Aide code java.
Aide code java. - Java - Programmation
Marsh Posté le 23-04-2004 à 15:23:01
J'ai récupéré un code issue d'un fichier. Cependant je ne suis pas sur que ce soit du java...si oui est ce possible que je puisse l'insérer dans une page web ?
le code :
  1. #ILOG Views Java 1.0
  2. #Reader : ilog.views.io.IlvGrapherReader
  3. ilog.views.IlvGrapher {
  4.   namedProperties [
  5.     DEF obj_0 ilog.views.graphlayout.tree.IlvTreeLayoutGrapherProperty {
  6.       name "LayoutProperty%IlvTreeLayout$2"
  7.       layoutOfConnectedComponentsEnabled true
  8.       flowDirection "Bottom"
  9.       layoutMode "LEVEL"
  10.       connectorStyle "EVENLY_SPACED_PINS"
  11.        } ,
  12.     DEF obj_1 ilog.views.graphlayout.internalutil.IlvLayoutParamControlBlock {
  13.       name "__graphLayoutControlBlock"
  14.       layouts [ "LayoutProperty%IlvHierarchicalLayout$1" , "LayoutProperty%IlvTreeLayout$2" , "@end" ]
  15.       preferredLayout "LayoutProperty%IlvTreeLayout$2"
  16.        } ,
  17.     DEF obj_2 ilog.views.graphlayout.hierarchical.IlvHierarchicalLayoutGrapherProperty {
  18.       name "LayoutProperty%IlvHierarchicalLayout$1"
  19.       allowedTime 100000000
  20.       layoutOfConnectedComponentsEnabled true
  21.       connectorStyle "EVENLY_SPACED_PINS"
  22.        }
  23.
  24.    ] Layers [
  25.     ilog.views.IlvManagerLayer {
  26.       index 0
  27.       visible true
  28.       selectable true
  29.       elements [ DEF obj_3 ilog.views.graphic.IlvGraphicSet {
  30.           name "142.9.101.90"
  31.           toolTip " 142.9.101.90, 142.9.101.90. Device Type : 2650."
  32.           objects [ DEF obj_4 ilog.views.graphic.IlvReliefLabel {
  33.               name "142.9.101.90"
  34.               foreground 0 0 0
  35.               rectangle 6.489538E-6 426.6607 85.0 50.0
  36.               radius 0
  37.               background 0 210 45
  38.               flags 6
  39.               thickness 3
  40.               font DEF font_0 "Dialog" PLAIN 12
  41.               label ""
  42.                } ,
  43.             DEF obj_5 ilog.views.graphic.IlvIcon {
  44.               rectangle 21.75 1.0 44.0 44.0
  45.               transform 1.0 0.0 0.0 1.0 -0.4999935104619908 425.66070556640625
  46.                } ,
  47.             DEF obj_6 ilog.views.graphic.IlvZoomableLabel {
  48.               transform 1.0 0.0 0.0 1.0 6.489538009191165E-6 426.66070556640625
  49.               font USE font_0
  50.               label "142.9.101.90"
  51.               flags 2149
  52.               strokeColor 0 0 0
  53.               fillColor 0 0 0
  54.               justification 1
  55.                }
  56.
  57.            ]
  58.           editable false
  59.           gnode true
  60.            } ,
  61.         DEF obj_7 ilog.views.graphic.IlvGraphicSet {
  62.           name "142.9.101.89"
  63.           toolTip " 142.9.101.89, 142.9.101.89. Device Type : 2824."
  64.           objects [ DEF obj_8 ilog.views.graphic.IlvReliefLabel {
  65.               name "142.9.101.89"
  66.               foreground 0 0 0
  67.               rectangle 0.0 525.2857 85.0 50.0
  68.               radius 0
  69.               background 0 210 45
  70.               flags 6
  71.               thickness 3
  72.               font USE font_0
  73.               label ""
  74.                } ,
  75.             DEF obj_9 ilog.views.graphic.IlvIcon {
  76.               rectangle 21.75 1.0 44.0 44.0
  77.               transform 1.0 0.0 0.0 1.0 -0.5 524.2857055664062
  78.                } ,
  79.             DEF obj_10 ilog.views.graphic.IlvZoomableLabel {
  80.               transform 1.0 0.0 0.0 1.0 0.0 525.2857055664062
  81.               font USE font_0
  82.               label "142.9.101.89"
  83.               flags 2149
  84.               strokeColor 0 0 0
  85.               fillColor 0 0 0
  86.               justification 1
  87.                }
  88.
