[Workblog] .:DarckTower:. [Photos]
.:DarckTower:. [Photos] [Workblog] - Water & Xtreme Cooling - Overclocking, Cooling & Modding
Marsh Posté le 24-12-2010 à 14:45:07
Soon...  :D
Config (version rapide):
Corsair Obsidian 800D
Silverstone ST-1000+
Asus Rampage 3 Extreme
Core i7 980X
GSkill  6 x 2 Go
CrossFire Radeon HD5970 2Go
Crucial C300 64Go
6 WD 2To
EK Suprem HF (plexi)
EK Acetal 5970 + Backplate
HW Labs Black ICE GT Stealth 360 XFLOW
EK CoolStream XT 120
Ventilateur Xigmatek XLF-F1256 et XLF-F1454
Laing DDC 1T
Reservoir XSPC 5" 1/4 "DDC Bayres One"
Full 13/19 Tygoon
Embouts BitsPower, TFC
quelques photos pendant le montage (avec mon iphone...désolé), j'ai encore pas mal de chose a améliorer, corriger, revoir.
http://img193.imageshack.us/img193/6174/img0222ku.jpghttp://img815.imageshack.us/img815/3093/img0209i.jpg
http://img18.imageshack.us/img18/7696/img0211co.jpghttp://img267.imageshack.us/img267/8111/img0213ud.jpg
http://img827.imageshack.us/img827/8587/img0218y.jpghttp://img408.imageshack.us/img408/6273/img0216y.jpg
http://img440.imageshack.us/img440/9291/img0220jb.jpghttp://img707.imageshack.us/img707/30/photoqfv.jpg
http://img692.imageshack.us/img692/5518/photo1jx.jpghttp://img338.imageshack.us/img338/9702/photo2hdo.jpg
http://img130.imageshack.us/img130/1323/dscf1181w.jpghttp://img96.imageshack.us/img96/615/dscf1182h.jpg
http://img703.imageshack.us/img703/9192/dscf1183o.jpghttp://img263.imageshack.us/img263/6748/dscf1185y.jpg
http://img826.imageshack.us/img826/6760/dscf1188ce.jpghttp://img717.imageshack.us/img717/9884/dscf1189y.jpg
http://img339.imageshack.us/img339/5803/dscf1190p.jpghttp://hfr-rehost.net/self/pic/f4e2ea908672285c6df11586904af7e582fa9e73.jpeg
Message édité par darckcrystal le 01-02-2011 à 09:54:12
[Mon Topic ACH/VDS/ECH]
Marsh Posté le 24-12-2010 à 15:02:20
reserved
Message édité par darckcrystal le 29-12-2010 à 14:12:01
Marsh Posté le 24-12-2010 à 15:02:23
reserved
Marsh Posté le 24-12-2010 à 15:06:20
drapal
Rien que le nom, ça pu la config de ouf :love:
Marsh Posté le 24-12-2010 à 15:29:31
Je veux la config pour planté mon drapal :p
• Asus ROG STRIX B550-E - AMD Ryzen 7 5800X3D - 32Go Corsair Vengeance - Sapphire Nitro+ RX7900XT - 3 x SSD - Corsair RM850x V3 - Corsair 5000X - H150i Capellix •
Marsh Posté le 24-12-2010 à 16:00:04
c'est fait :D
Marsh Posté le 24-12-2010 à 18:06:13
Arf j'suis pas fan du Corsair 800D, j'aurais attendu un MM ou un TJ07 :love:
Marsh Posté le 24-12-2010 à 18:09:32
Marsh Posté le 26-12-2010 à 00:24:14
Ou le boitier du topic de Ananit beaucoup mieux qu'un MM et mon cher ett plus beau  :love:
Drapoil  [:madwolf70]
Message édité par Madwolf70 le 26-12-2010 à 15:24:39
Marsh Posté le 26-12-2010 à 11:40:59
drapal :)
Marsh Posté le 26-12-2010 à 15:10:42
Drap :p
White Li : WorkBlog / Ventes
Marsh Posté le 27-12-2010 à 09:09:33
TJ07 j'ai déja eu d'ailleurs j'avais faire un truc pas trop mal mais faut trop de "bricolage" la je veux un boitier que je laisserai stock. MM j'aime pas du tout :jap:
ça va prendre du retard a cause de mon cadeau de Noël....la grippe.... :(
Message édité par darckcrystal le 27-12-2010 à 09:09:53
Marsh Posté le 27-12-2010 à 09:15:51
Drap :hello:
FEED-BACK /   I phoque PiseptO (Paidai i7 Owner)
Marsh Posté le 28-12-2010 à 14:35:21
drap
Marsh Posté le 28-12-2010 à 14:43:31
Je plante :D
/!\Mes Ventes/!\      /!\Mon Feed/!\
Marsh Posté le 31-12-2010 à 17:21:56
[:abnocte invictus]
Marsh Posté le 31-12-2010 à 17:32:32
Joli y a moyen d'avoir des tofs la nuit avec les ventilos qui tourne?
