[Work Blog]Bureau D'ordinateur Ultime
Bureau D'ordinateur Ultime [Work Blog] - Modding - Overclocking, Cooling & Modding
Marsh Posté le 29-12-2010 à 21:09:43
Bonjour tout le monde!
Je parle pas souvent le Francais, alors, mes postes seront on Anglais! Je m'excuse pour ca, mai, je croit que les images seront vraiment interesant pour tout le monde!
I would like to thank Crucial, Kingston and Danger Den for sponsoring this project and helping to make it a reality!
http://img40.imageshack.us/img40/4871/cruciallogo.gif
http://img850.imageshack.us/img850/7906/kingstonlogogif.png
http://img508.imageshack.us/img508/5674/dangerdenlogo.png
Decided a few weeks ago to start building my own custom computer desk / enclosure and I thought some of you would be interested in checking it out, so here goes :)
The 1st draft of the Ultimate Computer Desk.
I wanted the desk to be capable of having 2 integrated desktop systems. 1 for high-powered gaming, and the other, a low-powered system with lots of hard-drive space that will be on 24/7 for sharing media across the network and playing videos locally.
It needs to be quiet, have dust control, have manual fan control, and it also needs to look great in an office - sorry ahead of time to all you bling lovers!
I used Google Sketchup for all of my drafts.
I started first by sketching on paper how I would like the components to be laid out, and then started working on the left-hand module.
After determining the minimum width, I started to build up the left-hand module, taking into consideration that I would be using 3/4" plywood for the construction.
http://farm5.static.flickr.com/4106/5201406039_c18cf0c359.jpg
I then decided that the air intake will be on the same board that the motherboard will lie, air will come from the bottom. It will be covered with a furnace air filter material that should eliminate most of the dust, and also provide good air circulation.
http://farm5.static.flickr.com/4091/5202001046_4f9195503d.jpg
Next up was to add some to-scale components. A big thanks to B@gy, who created the model for the Noctua NH-U12P CPU Heatsink, as well as the Noctua fans, Alexander who created the model for the Asus Ares video card, Nightsoul who created the model of the Western Digital Hard-Drives, and Fubar East for the very nice power supply model. Your talent saved me a lot of time when it came to placing the items to scale.
http://farm6.static.flickr.com/5046/5201406077_c56c2d1be2.jpg
Another view, from the back
http://farm6.static.flickr.com/5290/5201406093_a9b6fd7eaf.jpg
I then took the same requirements and applied them to the right-hand module. This will be the "server-type" system. I also wanted to add drawers to this particular module, so this is what I came up with. It has the same air-intake system, which will be covered by a furnace air filter.
http://farm5.static.flickr.com/4148/5201406107_7506faec0b.jpg
And, finally, putting it all together, I figured 2 monitors is a reasonable thing these days. In the upper left, there will be the DVD drive, plus power and fan controls for the gaming rig. There is a glass cover over the gaming rig that can be removed to perform upgrades and maintenance.
http://farm5.static.flickr.com/4133/5202001106_244b576913.jpg
And a picture of the back - the boxes aren't exactly what they'll turn out as - they are for cable management, ideally I will setup little boxes so you will see almost NO cables in the back. They will have some foam stuffed in the top to keep dust out of the boxes as well.
http://farm6.static.flickr.com/5168/5202001122_a8298ea800.jpg
And that's it for this post! The 1st draft! I'll have to ponder on it for a little while to make sure everything is A-OK for building, and determine how much lumber I'll need.
As always, comments, feedback and ideas are ALWAYS WELCOME! This is going to be a long build, I figure it'll take me a couple months at least, and that's not including some of the custom electronic trickery I'm going to have to learn!
Message édité par ultimatedesk le 31-03-2011 à 18:44:01
Marsh Posté le 29-12-2010 à 21:10:22
After spending some time reviewing my 1st draft I realized a few things very quickly:
1. All my joints are butt joints! This is going to result in a lot of screw holes on the visible surfaces that I will have to cover up, and it will not be as strong as it could be.