  89.            ]
  90.           editable false
  91.           gnode true
  92.            } ,
  93.         DEF obj_11 ilog.views.graphic.IlvGraphicSet {
  94.           name "28680"
  95.           objects [ DEF obj_12 ilog.views.graphic.IlvShadowRectangle {
  96.               name "28680"
  97.               foreground 0 0 0
  98.               rectangle 298.75 619.5982 50.0 50.0
  99.               radius 0
  100.               background 0 0 255
  101.               flags 6
  102.               thickness 8.0
  103.               shadowPosition 10
  104.                }
  105.
  106.            ]
  107.           editable false
  108.           gnode true
  109.            } ,
  110.         DEF obj_13 ilog.views.graphic.IlvGraphicSet {
  111.           name "142.9.101.81"
  112.           toolTip " 142.9.101.81, 142.9.101.81. Device Type : 2512."
  113.           objects [ DEF obj_14 ilog.views.graphic.IlvReliefLabel {
  114.               name "142.9.101.81"
  115.               foreground 0 0 0
  116.               rectangle 281.25 722.5357 85.0 50.0
  117.               radius 0
  118.               background 0 210 45
  119.               flags 6
  120.               thickness 3
  121.               font USE font_0
  122.               label ""
  123.                } ,
  124.             DEF obj_15 ilog.views.graphic.IlvIcon {
  125.               rectangle 21.75 1.0 44.0 44.0
  126.               transform 1.0 0.0 0.0 1.0 280.75 721.5357055664062
  127.                } ,
  128.             DEF obj_16 ilog.views.graphic.IlvZoomableLabel {
  129.               transform 1.0 0.0 0.0 1.0 281.25 722.5357055664062
  130.               font USE font_0
  131.               label "142.9.101.81"
  132.               flags 2149
  133.               strokeColor 0 0 0
  134.               fillColor 0 0 0
  135.               justification 1
  136.                }
  137.
  138.            ]
  139.           editable false
  140.           gnode true
  141.            } ,
  142.         DEF obj_17 ilog.views.graphic.IlvGraphicSet {
  143.           name "142.9.101.83"
  144.           toolTip " 142.9.101.83, 142.9.101.83. Device Type : 2512."
  145.           objects [ DEF obj_18 ilog.views.graphic.IlvReliefLabel {
  146.               name "142.9.101.83"
  147.               foreground 0 0 0
  148.               rectangle 218.75 821.1607 85.0 50.0
  149.               radius 0
  150.               background 0 210 45
  151.               flags 6
  152.               thickness 3
  153.               font USE font_0
  154.               label ""
  155.                } ,
  156.             DEF obj_19 ilog.views.graphic.IlvIcon {
  157.               rectangle 21.75 1.0 44.0 44.0
  158.               transform 1.0 0.0 0.0 1.0 218.25 820.1607360839844
  159.                } ,
  160.             DEF obj_20 ilog.views.graphic.IlvZoomableLabel {
  161.               transform 1.0 0.0 0.0 1.0 218.75 821.1607360839844
  162.               font USE font_0
  163.               label "142.9.101.83"
  164.               flags 2149
  165.               strokeColor 0 0 0
  166.               fillColor 0 0 0
  167.               justification 1
  168.                }
  169.
  170.            ]
  171.           editable false
  172.           gnode true
  173.            } ,
  174.         DEF obj_21 ilog.views.graphic.IlvGraphicSet {
  175.           name "142.9.101.82"
  176.           toolTip " 142.9.101.82, 142.9.101.82. Device Type : 2512."
  177.           objects [ DEF obj_22 ilog.views.graphic.IlvReliefLabel {
  178.               name "142.9.101.82"
  179.               foreground 0 0 0
  180.               rectangle 343.75 821.1607 85.0 50.0
  181.               radius 0
  182.               background 0 210 45
  183.               flags 6
  184.               thickness 3
  185.               font USE font_0
  186.               label ""
  187.                } ,
  188.             DEF obj_23 ilog.views.graphic.IlvIcon {
  189.               rectangle 21.75 1.0 44.0 44.0
  190.               transform 1.0 0.0 0.0 1.0 343.25 820.1607055664062
  191.                } ,
  192.             DEF obj_24 ilog.views.graphic.IlvZoomableLabel {
  193.               transform 1.0 0.0 0.0 1.0 343.75 821.1607055664062
  194.               font USE font_0
  195.               label "142.9.101.82"
  196.               flags 2149
  197.               strokeColor 0 0 0
  198.               fillColor 0 0 0
  199.               justification 1
  200.                }
  201.
  202.            ]
  203.           editable false
  204.           gnode true
  205.            } ,
  206.         DEF obj_25 ilog.views.graphic.IlvGraphicSet {
  207.           name "142.9.101.95"
  208.           toolTip " 142.9.101.95, 142.9.101.95. Device Type : 2524."
