Pourquoi ma frame est tout blanche????
Pourquoi ma frame est tout blanche???? - Java - Programmation
Marsh Posté le 11-12-2002 à 20:02:35
Voila le code
Frame.java
"import java.awt.*;
import java.awt.event.*;
import javax.swing.*;
public class Frame extends JFrame {
  private JPanel contentPane;
  private JPanel jPanel1 = new JPanel();
  private JLabel jLabel1 = new JLabel();
  private JPanel jPanel2 = new JPanel();
  private JButton jButton1 = new JButton();
  private JButton jButton2 = new JButton();
  private JPanel jPanel3 = new JPanel();
  private JButton jButton3 = new JButton();
  private JPanel jPanel4 = new JPanel();
  private JButton jButton4 = new JButton();
  private JButton jButton5 = new JButton();
  private JButton jButton6 = new JButton();
  private JPanel jPanel5 = new JPanel();
  private JButton jButton7 = new JButton();
  private GridBagLayout gridBagLayout1 = new GridBagLayout();
  private GridBagLayout gridBagLayout2 = new GridBagLayout();
  private GridBagLayout gridBagLayout3 = new GridBagLayout();
  private GridBagLayout gridBagLayout4 = new GridBagLayout();
  private GridBagLayout gridBagLayout5 = new GridBagLayout();
  public Frame() {
    enableEvents(AWTEvent.WINDOW_EVENT_MASK);
    try {
      jbInit();
    catch(Exception e) {
      e.printStackTrace();
  private void jbInit() throws Exception  {
    contentPane = (JPanel) this.getContentPane();
    this.setSize(new Dimension(553, 435));
    this.setTitle("GESTION" );
    jPanel1.setLayout(gridBagLayout5);
    jLabel1.setFont(new java.awt.Font("Dialog", 1, 14));
    jLabel1.setHorizontalAlignment(SwingConstants.CENTER);
    jLabel1.setText("Bienvenue sur GESTION" );
    jPanel2.setLayout(gridBagLayout1);
    jPanel2.setFont(new java.awt.Font("Dialog", 1, 14));
    jPanel2.setBorder(BorderFactory.createTitledBorder(BorderFactory.createLineBorder(Color.blue), "x1" ));
    jPanel3.setBorder(BorderFactory.createTitledBorder(BorderFactory.createLineBorder(Color.blue), "x2" ));
    jPanel3.setLayout(gridBagLayout4);
    jPanel4.setBorder(BorderFactory.createTitledBorder(BorderFactory.createLineBorder(Color.blue), "x3" ));
    jPanel5.setBorder(BorderFactory.createTitledBorder(BorderFactory.createLineBorder(Color.red), "x4" ));
    jPanel5.setLayout(gridBagLayout3);
    jPanel4.setLayout(gridBagLayout2);
    jButton1.setText("xxxx" );
    jButton2.setText("xxxxx" );
    jButton3.setText("xxxx" );
    jButton4.setText("xxxxx" );
    jButton5.setText("xxxx" );
    jButton6.setText("xxxxx" );
    jButton7.setText("xxxx" );
    jPanel1.add(jPanel2,  new GridBagConstraints(0, 1, 1, 1, 1.0, 1.0
            ,GridBagConstraints.CENTER, GridBagConstraints.BOTH, new Insets(18, 35, 26, 0), 0, 0));
    jPanel2.add(jButton1,  new GridBagConstraints(0, 0, 1, 1, 0.0, 0.0
            ,GridBagConstraints.CENTER, GridBagConstraints.NONE, new Insets(18, 23, 0, 24), 33, -2));
    jPanel2.add(jButton2,  new GridBagConstraints(0, 1, 1, 1, 0.0, 0.0
            ,GridBagConstraints.CENTER, GridBagConstraints.NONE, new Insets(22, 23, 42, 24), 35, -2));
    jPanel1.add(jPanel3,  new GridBagConstraints(0, 2, 1, 1, 1.0, 1.0