2. The edges of plywood are nasty - I did not account for using 1/4" solid wood trim on all of the visible edges of the plywood. This will seriously throw off all my measurements.
3. The right-hand module, with the so called drawers, don't actually have drawers sketched in - just drawer faces!
So, it was time start from scratch (Sorta). Here's the end result, and ultimately, the final plan. The dark coloured wood is the solid trim, and the light coloured wood are 1x1's so that I can screw the panels together from the inside, avoiding any screw holes on the outside. I also added a few dado joints that I believe will be ultra strong with just a generous application of wood glue.
http://farm6.static.flickr.com/5121/5202002508_03592c9c72.jpg
http://farm5.static.flickr.com/4153/5202002530_4246fb3421.jpg
So, while I was redoing all of this, I figured: this desk is going to be a beast. A big, heavy, super-duty truck kind of beast. This means I will likely be able to keep it for quite some time, and with technology going the way it is....
http://farm6.static.flickr.com/5129/5201407551_223500f13e.jpg
Yup, planning for 3 monitors, external fan / dvd / power controls for both of the systems, and going the full 8 foot length for the desk. The dvd / controls will be in the cubby holes you see in the upper left and right-hand sides of the desk.
It'll be able to be disassembled into 4 pieces - the desk surface, the desk shelf, and the left and right modules.
Much better. I think from here I can make my cut sheets and actually get to work!
Yes, I love Google Sketchup, I am not ashamed of it either, it is so incredibly useful and it's so incredibly free.
I've used it for a few years now, mostly for planning aquarium setups and building aquarium stands. Here is the most awesome part of Sketchup - pulling dimensions, and creating your cut sheets (Someone needs to automate this).
http://farm6.static.flickr.com/5243/5201407571_ae2a049307.jpg
http://farm6.static.flickr.com/5127/5201407587_a850e542b3.jpg
http://farm5.static.flickr.com/4153/5202002638_312384edec.jpg
http://farm6.static.flickr.com/5048/5201407617_6838894d84.jpg
And that's it! 4 Sheets!
Now I have to figure out where I'm going to build this darn thing. I've got a low-ceiling basement with a circular saw, router, and a drill...
I think I might need some new tools... :D:D:D
Stay tuned! I'll be cutting up some wood next!
Marsh Posté le 29-12-2010 à 21:10:57
Purely coincidentally, while talking over the idea with a few pints at the local pub, a good girlfriend of mine piped up stating:
"Oh, didn't you know? My dad has a full wood shop in his backyard, he'd love to help I'm sure!"
By golly.
A meeting was arranged, and poof, we got along great and he's looking forward to a nice big project being started in his shop.
It's a free standing building in his backyard with an attic for wood storage, lots of tools - stationary and portable, and yeah, lots of tools - did I mention that? Table saw, band saw, drill press, planar, horizontal planar, belt sander, jointer, grinders, air compressor, just about everything a guy could ask for.
http://img15.imageshack.us/img15/3117/img4405i.jpg
So we set about to pick up the initial bits of lumber. 4 Sheets of 3/4" Plywood, 2-sided Maple Veneer - was a steal too, such a good deal that Mike, the owner of the wood shop, picked up a pair of sheets for himself for a future project as well!
http://img88.imageshack.us/img88/6945/img4398h.jpg
http://img689.imageshack.us/img689/1636/img4410p.jpg
Time to hit up the table saw to do the initial lengthwise cuts
http://img718.imageshack.us/img718/8642/img4404n.jpg
http://img4.imageshack.us/img4/4949/img4415c.jpg
Thankfully I had a helper - she was eventually covered in sawdust and abandoned me in the shop after the big cuts were done. It still left me with several 8' long sheets to manage on my own, as you can see in the left hand side of the shop in the back.
http://img18.imageshack.us/img18/6551/img4412b.jpg
So I set about my merry way, and thankfully, did not lose any of my fingers (This time).