  209.           objects [ DEF obj_26 ilog.views.graphic.IlvReliefLabel {
  210.               name "142.9.101.95"
  211.               foreground 0 0 0
  212.               rectangle -281.25 623.9107 85.0 50.0
  213.               radius 0
  214.               background 0 210 45
  215.               flags 6
  216.               thickness 3
  217.               font USE font_0
  218.               label ""
  219.                } ,
  220.             DEF obj_27 ilog.views.graphic.IlvIcon {
  221.               rectangle 21.75 1.0 44.0 44.0
  222.               transform 1.0 0.0 0.0 1.0 -281.75 622.9107055664062
  223.                } ,
  224.             DEF obj_28 ilog.views.graphic.IlvZoomableLabel {
  225.               transform 1.0 0.0 0.0 1.0 -281.25 623.9107055664062
  226.               font USE font_0
  227.               label "142.9.101.95"
  228.               flags 2149
  229.               strokeColor 0 0 0
  230.               fillColor 0 0 0
  231.               justification 1
  232.                }
  233.
  234.            ]
  235.           editable false
  236.           gnode true
  237.            } ,
  238.         DEF obj_29 ilog.views.graphic.IlvGraphicSet {
  239.           name "142.9.101.91"
  240.           toolTip " 142.9.101.91, 142.9.101.91. Device Type : 2650."
  241.           objects [ DEF obj_30 ilog.views.graphic.IlvReliefLabel {
  242.               name "142.9.101.91"
  243.               foreground 0 0 0
  244.               rectangle -156.25 623.9107 85.0 50.0
  245.               radius 0
  246.               background 0 210 45
  247.               flags 6
  248.               thickness 3
  249.               font USE font_0
  250.               label ""
  251.                } ,
  252.             DEF obj_31 ilog.views.graphic.IlvIcon {
  253.               rectangle 21.75 1.0 44.0 44.0
  254.               transform 1.0 0.0 0.0 1.0 -156.75 622.9107055664062
  255.                } ,
  256.             DEF obj_32 ilog.views.graphic.IlvZoomableLabel {
  257.               transform 1.0 0.0 0.0 1.0 -156.25 623.9107055664062
  258.               font USE font_0
  259.               label "142.9.101.91"
  260.               flags 2149
  261.               strokeColor 0 0 0
  262.               fillColor 0 0 0
  263.               justification 1
  264.                }
  265.
  266.            ]
  267.           editable false
  268.           gnode true
  269.            } ,
  270.         DEF obj_33 ilog.views.graphic.IlvGraphicSet {
  271.           name "142.9.101.70"
  272.           toolTip " 142.9.101.70, 142.9.101.70. Device Type : 2524."
  273.           objects [ DEF obj_34 ilog.views.graphic.IlvReliefLabel {
  274.               name "142.9.101.70"
  275.               foreground 0 0 0
  276.               rectangle -468.75 722.5357 85.0 50.0
  277.               radius 0
  278.               background 0 210 45
  279.               flags 6
  280.               thickness 3
  281.               font USE font_0
  282.               label ""
  283.                } ,
  284.             DEF obj_35 ilog.views.graphic.IlvIcon {
  285.               rectangle 21.75 1.0 44.0 44.0
  286.               transform 1.0 0.0 0.0 1.0 -469.25 721.5357055664062
  287.                } ,
  288.             DEF obj_36 ilog.views.graphic.IlvZoomableLabel {
  289.               transform 1.0 0.0 0.0 1.0 -468.75 722.5357055664062
  290.               font USE font_0
  291.               label "142.9.101.70"
  292.               flags 2149
  293.               strokeColor 0 0 0
  294.               fillColor 0 0 0
  295.               justification 1
  296.                }
  297.
  298.            ]
  299.           editable false
  300.           gnode true
  301.            } ,
  302.         DEF obj_37 ilog.views.graphic.IlvGraphicSet {
  303.           name "142.9.101.88"
  304.           toolTip " 142.9.101.88, 142.9.101.88. Device Type : 2524."
  305.           objects [ DEF obj_38 ilog.views.graphic.IlvReliefLabel {
  306.               name "142.9.101.88"
  307.               foreground 0 0 0
  308.               rectangle 156.25 722.5357 85.0 50.0
  309.               radius 0
  310.               background 0 210 45
  311.               flags 6
  312.               thickness 3
  313.               font USE font_0
  314.               label ""
  315.                } ,
  316.             DEF obj_39 ilog.views.graphic.IlvIcon {
  317.               rectangle 21.75 1.0 44.0 44.0
  318.               transform 1.0 0.0 0.0 1.0 155.75 721.5357055664062
  319.                } ,
  320.             DEF obj_40 ilog.views.graphic.IlvZoomableLabel {
  321.               transform 1.0 0.0 0.0 1.0 156.25 722.5357055664062
  322.               font USE font_0
  323.               label "142.9.101.88"
  324.               flags 2149
  325.               strokeColor 0 0 0
  326.               fillColor 0 0 0
  327.               justification 1
  328.                }
  329.