            ,GridBagConstraints.CENTER, GridBagConstraints.BOTH, new Insets(16, 35, 82, 0), 0, 0));
    jPanel3.add(jButton3,  new GridBagConstraints(0, 0, 1, 1, 0.0, 0.0
            ,GridBagConstraints.CENTER, GridBagConstraints.NONE, new Insets(5, 54, 8, 54), 0, 0));
    jPanel1.add(jPanel4,  new GridBagConstraints(1, 1, 1, 1, 1.0, 1.0
            ,GridBagConstraints.CENTER, GridBagConstraints.BOTH, new Insets(18, 53, 0, 26), 0, 0));
    jPanel4.add(jButton5,  new GridBagConstraints(0, 1, 1, 1, 0.0, 0.0
            ,GridBagConstraints.CENTER, GridBagConstraints.NONE, new Insets(22, 37, 0, 38), 32, 0));
    jPanel4.add(jButton4,  new GridBagConstraints(0, 0, 1, 1, 0.0, 0.0
            ,GridBagConstraints.CENTER, GridBagConstraints.NONE, new Insets(7, 37, 0, 38), 24, 0));
    jPanel4.add(jButton6,  new GridBagConstraints(0, 2, 1, 1, 0.0, 0.0
            ,GridBagConstraints.CENTER, GridBagConstraints.NONE, new Insets(22, 37, 26, 38), 10, 0));
    jPanel1.add(jPanel5,  new GridBagConstraints(1, 2, 1, 1, 1.0, 1.0
            ,GridBagConstraints.CENTER, GridBagConstraints.BOTH, new Insets(16, 53, 82, 26), 0, 0));
    jPanel5.add(jButton7,  new GridBagConstraints(0, 0, 1, 1, 0.0, 0.0
            ,GridBagConstraints.CENTER, GridBagConstraints.NONE, new Insets(5, 39, 10, 30), 18, -2));
    jPanel1.add(jLabel1, new GridBagConstraints(0, 0, 2, 1, 0.0, 0.0
            ,GridBagConstraints.CENTER, GridBagConstraints.NONE, new Insets(18, 95, 0, 76), 208, 31));
    contentPane.add(jPanel1, BorderLayout.CENTER);
  //Overridden so we can exit when window is closed
  protected void processWindowEvent(WindowEvent e) {
    super.processWindowEvent(e);
    if (e.getID() == WindowEvent.WINDOW_CLOSING) {
      System.exit(0);
Et Application.java
"import javax.swing.UIManager;
import java.awt.*;
public class Application {
  private boolean packFrame = false;
  public Application() {
    Frame1 frame = new Frame1();
    if (packFrame) {
      frame.pack();
    else {
      frame.validate();
    Dimension screenSize = Toolkit.getDefaultToolkit().getScreenSize();
    Dimension frameSize = frame.getSize();
    if (frameSize.height > screenSize.height) {
      frameSize.height = screenSize.height;
    if (frameSize.width > screenSize.width) {
      frameSize.width = screenSize.width;
    frame.setLocation((screenSize.width - frameSize.width) / 2, (screenSize.height - frameSize.height) / 2);
    frame.setVisible(true);
  public static void main(String[] args) {
    try {
      UIManager.setLookAndFeel(UIManager.getSystemLookAndFeelClassName());
    new Application();
J'ai JDK 1.4.1 ...
Je vois pas trop d'où ça peut venir ...
Au fait g laisser tomber JBuilder car importer des librairies de 30meg... ça le fait pas  :D
Marsh Posté le 11-12-2002 à 20:07:59
C'est bon juste un probleme de configuration de Runtime de JCreator ...
Mais quand j'importerai mes sources sous Linux, devrai-je faire une manip pour configurer ce Runtime pour lancer mon application ? Sous Unix on se casse moins la tête ?
Shogun (ex-supporter de JBuil....)
Marsh Posté le 11-12-2002 à 20:11:06
Derniere question ....:ange:
ça sert a quoi le runtime ???
