< Test Statistics > Array Memory Used: 64MB SMP Test: No Total Test Threads: 1 SMT Test: No Dynamic MP/MT Load Balance: No Processor Affinity: No
< System Chipset > Model: VIA Technologies Inc VT8363/5 KT133/KM133 System Controller Front Side Bus Speed: 2x 101MHz (202MHz data rate) Max. Bus Bandwidth: 1616MB/s (estimated)
< Logical/Chipset Memory Banks > Bank 0 Setting: 64MB SDRAM 2-2-2CL Bank 4 Setting: 64MB SDRAM 2-2-2CL Bank Interleave: 4-way Memory Bus Speed: 1x 101MHz (101MHz data rate) Max. Memory Bandwidth: 808MB/s (estimated)
< Instruction Set Support > MMX Technology: Yes SSE Technology: No SSE2 Technology: No Hyper-Threading Technology: No Extended AMD MMX Technology: Yes
Marsh Posté le 28-05-2002 à 19:48:30
Comments: 1000 mhz 1.85v 10X100mhz
<<< CPU Arithmetic Benchmark >>>
< Benchmark Results >
Dhrystone ALU: 2754MIPS
Whetstone FPU: 1372MFLOPS
< Test Status >
SMP Test: No
SMT Test: No
< Processor(s) >
Model: AMD Duron(tm) Processor
Speed: 1.01GHz
Model Number: 1006 (estimated)
Performance Rating: PR1338 (estimated)
L2 On-board Cache: 64kB ECC synchronous write-back
<<< CPU Multi-Media Benchmark >>>
Integer aEMMX/aSSE: 5482it/s
Floating-Point aE3DNow!: 6074it/s
< Test Status >
SMP Test: No
SMT Test: No
< Processor(s) >
Speed: 1.01GHz
Model Number: 1007 (estimated)
Performance Rating: PR1339 (estimated)
< Technology Support >
MMX Technology: Yes
SSE Technology: No
SSE2 Technology: No
3DNow! Technology: Yes
Extended 3DNow! Technology: Yes
<<< Memory Bandwidth Benchmark >>>
RAM Bandwidth Int Buffered aEMMX/aSSE:765MB/s
RAM Bandwidth Float Buffered aEMMX/aS:763MB/s
< Int Buffered aEMMX/aSSE (Integer STREAM) Results Breakdown >
Assignment: 769MB/s
Scaling: 768MB/s
Addition: 762MB/s
Triad: 763MB/s
Data Item Size: 4-bytes / 32-bits
Buffering Used: Yes
Bandwidth Efficiency: 95% (estimated)
< Float Buffered aEMMX/aSSE (Float STREAM) Results Breakdown >
Assignment: 768MB/s
Scaling: 768MB/s
Addition: 757MB/s
Triad: 760MB/s
Data Item Size: 8-bytes / 64-bits
Buffering Used: Yes
Bandwidth Efficiency: 94% (estimated)
< Test Statistics >
SMP Test: No
SMT Test: No
< System Chipset >
Controller
MMX Technology: Yes
SSE Technology: No
SSE2 Technology: No