  330.            ]
  331.           editable false
  332.           gnode true
  333.            } ,
  334.         DEF obj_41 ilog.views.graphic.IlvGraphicSet {
  335.           name "142.9.101.67"
  336.           toolTip " 142.9.101.67, 142.9.101.67. Device Type : 2524."
  337.           objects [ DEF obj_42 ilog.views.graphic.IlvReliefLabel {
  338.               name "142.9.101.67"
  339.               foreground 0 0 0
  340.               rectangle 31.25 722.5357 85.0 50.0
  341.               radius 0
  342.               background 0 210 45
  343.               flags 6
  344.               thickness 3
  345.               font USE font_0
  346.               label ""
  347.                } ,
  348.             DEF obj_43 ilog.views.graphic.IlvIcon {
  349.               rectangle 21.75 1.0 44.0 44.0
  350.               transform 1.0 0.0 0.0 1.0 30.75 721.5357055664062
  351.                } ,
  352.             DEF obj_44 ilog.views.graphic.IlvZoomableLabel {
  353.               transform 1.0 0.0 0.0 1.0 31.25 722.5357055664062
  354.               font USE font_0
  355.               label "142.9.101.67"
  356.               flags 2149
  357.               strokeColor 0 0 0
  358.               fillColor 0 0 0
  359.               justification 1
  360.                }
  361.
  362.            ]
  363.           editable false
  364.           gnode true
  365.            } ,
  366.         DEF obj_45 ilog.views.graphic.IlvGraphicSet {
  367.           name "142.9.101.68"
  368.           toolTip " 142.9.101.68, 142.9.101.68. Device Type : 2524."
  369.           objects [ DEF obj_46 ilog.views.graphic.IlvReliefLabel {
  370.               name "142.9.101.68"
  371.               foreground 0 0 0
  372.               rectangle -93.75 722.5357 85.0 50.0
  373.               radius 0
  374.               background 0 210 45
  375.               flags 6
  376.               thickness 3
  377.               font USE font_0
  378.               label ""
  379.                } ,
  380.             DEF obj_47 ilog.views.graphic.IlvIcon {
  381.               rectangle 21.75 1.0 44.0 44.0
  382.               transform 1.0 0.0 0.0 1.0 -94.25001525878906 721.5357055664062
  383.                } ,
  384.             DEF obj_48 ilog.views.graphic.IlvZoomableLabel {
  385.               transform 1.0 0.0 0.0 1.0 -93.75001525878906 722.5357055664062
  386.               font USE font_0
  387.               label "142.9.101.68"
  388.               flags 2149
  389.               strokeColor 0 0 0
  390.               fillColor 0 0 0
  391.               justification 1
  392.                }
  393.
  394.            ]
  395.           editable false
  396.           gnode true
  397.            } ,
  398.         DEF obj_49 ilog.views.graphic.IlvGraphicSet {
  399.           name "142.9.101.92"
  400.           toolTip " 142.9.101.92, 142.9.101.92. Device Type : 2524."
  401.           objects [ DEF obj_50 ilog.views.graphic.IlvReliefLabel {
  402.               name "142.9.101.92"
  403.               foreground 0 0 0
  404.               rectangle -218.75 722.5357 85.0 50.0
  405.               radius 0
  406.               background 0 210 45
  407.               flags 6
  408.               thickness 3
  409.               font USE font_0
  410.               label ""
  411.                } ,
  412.             DEF obj_51 ilog.views.graphic.IlvIcon {
  413.               rectangle 21.75 1.0 44.0 44.0
  414.               transform 1.0 0.0 0.0 1.0 -219.25 721.5357055664062
  415.                } ,
  416.             DEF obj_52 ilog.views.graphic.IlvZoomableLabel {
  417.               transform 1.0 0.0 0.0 1.0 -218.75 722.5357055664062
  418.               font USE font_0
  419.               label "142.9.101.92"
  420.               flags 2149
  421.               strokeColor 0 0 0
  422.               fillColor 0 0 0
  423.               justification 1
  424.                }
  425.
  426.            ]
  427.           editable false
  428.           gnode true
  429.            } ,
  430.         DEF obj_53 ilog.views.graphic.IlvGraphicSet {
  431.           name "142.9.101.93"
  432.           toolTip " 142.9.101.93, 142.9.101.93. Device Type : 2524."