Ventes [Workblog]
Marsh Posté le 01-01-2011 à 13:38:56
Marsh Posté le 01-01-2011 à 14:14:57
Bonjour tout le monde
Meilleurs voeux de bonheur, de réussite pour cette nouvelle année qui débute.
Joli boulot dark c'est simple, sobre, efficace comme je les aime
* rien * |||||   * Mon feedback *
Marsh Posté le 03-01-2011 à 10:07:45
oui oui possible, j'ai rencontré un p'tit problème avec le reservoir XSPC donc la machine ne tourne pas pour le moment mais des que le problème est réglé je fais ça!!
Marsh Posté le 03-01-2011 à 12:26:41
T'as eu quoi comme soucis?
Ventes [Workblog]
Marsh Posté le 03-01-2011 à 14:18:14
la plan de joint du réservoir n'était pas parfaitement plat donc le LDR passait au dessus du joint torique de la pompe donc fuite et surtout la pompe aspirait de l'air qu'elle envoyait dans mon circuit, c'est en cour d'échange par doc micro.
Marsh Posté le 03-01-2011 à 14:20:08
Heureusement que tu l'as remarquer ton liquide sera de quelle couleur ?
Marsh Posté le 03-01-2011 à 15:06:45
oué heureusement  [:panzani gino]
liquide bleu feser  :jap:
Marsh Posté le 03-01-2011 à 17:37:08
Drapal :)
Bonne année Dark :D
Sinon sa n'aurais pas été plus simple de mettre la pompe en bas?
Pour le rad en haut sa n'existe pas des version avec l'entre/sortie décalé?
|--Topic [ACH] [VDS]--|La vie est un phoenix qui renaît de ses larmes.
Marsh Posté le 03-01-2011 à 17:46:46
blouskaille a écrit :
Drapal :)
Bonne année Dark :D
J'ai le même souci
http://www.materiel.net/radiateur- [...] 39941.html
Mais pas assez épais
Marsh Posté le 03-01-2011 à 18:02:22
Ces rads là fonctionnent bien mais faut des ventilos qui soufflent très forts dessus
Marsh Posté le 04-01-2011 à 09:18:26
Drapal :)
Bonne année Dark :D
si si ça aurait été le top mais y'a d'autres paramètres qui rencontrent en ligne de compte :D
exactement !
et comme je cherche le silence plus que la perf spa pour moi  [:spamafote]
Marsh Posté le 04-01-2011 à 10:09:11
Ok :jap:
Je viens de me faire crucifier :lol:
Marsh Posté le 04-01-2011 à 11:25:40
Salut, joli MOD d'un 800D et joli config au passage.
Par contre le sens du liquide c'est bien pompe->rad->cpu->gpu ?
Et lorsque tu aura pu démarrer cette grosse bête pourras tu mettre tes températures en jeux ou autre j'aimerai bien voir le niveau de juste un 360 sur deux 5970 et un 980  :??:
Continue comme ça en tout cas  :love:
Water -> P7P55D-E Pro - i7 860 @4GHz HT On - 8Go Vengeance OC 2000 C9 - GTX570 @915/2230 - Falcon II 128Go + WD 1To - HX750 - Xigmatek Elysium -> Mon Workblog
Marsh Posté le 04-01-2011 à 13:29:12
FEEDBACK HFR
Marsh Posté le 04-01-2011 à 13:55:41
le sens du liquide c'est bien ça  :jap:
j'ai un rad 120 en bas du boitier qui apparait pas sur les photos
je mettrai les temps, pas de problème ;)
Marsh Posté le 04-01-2011 à 15:16:02
exactement !
Je me suis pris un Thermochill 120.3 bien épais à la place :lol:
Message édité par logicsystem360 le 04-01-2011 à 15:16:09
Marsh Posté le 04-01-2011 à 15:33:05
Ok :jap:
mais non, c'est un bon rad avec des I/O bien placé pour mon utilisation dommage qu'il soit si fin  :(
Marsh Posté le 04-01-2011 à 16:39:39
Disons que pour une config comme la mienne (Q9550, P45, CG nvidia max GTX480) sa peut ptet passer :)
Marsh Posté le 04-01-2011 à 16:42:35
J'ai Q6600 +HD 5870 , j'ai pris deux rad 360 dont un moyen et un épais :lol:
Marsh Posté le 04-01-2011 à 16:47:36
Ok mes rêves d'avoir ce rad c'est mort c'est ca? :cry:
Bon et bien je vais faire la même chose que toi Dark
Marsh Posté le 04-01-2011 à 17:16:43
Non mais tu devrai avoir des ventilo qui soufflent pour avoir les perf d'un rad épais, adieu le silence  [:matheanswer:2]
Marsh Posté le 04-01-2011 à 17:29:27
ou alors t'accepte d'avoir qq degrès en plus, et sa marche très bien :o
Marsh Posté le 04-01-2011 à 17:37:44
du bon gros LPDC :love:
