register_globals qui n'en fait qu'a sa tête
register_globals qui n'en fait qu'a sa tête - PHP - Programmation
Marsh Posté le 10-07-2003 à 11:32:28
comprend pas
  1. ; This file is different from the php.ini-dist file in the fact that it features
  2. ; different values for several directives, in order to improve performance, while
  3. ; possibly breaking compatibility with the standard out-of-the-box behavior of
  4. ; PHP 3.  Please make sure you read what's different, and modify your scripts
  5. ; accordingly, if you decide to use this file instead.
  6. ;
  7. ; - register_globals = Off         [Security, Performance]
  8. register_globals = On
  9. ;     Global variables are no longer registered for input data (POST, GET, cookies,
  10. ;     environment and other server variables).  Instead of using $foo, you must use
  11. ;     you can use $_REQUEST["foo"] (includes any variable that arrives through the
  12. ;     request, namely, POST, GET and cookie variables), or use one of the specific
  13. ;     $_GET["foo"], $_POST["foo"], $_COOKIE["foo"] or $_FILES["foo"], depending
  14. ;     on where the input originates.  Also, you can look at the
  15. ;     import_request_variables() function.
  16. ;     Note that register_globals is going to be depracated (i.e., turned off by
  17. ;     default) in the next version of PHP, because it often leads to security bugs.
  18. ;     Read http://php.net/manual/en/security.registerglobals.php for further
  19. ;     information.
  1. <html>
  2. <head>
  3.   <title>f</title>
  4.   <meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1">
  5.   <meta name="GENERATOR" content="Quanta Plus">
  6. </head>
  7. <body>
  8.   <form action="truc.php" method="post">
  9.   <input type="text" name="truc">
  10.     <input type="submit">
  11.   </form>
  12. </body>
  13. </html>
  1. <?
  2. echo "$truc";
  3. ?>
  1. [Thu Jul 10 11:27:05 2003] [error] PHP Notice:  Undefined variable:  truc in /home/farib/public_html/truc.php on line 2
 [email]
Message édité par farib le 10-07-2003 à 11:33:25
Marsh Posté le 10-07-2003 à 12:00:29
farib a écrit :
  1. <?
  2. echo $_POST['truc'];
  3. ?>
Marsh Posté le 10-07-2003 à 12:01:56
Ui mais ce qu'il veut dire c'est que même avec register_globals à On, il récupère pas la valeur.
farib : essaie on en minuscules. Pis restarte ton serveur Apache aussi (ch'ais pas si ça change quelque chose, mais bon).
Everyone thinks of changing the world, but no one thinks of changing himself  |  It is the peculiar quality of a fool to perceive the faults of others and to forget his own  |  Early clumsiness is not a verdict, it’s an essential ingredient.
Marsh Posté le 10-07-2003 à 13:18:24
okay, j'ai pas compris mais, par défaut avec l'install de la slack 9
j'ai php.ini, php.ini-dist
je modifiais le register_globals de php.ini, ca faisait rien
par contre, j'ai utilisé le php.ini-dist et la ca a  marché
il doit y avoir d'autres directives dnas php.ini qui s'opposent a register_globals
Marsh Posté le 10-07-2003 à 14:11:23
C'est possible, ouais. De toute façon, fais bien gaffe parce qu'apparemment c'est deprecated et bientôt tu pourras pas le modifier. Donc autant t'habituer aux $_POST et tout l'bazar :D
Marsh Posté le 10-07-2003 à 15:03:49
je sais bien seulement c'est pour me greffer sur un systeme déja existant
Message édité par farib le 10-07-2003 à 15:03:59
Marsh Posté le 18-07-2003 à 07:51:59
il fo donc changer le register globals (on/off) dans le fichier php.ini-dist ok !!  :jap:
c vrai que pour le $_post, il va falloir que je m'habitue parce que au début je le faisait pas donc je suis obligé de changer toutes mes variables  :D  et puis si je le fé pas et que je tombe sur les dernieres versions de php  :sweat: g vu ce que ca faisait ...
la vie ne vaut rien, mais rien ne vaut la vie
Marsh Posté le 18-07-2003 à 08:20:20
ou se trouve php.ini-dist dans easyphp, parce que g pas réussi à trouver (meme en affichant tout les types de fichiers)
Marsh Posté le 18-07-2003 à 13:10:23
easyphp, c'est php.ini dans le dossier de windows. ("c:\windows\", "c:\winnt\" ou "c:\winnt40\" en général)
Message édité par omega2 le 18-07-2003 à 13:10:52