  433.           objects [ DEF obj_54 ilog.views.graphic.IlvReliefLabel {
  434.               name "142.9.101.93"
  435.               foreground 0 0 0
  436.               rectangle -218.75 821.1607 85.0 50.0
  437.               radius 0
  438.               background 0 210 45
  439.               flags 6
  440.               thickness 3
  441.               font USE font_0
  442.               label ""
  443.                } ,
  444.             DEF obj_55 ilog.views.graphic.IlvIcon {
  445.               rectangle 21.75 1.0 44.0 44.0
  446.               transform 1.0 0.0 0.0 1.0 -219.25 820.1607055664062
  447.                } ,
  448.             DEF obj_56 ilog.views.graphic.IlvZoomableLabel {
  449.               transform 1.0 0.0 0.0 1.0 -218.75 821.1607055664062
  450.               font USE font_0
  451.               label "142.9.101.93"
  452.               flags 2149
  453.               strokeColor 0 0 0
  454.               fillColor 0 0 0
  455.               justification 1
  456.                }
  457.
  458.            ]
  459.           editable false
  460.           gnode true
  461.            } ,
  462.         DEF obj_57 ilog.views.graphic.IlvGraphicSet {
  463.           name "142.9.101.69"
  464.           toolTip " 142.9.101.69, 142.9.101.69. Device Type : 2524."
  465.           objects [ DEF obj_58 ilog.views.graphic.IlvReliefLabel {
  466.               name "142.9.101.69"
  467.               foreground 0 0 0
  468.               rectangle -343.75 722.5357 85.0 50.0
  469.               radius 0
  470.               background 0 210 45
  471.               flags 6
  472.               thickness 3
  473.               font USE font_0
  474.               label ""
  475.                } ,
  476.             DEF obj_59 ilog.views.graphic.IlvIcon {
  477.               rectangle 21.75 1.0 44.0 44.0
  478.               transform 1.0 0.0 0.0 1.0 -344.25 721.5357055664062
  479.                } ,
  480.             DEF obj_60 ilog.views.graphic.IlvZoomableLabel {
  481.               transform 1.0 0.0 0.0 1.0 -343.75 722.5357055664062
  482.               font USE font_0
  483.               label "142.9.101.69"
  484.               flags 2149
  485.               strokeColor 0 0 0
  486.               fillColor 0 0 0
  487.               justification 1
  488.                }
  489.
  490.            ]
  491.           editable false
  492.           gnode true
  493.            }
  494.
  495.        ]
  496.       } , ilog.views.IlvManagerLayer {
  497.       index 1
  498.       visible true
  499.       selectable true
  500.       elements [ DEF obj_61 ilog.views.graphic.IlvPolylineLinkImage {
  501.           name "23811"
  502.           toolTip "<html><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\">  Link from Port: 49 (1000Mbps) on 142.9.101.90</p><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\">  to Port: 3 (1000Mbps) on 142.9.101.89. </p><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\"></p></html>"
  503.           foreground 64 64 64
  504.           oriented false
  505.           from USE obj_3
  506.           to USE obj_7
  507.           lineWidth 2.0
  508.           points [  ]
  509.           moveable false
  510.           glink true
  511.            } ,
  512.         DEF obj_62 ilog.views.graphic.IlvPolylineLinkImage {
  513.           name "29443"
  514.           toolTip "<html><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\">  Link from Port: 6 (100Mbps) on 142.9.101.89</p><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\">  to Port: 142.9.101.89 (0Mbps) on 28680. </p><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\"></p></html>"
  515.           foreground 64 64 64
  516.           oriented false
  517.           from USE obj_7
  518.           to USE obj_11
  519.           lineWidth 2.0
  520.           points [  ]
  521.           moveable false
  522.           glink true
  523.            } ,
  524.         DEF obj_63 ilog.views.graphic.IlvPolylineLinkImage {
  525.           name "29699"
  526.           toolTip "<html><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\">  Link from Port: 142.9.101.81 (0Mbps) on 28680</p><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\">  to Port: 13 (100Mbps) on 142.9.101.81. </p><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\"></p></html>"
  527.           foreground 64 64 64
  528.           oriented false
  529.           from USE obj_11
  530.           to USE obj_13
  531.           lineWidth 2.0
  532.           points [  ]
  533.           moveable false
  534.           glink true
  535.            } ,
  536.         DEF obj_64 ilog.views.graphic.IlvPolylineLinkImage {
  537.           name "39939"
  538.           toolTip "<html><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\">  Link from Port: 14 (100Mbps) on 142.9.101.81</p><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\">  to Port: 13 (100Mbps) on 142.9.101.83. </p><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\"></p></html>"
  539.           foreground 64 64 64
  540.           oriented false
  541.           from USE obj_13
  542.           to USE obj_17
  543.           lineWidth 2.0
  544.           points [  ]
  545.           moveable false
  546.           glink true
  547.            } ,
  548.         DEF obj_65 ilog.views.graphic.IlvPolylineLinkImage {
  549.           name "34819"
  550.           toolTip "<html><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\">  Link from Port: 1 (100Mbps) on 142.9.101.81</p><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\">  to Port: 13 (100Mbps) on 142.9.101.82. </p><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\"></p></html>"
  551.           foreground 64 64 64
  552.           oriented false
  553.           from USE obj_13
  554.           to USE obj_21
  555.           lineWidth 2.0
  556.           points [  ]
  557.           moveable false
  558.           glink true
  559.            } ,
  560.         DEF obj_66 ilog.views.graphic.IlvPolylineLinkImage {
