outfile. pager (\P) Set PAGER [to_pager]. Print the query results via PAGER. print (\p) Print current command. quit (\q) Quit mysql. rehash (\#) Rebuild completion hash. source (\.) Execute a SQL script file. Takes a file name as an argument. status (\s) Get status information from the server. tee (\T) Set outfile [to_outfile]. Append everything into given outfile. use (\u) Use another database. Takes database name as argument.
Marsh Posté le 07-02-2003 à 18:37:35
Sous Mysql? Sous oracle c'est @monfichier mais sous mysql?
CHaiCA
Message édité par chaica le 07-02-2003 à 19:07:05
