Probleme sur la fonction get pour un Httprequest - Java - Programmation
Marsh Posté le 06-04-2014 à 22:33:03
ce httprequest ?
https://github.com/kevinsawicki/http-request
Sinon d'ab j'utilise plutôt httpComponents de Apache:
http://hc.apache.org/
Marsh Posté le 06-04-2014 à 22:57:11
import java.io.IOException;
import java.io.InputStream;
import java.io.UnsupportedEncodingException;
import java.net.HttpURLConnection;
import java.net.URL;
import java.net.URLConnection;
import org.apache.http.HttpResponse;
import org.apache.http.client.methods.HttpGet;
import org.apache.http.client.methods.HttpPost;
import org.apache.http.client.params.ClientPNames;
import org.apache.http.client.params.CookiePolicy;
import org.apache.http.entity.StringEntity;
import org.apache.http.impl.client.DefaultHttpClient;
import org.apache.http.params.BasicHttpParams;
import org.apache.http.params.HttpConnectionParams;
import org.apache.http.params.HttpParams;
import org.apache.http.protocol.BasicHttpContext;
import org.apache.http.protocol.HttpContext;
import org.apache.http.util.EntityUtils;
import org.json.JSONObject;
import android.util.Log;
public class HttpRequest{
DefaultHttpClient httpClient;
HttpContext localContext;
private String ret;
HttpResponse response = null;
HttpPost httpPost = null;
HttpGet httpGet = null;
public HttpRequest(){
HttpParams myParams = new BasicHttpParams();
HttpConnectionParams.setConnectionTimeout(myParams, 10000);
HttpConnectionParams.setSoTimeout(myParams, 10000);
httpClient = new DefaultHttpClient(myParams);
localContext = new BasicHttpContext();
public void clearCookies() {
httpClient.getCookieStore().clear();
public void abort() {
try {
if (httpClient != null) {
System.out.println("Abort." );
httpPost.abort();
} catch (Exception e) {
System.out.println("Your App Name Here" + e);
public String sendPost(String url, String data) {
return sendPost(url, data, null);
public String sendJSONPost(String url, JSONObject data) {
return sendPost(url, data.toString(), "application/json" );
public String sendPost(String url, String data, String contentType) {
ret = null;
httpClient.getParams().setParameter(ClientPNames.COOKIE_POLICY, CookiePolicy.RFC_2109);
httpPost = new HttpPost(url);
response = null;
StringEntity tmp = null;
Log.d("Your App Name Here", "Setting httpPost headers" );
httpPost.setHeader("User-Agent", "SET YOUR USER AGENT STRING HERE" );
httpPost.setHeader("Accept", "text/html,application/xml,application/xhtml+xml,text/html;q=0.9,text/plain;q=0.8,image/png,*/*;q=0.5" );
if (contentType != null) {
httpPost.setHeader("Content-Type", contentType);
} else {
httpPost.setHeader("Content-Type", "application/x-www-form-urlencoded" );
try {
tmp = new StringEntity(data,"UTF-8" );
} catch (UnsupportedEncodingException e) {
Log.e("Your App Name Here", "HttpUtils : UnsupportedEncodingException : "+e);
httpPost.setEntity(tmp);
Log.d("Your App Name Here", url + "?" + data);
try {
response = httpClient.execute(httpPost,localContext);
if (response != null) {
ret = EntityUtils.toString(response.getEntity());
Log.e("Your App Name Here", "HttpUtils: " + e);
Log.d("Your App Name Here", "Returning value:" + ret);
return ret;
public String sendGet(String url) {
httpGet = new HttpGet(url);
try {
response = httpClient.execute(httpGet);
Log.e("Your App Name Here", e.getMessage());
//int status = response.getStatusLine().getStatusCode();
// we assume that the response body contains the error message
try {
} catch (IOException e) {
return ret;
public InputStream getHttpStream(String urlString) throws IOException {
InputStream in = null;
int response = -1;
URL url = new URL(urlString);
URLConnection conn = url.openConnection();
if (!(conn instanceof HttpURLConnection))
throw new IOException("Not an HTTP connection" );
try{
HttpURLConnection httpConn = (HttpURLConnection) conn;
httpConn.setAllowUserInteraction(false);
httpConn.setInstanceFollowRedirects(true);
httpConn.setRequestMethod("GET" );
httpConn.connect();
response = httpConn.getResponseCode();
if (response == HttpURLConnection.HTTP_OK) {
in = httpConn.getInputStream();
throw new IOException("Error connecting" );
} // end try-catch
return in;
c'est celui-la
Marsh Posté le 06-04-2014 à 19:34:05
Hey, J'ai d'abord télécharger une fonction Httprequest pour effectuer des GET et des PUT. les Put j'ai aucun soucis pour les effectuer mais alors les get cela ne veut pas. Donc j'ai besoin d'un peu d'aide pour effectuer cette tâche
![;) ;)](https://forum-images.hardware.fr/icones/wink.gif)
j'ai écrit ça comme programme.
public void getData(){
String fullUrl="http://doc.google.com";
HttpRequest Req= new HttpRequest();
String a=Req.sendGet(fullUrl);
EditText get = (EditText)findViewById(R.id.arr);
get.setText(a);
le sendGet est
try {
try {
return ret;
Par contre il y a une fonction avec le GET mais je ne sais pas si celui-la sert à qqc dans la réalisation du GET
int response = -1;
try{
httpConn.connect();
} // end try-catch
return in;
Merci d'avance
Message édité par ptitgwend le 06-04-2014 à 19:39:17