  561.           name "128003"
  562.           toolTip "<html><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\">  Link from Port: 21 (1000Mbps) on 142.9.101.89</p><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\">  to Port: 25 (1000Mbps) on 142.9.101.95. </p><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\"></p></html>"
  563.           foreground 64 64 64
  564.           oriented false
  565.           from USE obj_7
  566.           to USE obj_25
  567.           lineWidth 2.0
  568.           points [  ]
  569.           moveable false
  570.           glink true
  571.            } ,
  572.         DEF obj_67 ilog.views.graphic.IlvPolylineLinkImage {
  573.           name "54275"
  574.           toolTip "<html><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\">  Link from Port: 4 (1000Mbps) on 142.9.101.89</p><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\">  to Port: 49 (1000Mbps) on 142.9.101.91. </p><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\"></p></html>"
  575.           foreground 64 64 64
  576.           oriented false
  577.           from USE obj_7
  578.           to USE obj_29
  579.           lineWidth 2.0
  580.           points [  ]
  581.           moveable false
  582.           glink true
  583.            } ,
  584.         DEF obj_68 ilog.views.graphic.IlvPolylineLinkImage {
  585.           name "62467"
  586.           toolTip "<html><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\">  Link from Port: 2 (100Mbps) on 142.9.101.91</p><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\">  to Port: 26 (100Mbps) on 142.9.101.70. </p><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\"></p></html>"
  587.           foreground 64 64 64
  588.           oriented false
  589.           from USE obj_29
  590.           to USE obj_33
  591.           lineWidth 2.0
  592.           points [  ]
  593.           moveable false
  594.           glink true
  595.            } ,
  596.         DEF obj_69 ilog.views.graphic.IlvPolylineLinkImage {
  597.           name "95235"
  598.           toolTip "<html><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\">  Link from Port: 13 (100Mbps) on 142.9.101.91</p><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\">  to Port: 25 (100Mbps) on 142.9.101.88. </p><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\"></p></html>"
  599.           foreground 64 64 64
  600.           oriented false
  601.           from USE obj_29
  602.           to USE obj_37
  603.           lineWidth 2.0
  604.           points [  ]
  605.           moveable false
  606.           glink true
  607.            } ,
  608.         DEF obj_70 ilog.views.graphic.IlvPolylineLinkImage {
  609.           name "70659"
  610.           toolTip "<html><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\">  Link from Port: 4 (100Mbps) on 142.9.101.91</p><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\">  to Port: 25 (100Mbps) on 142.9.101.67. </p><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\"></p></html>"
  611.           foreground 64 64 64
  612.           oriented false
  613.           from USE obj_29
  614.           to USE obj_41
  615.           lineWidth 2.0
  616.           points [  ]
  617.           moveable false
  618.           glink true
  619.            } ,
  620.         DEF obj_71 ilog.views.graphic.IlvPolylineLinkImage {
  621.           name "78851"
  622.           toolTip "<html><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\">  Link from Port: 8 (100Mbps) on 142.9.101.91</p><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\">  to Port: 25 (100Mbps) on 142.9.101.68. </p><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\"></p></html>"
  623.           foreground 64 64 64
  624.           oriented false
  625.           from USE obj_29
  626.           to USE obj_45
  627.           lineWidth 2.0
  628.           points [  ]
  629.           moveable false
  630.           glink true
  631.            } ,
  632.         DEF obj_72 ilog.views.graphic.IlvPolylineLinkImage {
  633.           name "111619"
  634.           toolTip "<html><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\">  Link from Port: 22 (100Mbps) on 142.9.101.91</p><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\">  to Port: 7 (100Mbps) on 142.9.101.92. </p><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\"></p></html>"
  635.           foreground 64 64 64
  636.           oriented false
  637.           from USE obj_29
  638.           to USE obj_49
  639.           lineWidth 2.0
  640.           points [  ]
  641.           moveable false
  642.           glink true
  643.            } ,
  644.         DEF obj_73 ilog.views.graphic.IlvPolylineLinkImage {
  645.           name "119811"
  646.           toolTip "<html><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\">  Link from Port: 1 (100Mbps) on 142.9.101.92</p><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\">  to Port: 1 (100Mbps) on 142.9.101.93. </p><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\"></p></html>"
  647.           foreground 64 64 64
  648.           oriented false
  649.           from USE obj_49
  650.           to USE obj_53
  651.           lineWidth 2.0
  652.           points [  ]
  653.           moveable false
  654.           glink true
  655.            } ,
  656.         DEF obj_74 ilog.views.graphic.IlvPolylineLinkImage {
  657.           name "87043"
  658.           toolTip "<html><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\">  Link from Port: 9 (100Mbps) on 142.9.101.91</p><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\">  to Port: 25 (100Mbps) on 142.9.101.69. </p><p align=\"left\" style=\"font-family:Tahoma;font-size:11pt\"></p></html>"
  659.           foreground 64 64 64
  660.           oriented false
  661.           from USE obj_29
  662.           to USE obj_57
  663.           lineWidth 2.0
  664.           points [  ]
  665.           moveable false
  666.           glink true
  667.            }
  668.
