aws-script: tailoring this hack a bit - how to - PHP - Programmation
Marsh Posté le 09-07-2005 à 03:33:16
i z'on pas de forums dédiés au zétazunis
Marsh Posté le 09-07-2005 à 12:16:30
fo croire que non ...
hi guy, we're french here, is there any programation forums in your language ?
PS : oui mon anglais est nul je sais
Marsh Posté le 09-07-2005 à 12:32:17
hi guy, we're french here, is there any development forum into your language ?
Marsh Posté le 09-07-2005 à 12:44:27
Vous pigez pas l'anglais ou quoi ?
Si vous avez la réponse donnez-la lui
Marsh Posté le 09-07-2005 à 02:38:27
hello g dáy here - hello all
[i am back again]
today again with a question regarding amazon web services - created with a great script http://www.mrrat.com/aws/ ;-)
- i want to have a special front-end view - and behaviour - of the front end of the script. see a sample of examples - here at http://www.downintheflood.com/ItemList/
http://www.downintheflood.com/Item [...] emList.php
item List Example 1
Item List Example 2
Item List Example 3
Item List Example 4
the sources are available too -
alltogheter: i grabbed the APF4 script on http://www.Mrrat.com
i had a first look at the script: http://mrrat.com/aws/docs_apf_beginners.html#Edit
i uploaded the script to the server and now it works fine.
What I wanted to do was show a selection of hand-picked titles on the main page of the book store. The script works great, now back to the [B]frontendhack[/B] that i want to create....with the script. [see an example here http://www.downintheflood.com/ItemList/ ]
http://www.absolutefreebies.com/ph [...] f9f6e68e5c
the guy created a kind of a frontendhack see - http://www.downintheflood.com/ItemList/
well - the guy here worked out some front-end scripts that show 40 to 50 items.
but i am not sure if we can do this in a way that the books that the script can show can be changed. There must be a idea how we can make the script showing new books with ease.
How can we solve this?
how can we hack the script that it does not show only books out of the national geographic-series? Can we hack this so that we have an easy way to edit the 50 items the script shows? is this possible - that would be great
any idea and input would be greatly appreciated,
thx
metabo
