Question sur les applets - Java - Programmation
Marsh Posté le 13-08-2003 à 07:24:14
Ça devrait t'aider :
http://groups.google.com/groups?hl [...] 0%26sa%3DN
Marsh Posté le 13-08-2003 à 18:13:04
Arf, tes deux liens ne fonctionnent pas chez moi.
Erreur 403 Forbidden :
Google
Error Forbidden
et puis un super long message d'erreur ...
Merci quand même.
Marsh Posté le 14-08-2003 à 13:14:24
| spiritous a écrit : Arf, tes deux liens ne fonctionnent pas chez moi. |
Marsh Posté le 14-08-2003 à 19:00:47
Ben c'est vrai ...
Voilà le message d'erreur exact que j'ai :
Google
Error
Forbidden
Your client does not have permission to get URL /groups?hl=fr&lr=&ie=UTF-8&threadm=722pdn%24nl57%40forums.borland.com&rnum=17&prev=/groups%3Fq%3Dtab%2Bjava%2Bjframe%2Bapplet%26hl%3Dfr%26lr%3D%26ie%3DUTF-8%26start%3D10%26sa%3DN from this server.(Client IP address: 213.224.83.38)
Please see Google's Terms of Service posted at http://www.google.com/terms_of_service.html
If you believe that you have received this response in error, please send email to forbidden@google.com. Before sending this email, however, please make sure to take a look at our Terms of Service (http://www.google.com/terms_of_service.html).In your email, please send us the entire code displayed below. Please also send us any information you may know about how you are performing your Google searches-- for example, "I'm using the Opera browser on Linux to do searches from home. My Internet access is through a dial-up account I have with the FooCorp ISP." or "I'm using the Konqueror browser on Linux to search from my job at myFoo.com. My machine's IP address is 10.20.30.40, but all of myFoo's web traffic goes through some kind of proxy server whose IP address is 10.11.12.13." (If you don't know any information like this, that's OK. But this kind of information can help us track down problems, so please tell us what you can.)
We will use all this information to diagnose the problem, and we'll hopefully have you back up and searching with Google again quickly!
Please note that although we read all the email we receive, we are not always able to send a personal response to each and every email. So don't despair if you don't hear back from us!
Also note that if you do not send us the entire code below, we will not be able to help you.
Best wishes,
The Google Team
AD87vurV4FMmYWJ6ejIyAAJhR0VUIC9ncm91cHM_aGw9ZnImb
HI9JmllPVVURi04JnRocmVhZG09NzIycGRuJTI0bmw1NyU0MG
ZvcnVtcy5ib3JsYW5kLmNvbSZybnVtPTE3JnByZXY9L2dyb3V
wcyUzRnElM0R0YWIlMkJqYXZhJTJCamZyYW1lJTJCYXBwbGV0
JTI2aGwlM0RmciUyNmxyJTNEJTI2aWUlM0RVVEYtOCUyNnN0Y
XJ0JTNEMTAlMjZzYSUzRE4gSFRUUC8xLjENCkhvc3Q6IGdyb3
Vwcy5nb29nbGUuY29tDQpBY2NlcHQ6ICovKg0KUmVmZXJlcjo
gaHR0cDovL2ZvcnVtLmhhcmR3YXJlLmZyL2ZvcnVtMi5waHAz
P3Bvc3Q9NDA0NTkmY2F0PTEwJmNvbmZpZz0maW50ZXJmYWNlP
SZjYWNoZT0mc29uZGFnZT0mb3dudG9waWM9JnA9MSZ0cmFzaD
0mc3ViY2F0PTM5MA0KQWNjZXB0LUxhbmd1YWdlOiBmcg0KVXN
lci1BZ2VudDogTW96aWxsYS80LjAgKGNvbXBhdGlibGU7IE1T
SUUgNS41OyBXaW5kb3dzIDk4OyBXaW4gOXggNC45MCkNClgtR
m9yd2FyZGVkLUZvcjogMjEzLjIyNC4yMDIuMzgNClZpYTogMS
4wIG5jYXNzZTAxIChOZXRDYWNoZSBOZXRBcHAvNS4zLjFSMyk
NCkNvbm5lY3Rpb246IEtlZXAtYWxpdmUNClgtVXNlci1JcDog
MjEzLjIyNC44My4zOA0KWC1HUjogMDAwMDAwMDAwMDAwM2NiZ
A0KZJbOZw==
Marsh Posté le 15-08-2003 à 10:16:12
bin soit ton ip a été banné parce que tu (ou qqun utilisant ton ip) a fait le con, soit c'est une erreur de google
dans ce cas envoie un mail à google (voir msg)
Marsh Posté le 13-08-2003 à 03:04:56
Voilà, j'ai fait une petite interface graphique et mon problème est le suivant : quand je la met dans une JFrame ca marche très bien mais quand je la met sous forme d'applet dans une page web
la touche tab (pour passer d'un composant à un autre) ne fonctionne plus.
Alors ma question : c'est normal ? et si oui, est ce qu'il y a moyen de faire en sorte que la touche tab (re)fonctionne ?