  669.        ]
  670.       } , ilog.views.IlvManagerLayer {
  671.       index 2
  672.       visible true
  673.       selectable true
  674.       elements [
  675.        ]
  676.       } , ilog.views.IlvManagerLayer {
  677.       index 3
  678.       visible true
  679.       selectable true
  680.       elements [
  681.        ]
  682.       } , ilog.views.IlvManagerLayer {
  683.       index 4
  684.       visible true
  685.       selectable true
  686.       elements [
  687.        ]
  688.       }]}
Marsh Posté le 23-04-2004 à 15:24:20
[:mlc]
Everyone thinks of changing the world, but no one thinks of changing himself  |  It is the peculiar quality of a fool to perceive the faults of others and to forget his own  |  Early clumsiness is not a verdict, it’s an essential ingredient.
Marsh Posté le 23-04-2004 à 15:26:32
Oh merde.
Non, c'est pas du java, c'est un fichier ilv (contenant des information de positionnement d'objets graphiques) créé avec ilog views java, et c'est pas intégrable dans une page web (sauf applet avec views qui le lit et l'affiche, mais c'est faissable qu'en intranet vu la taille du bestiau).
brisez les rêves des gens, il en restera toujours quelque chose...  -- laissez moi troller sur discu !
Marsh Posté le 23-04-2004 à 15:31:10
[:zeed]
IVG en france
Marsh Posté le 23-04-2004 à 15:49:50
Eh ho, pour une fois que j'arrive à répondre à une question :o
Marsh Posté le 23-04-2004 à 16:54:15
c'est de la fumé qui lui sort de la tete c'est ca?
Message édité par veryfree le 23-04-2004 à 16:54:38
Marsh Posté le 23-04-2004 à 16:59:35
Au fait, pour info, c'est le plan d'un reseau, avec des icones pour les PC, et des liens entre.
Merde, je peux pas 'louvrir avec studio :o
Message édité par kadreg le 23-04-2004 à 17:01:19
Marsh Posté le 23-04-2004 à 17:00:21
je crois que c'est un genre d'Elan (pas facile a caser comme smiley alors je l'ai mis la [:spamafote] )
IVG en france
Marsh Posté le 23-04-2004 à 17:07:51
[:epok]
Marsh Posté le 23-04-2004 à 18:05:03
un peu comme le mien quoi [:veryfree]
Marsh Posté le 23-04-2004 à 18:52:31
Au fait, ilog views, sapu :o
Marsh Posté le 23-04-2004 à 20:06:00
super titre :o
Marsh Posté le 23-04-2004 à 21:47:56
 [:the real smiley]
 :D
༼ つ ◕_◕ ༽つ
Marsh Posté le 23-04-2004 à 22:24:32
THE REAL SMILEY a écrit :
Développeur de Bugs
c'est comme ca que t'es devenu modo alors [:meganne]
Marsh Posté le 23-04-2004 à 22:35:58
ah bon ? je suis modo moi :??:
.... euh oui en fait, je suis modo de mon forum perso [:ddr555]
Message édité par THE REAL SMILEY le 23-04-2004 à 22:36:48
༼ つ ◕_◕ ༽つ
Marsh Posté le 23-04-2004 à 22:36:21
Bah oui, comme moi [:spamafote]
Marsh Posté le 23-04-2004 à 22:38:06
si tu le dis :D
༼ つ ◕_◕ ༽つ
Marsh Posté le 23-04-2004 à 22:55:25
oups, j ai confondu avec The Real Phoenix  [:veryfree]
sorry  :sweat:
Marsh Posté le 23-04-2004 à 23:03:06
sorry  :sweat:
ahh ces Real :D ... heureusement qu'il y en a plus beaucoup :D
༼ つ ◕_◕ ༽つ
Marsh Posté le 23-04-2004 à 23:14:02
c'est clair, c'est d'un ringard  [:ddr555]
Marsh Posté le 23-04-2004 à 23:16:56
:fuck: c'est les vestiges d'une époque révolue plutôt [:aloy]
༼ つ ◕_◕ ༽つ
Marsh Posté le 23-04-2004 à 23:17:54
j'ai pas connu [:dawa]
Message édité par veryfree le 23-04-2004 à 23:18:12
Marsh Posté le 23-04-2004 à 23:24:04
Date d'arrivée sur le forum :  le 25-07-2001  :whistle:
et pour rappel: :D
http://antibillou.free.fr/perso/timeline.png
༼ つ ◕_◕ ༽つ
Marsh Posté le 23-04-2004 à 23:26:43
et pour rappel: :D
ah, the real CONcept :D
faut croire que je suis passé a coté en fait ;D
mais qui a lancé cette mode en fait?
