Je suis confronté à un problème que je n'ai pas réussi à résoudre. je cherche à compiler un programme qui utilise la bibliothèque Gnome dans sa version 1. Lors de la compilation avec les outils autoconf/automake, j'obtiens les warning suivants :
In file included from /usr/include/c++/3.4/i486-linux/bits/c++locale.h:46, from /usr/include/c++/3.4/iosfwd:46, from /usr/include/c++/3.4/ios:44, from /usr/include/c++/3.4/ostream:45, from /usr/include/c++/3.4/iostream:45, from VideoWin.h:4, from VideoWin.cc:6: /usr/include/libintl.h:108:1: warning: this is the location of the previous definition
L'application se compile mais à l'exécution, elle ne fonctionne pas du tout comme prévu.
Autre chose, si j'inclue dans mes fichiers <iostream> apres <gnome.h>, alors je n'ai plus droit à un warning mais à une jolie erreur :
In file included from /usr/include/c++/3.4/i486-linux/bits/c++locale.h:46, from /usr/include/c++/3.4/iosfwd:46, from /usr/include/c++/3.4/ios:44, from /usr/include/c++/3.4/ostream:45, from /usr/include/c++/3.4/iostream:45, from VideoWin.h:7, from VideoWin.cc:6:
/usr/include/libintl.h:40: error: expected unqualified-id before "const" /usr/include/libintl.h:40: error: expected `)' before "const" /usr/include/libintl.h:40: error: expected init-declarator before "const" /usr/include/libintl.h:40: error: expected `,' or `;' before "const" /usr/include/libintl.h:44: error: expected unqualified-id before "const" /usr/include/libintl.h:44: error: expected `)' before "const" /usr/include/libintl.h:44: error: expected init-declarator before "const" /usr/include/libintl.h:44: error: expected `,' or `;' before "const" /usr/include/libintl.h:51: error: expected unqualified-id before "const" /usr/include/libintl.h:51: error: expected `)' before "const" /usr/include/libintl.h:51: error: expected init-declarator before "const" /usr/include/libintl.h:51: error: expected `,' or `;' before "const" /usr/include/libintl.h:81: error: expected unqualified-id before "const" /usr/include/libintl.h:81: error: expected `)' before "const" /usr/include/libintl.h:81: error: expected init-declarator before "const" /usr/include/libintl.h:81: error: expected `,' or `;' before "const" /usr/include/libintl.h:85: error: expected unqualified-id before "const" /usr/include/libintl.h:85: error: expected `)' before "const"[/cpp] /usr/include/libintl.h:85: error: expected init-declarator before "const" /usr/include/libintl.h:85: error: expected `,' or `;' before "const"
voici la parti du fichier libintl.h :
* /* Message catalogs for internationalization.
* Copyright (C) 1995-1999, 2000-2002 Free Software Foundation, Inc.
* This file is part of the GNU C Library.
* This file is derived from the file libgettext.h in the GNU gettext package.
* The GNU C Library is free software; you can redistribute it and/or
* modify it under the terms of the GNU Lesser General Public
* License as published by the Free Software Foundation; either
* version 2.1 of the License, or (at your option) any later version.
* The GNU C Library is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
* Lesser General Public License for more details.
* You should have received a copy of the GNU Lesser General Public
* License along with the GNU C Library; if not, write to the Free
* Software Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA
* 02111-1307 USA. */
* #ifndef _LIBINTL_H
* #define _LIBINTL_H 1
* #include <features.h>
* /* We define an additional symbol to signal that we use the GNU
* implementation of gettext. */
* #define __USE_GNU_GETTEXT 1
* /* Provide information about the supported file formats. Returns the
* maximum minor revision number supported for a given major revision. */
Marsh Posté le 24-05-2005 à 10:54:08
from VideoWin.h:4,
from VideoWin.cc:6:
from VideoWin.h:7,
from VideoWin.cc:6:
Si vous avez une petite idée...
Message édité par Blakstaf le 24-05-2005 à 10:55:00
