Ouvrir une image en popup - Lightbox 2 inside
Ouvrir une image en popup - Lightbox 2 inside - HTML/CSS - Programmation
Marsh Posté le 19-12-2007 à 16:28:08
Salut :)
Je voudrais utiliser le script Lightbox2 (http://www.lokeshdhakar.com/projects/lightbox2/)
Celui-ci s'utilise vraiment simplement (j'ai mis en gras pour que vous ayez l'essentiel) :
How to Use:
Part 1 - Setup
   1. Lightbox v2.0 uses the Prototype Framework and Scriptaculous Effects Library. You will need to include these three Javascript files in your header.
      <script type="text/javascript" src="js/prototype.js"></script>
      <script type="text/javascript" src="js/scriptaculous.js?load=effects"></script>
      <script type="text/javascript" src="js/lightbox.js"></script>
   2. Include the Lightbox CSS file (or append your active stylesheet with the Lightbox styles).
      <link rel="stylesheet" href="css/lightbox.css" type="text/css" media="screen" />
   3. Check the CSS and make sure the referenced prevlabel.gif and nextlabel.gif files are in the right location. Also, make sure the loading.gif and closelabel.gif files as referenced near the top of the lightbox.js file are in the right location.
Part 2 - Activate
   1. Add a rel="lightbox" attribute to any link tag to activate the lightbox. For example:
      <a href="images/image-1.jpg" rel="lightbox" title="my caption">image #1</a>
      Optional: Use the title attribute if you want to show a caption.
   2. If you have a set of related images that you would like to group, follow step one but additionally include a group name between square brackets in the rel attribute. For example:
      <a href="images/image-1.jpg" rel="lightbox[roadtrip]">image #1</a>
      <a href="images/image-2.jpg" rel="lightbox[roadtrip]">image #2</a>
      <a href="images/image-3.jpg" rel="lightbox[roadtrip]">image #3</a>
      No limits to the number of image sets per page or how many images are allowed in each set. Go nuts!
Sauf que je voudrais l'utiliser dans un logiciel d'édition de visite virtuelle qui n'accepte que des fonction javascript, pas un lien tel qu'il est demandé de l'utiliser...
Je ne sais pas trop comment m'y prendre... mais j'imagine qu'une solution existe... comment feriez-vous ?
 [:le chtra]
Marsh Posté le 19-12-2007 à 16:51:57
avec une idée toute bête sur la direction qui est peut-être à prendre :
ce serait d'être capable de lancer l'équivalent de ça :
en javascript. peut-être en lançant une fonction javascript qui éxécute le code html necéssaire ?
Marsh Posté le 19-12-2007 à 17:02:53
En générant une galerie avec JAlbum muni du skin Lightbox, tu peux peut être examiner le fonctionnement du truc, et l'adapter à ta situation ?
'fin j'sais pas trop si j'ai bien compris ta demande ;)
Marsh Posté le 19-12-2007 à 17:05:47
c'est pas bête en effet....
oui je me rend compte que si je formule mieux mon besoin je trouverai la solution :D
Marsh Posté le 19-12-2007 à 17:30:31
bon.
avec ça :
window.open("menu1.jpg","menu1","" );
j'ouvre bien l'image (ça l'ouvre dans une fenêtre séparée). mais je ne sais pas (on dirait que c'est impossible - noob inside-) comment ajouter le rel="lightbox" dans le code js...
Marsh Posté le 19-12-2007 à 17:51:16
huhu, je continue :)
si j'édite le fichier produit par le logiciel, au tout début j'ai du code accessible (le reste étant l'image du panoramique, cryptée). On trouve ça :
function onClickimmer_hs_2()
javascript("window.open(\"menu1.jpg\",\"menu1\",\"\" );" );
et je peux l'éditer. donc si je pouvais coller ce rel quelque part..... ça m'irait bien, mais je trouve pas. grrr.