Message édité par veryfree le 23-04-2004 à 23:26:53
Marsh Posté le 23-04-2004 à 23:31:10
c'était pas une mode, c'était un concept [:aloy].
il n'avait de concept que le nom d'ailleurs :)
je ne sais pas/plus qui l'a créé[:spamafote] et blabla n'existant plus, pas moyen de faire des fouilles archéologiques :/
༼ つ ◕_◕ ༽つ
Marsh Posté le 24-04-2004 à 09:13:17
TRK non ?
Marsh Posté le 24-04-2004 à 09:39:19
c'est fort possible en effet, il faudrait demander à l'intéressée
༼ つ ◕_◕ ༽つ
Marsh Posté le 25-04-2004 à 17:11:40
ce code est une map snmp :).
apparement ceci est possible de l'intégrer dans une page web (que je consulte sur l'intranet) comment faire ?  :hello:
merci pour votre aide. :)
Marsh Posté le 25-04-2004 à 17:16:34
Tu Crée une applet, dedans, tu rajoute un grapher, et sur lce grapheur, tu fait "read" de ton centenu.
Je ne peux que te conseiller d'aller lire la doc de views (cherche bien, c'est le gros tas de livre qui dort dans un placard :lo)
Marsh Posté le 26-04-2004 à 09:54:56
malheusement je n'ai pas de bouquin sur le java :/
je vais essayer de trouver ca sur internet... :hello:
Marsh Posté le 26-04-2004 à 09:57:05
cai pas du java !  c'est du views !!!!!!!!!
http://www.ilog.com
Marsh Posté le 26-04-2004 à 10:12:28
http://www.ilog.com
si il y a un applet c'est basé sur du java non ?  :??:
Marsh Posté le 26-04-2004 à 10:13:31
Oui, mais de toutes façons, avec views, tu utilise largement plus les viewseries que le reste de java.
Marsh Posté le 26-04-2004 à 10:13:56
(et j'ai déjà vu des applets java écrites en Ada, mais c'est juste pour le fnu)à
Marsh Posté le 26-04-2004 à 10:20:16
là j'avoue ne plus comprendre grand chose...:/
je ne vois pas comment l'insérer dans une page web... :(
tu as parlé de grapher ? c'est quoi ?  :sweat:
Marsh Posté le 26-04-2004 à 10:23:35
[:totoz]
Je ne peux que te conseiller la lecture de la documentation ilog view, puisque c'est vraiment spécifique.
Detailed Description
Grapher class.
The grapher lets you create graphic programs that represent hierarchical information using graphic objects. The IlvGrapher class is a subtype of the IlvManager class. The grapher library is particularly effective in creating programs that represent large quantities of dynamic, interconnected information, such as network management and file management programs. Through an extensive set of calls to the grapher library, you can create nodes, links, and other graphic objects.
[*] Nodes are the visual reference points in a hierarchy of information. A node is a graphic object - a subtype of the IlvGraphic class - that assumes a particular functionality when added to the grapher via the IlvGrapher::addNode() call. This functionality allows links and nodes to stay together if and when a node is moved.
[*]  Links Links are the visual representation of connections between nodes. A link is an instance of the IlvLinkImage class or one of its subclasses. It is added to the grapher with the IlvGrapher::addLink() method. Since links can only exist between two existing nodes, you must create them with two graphic objects that are known as nodes by the grapher.
[*] Graphic objects of the IlvGraphic type, representing neither nodes nor links, can be incorporated into the graphs handled by the grapher.
Marsh Posté le 26-04-2004 à 10:27:23
peux tu me donner la source stp ?  :whistle:
en tout cas merci de m'occuper de mon cas, je sais je suis un boulet  :D  :lol:  :jap:
Marsh Posté le 26-04-2004 à 10:41:02
non (déjà, j'ai des doute sur le fait que j'ai le droit de poster cela ici).
Il te faudra forcément ilog views.
Marsh Posté le 26-04-2004 à 11:02:59
même pas la doc ?  :sweat:
