[C] Utilisateur windows
Utilisateur windows [C] - C++ - Programmation
Marsh Posté le 06-06-2003 à 15:28:15
Comment fait-on en c pour connaitre l'utilisateur actuellement connecté ?
Genre : administrateur
Merci De vous y interesser
NoNo
Marsh Posté le 06-06-2003 à 18:44:59
Dans l'API Windows :
The GetUserName function retrieves the user name of the current thread. This is the name of the user currently logged onto the system.
BOOL GetUserName(
    LPTSTR lpBuffer, // address of name buffer
    LPDWORD nSize  // address of size of name buffer
Parameters
lpBuffer
Points to the buffer to receive the null-terminated string containing the user's logon name. If this buffer is not large enough to contain the entire user name, the function fails.
nSize
Pointer to a DWORD that, on input, specifies the maximum size, in characters, of the buffer specified by the lpBuffer parameter. If this buffer is not large enough to contain the entire user name, the function fails. If the function succeeds, it will place the number of characters copied to the buffer into the DWORD that nSize points to.
Return Values
If the function succeeds, the return value is nonzero, and the variable pointed to by nSize contains the number of characters copied to the buffer specified by lpBuffer, including the terminating null character.
If the function fails, the return value is zero. To get extended error information, call GetLastError.
Remarks
If the current thread is impersonating another client, the GetUserName function returns the user name of the client that the thread is impersonating.
See Also
LookupAccountName
Message édité par jagstang le 06-06-2003 à 18:45:44