http://img709.imageshack.us/img709/3193/aimg4418.jpg
http://img522.imageshack.us/img522/4114/aimg4423.jpg
http://img338.imageshack.us/img338/4359/aimg4425.jpg
All of the initial cuts were done, except for one particular strip of 8' that needed to be cut into 3 28" lengths - beyond what the table saw was capable of doing. I decided that it was enough for the day.
http://img574.imageshack.us/img574/1083/aimg4426.jpg
Made quite a nice little mess!!
http://img686.imageshack.us/img686/7202/aimg4427.jpg
http://img27.imageshack.us/img27/1711/aimg4431.jpg
All in all a good start to a long project
http://img15.imageshack.us/img15/7415/aimg4435.jpg
http://img842.imageshack.us/img842/6362/aimg4441.jpg
Stay tuned! Lots of work still to go
Marsh Posté le 29-12-2010 à 21:14:52
Welcome :)
Nice project :)
See you on B**-T*** :)
Message édité par tavutatete le 29-12-2010 à 21:19:26
StarWars Tourelle Turbo-Laser
Marsh Posté le 29-12-2010 à 22:08:43
C'est vraiment un bon début, pressé d'en voir la suite. :p
"Le serveur a compris la requête, mais refuse de la satisfaire." Ou comment dire poliment a quelqu'un d'aller se faire foutre.
Marsh Posté le 29-12-2010 à 23:20:27
Already looks great
I'll follow this thread ;)
Topikatransäks
Marsh Posté le 30-12-2010 à 01:15:17
What a crazy idea, this's gonna be a real good desktop I guess.
A nice integrated computer project, let's see what u can do :D
Marsh Posté le 30-12-2010 à 01:42:34
Sorry for my bad english ^^
I think it's an idea who everyone here haved one time in his life, and your it's really impressive, really good project !
Good luck guy !
I put your thread in my favorites and see you again !
Message édité par asphyth le 30-12-2010 à 01:44:24
-> Mon Feed Back <- -> Mes Ventes <-
Marsh Posté le 30-12-2010 à 10:58:57
Oh yeah a desktop mod !
God job !
Enjoy !
Sorry for my english :/
Marsh Posté le 30-12-2010 à 16:13:03
tavutatete a écrit :
Welcome :)
Nice project :)
Knightcore a écrit :
Already looks great
Good luck guy !
God job !
Enjoy !
Thanks everyone! I really appreciate the support :) Merci tout le monde, j'ai pas la chance de parlez Francais beaucoup, ou ecrier, mai je comprend q'est que to dit! (Oi, the spelling and grammar!  :lol: )
Marsh Posté le 30-12-2010 à 16:13:56
Had time to cut that last 8' sheet into the 28" sections, and cut a hole in the surface portion of the desk. The surface portion, fyi, will be composed of two 8' pieces of 3/4" plywood, so its total thickness will be 1.5" thick.
The upper plywood will have a hole that is .5" wider all around than the board beneath it.
Only had time to do one hole tonight - the lower portion, thankfully, because I made a few small mistakes!
Sorry about the photos folks, I had already uploaded these to imageshack and forgot to resize them, so here are the thumbnails since I don't have the original stock photos on me right now. From now on, they'll be properly sized at 800x600, which I feel is a fair compromise for detail and bandwidth.
http://img80.imageshack.us/img80/507/img4490h.th.jpg
http://img148.imageshack.us/img148/4591/img4493d.th.jpg
I started off with a carpenters angle, measured off my lines with a pencil and then made a rough cut with a jigsaw. I then clamped a straight-edge lined up with the edges (measured) and ran a router across it to create the smooth finish.
I messed up a bit, going a bit too far with the router on one end, and then not far enough on the other end - I'll have to sand and file to square it off.
Sorry I didn't take too many pictures - the next hole will have more!
http://img88.imageshack.us/img88/3007/img44940.th.jpg
http://img695.imageshack.us/img695/5294/img4495v.th.jpg
http://img442.imageshack.us/img442/185/img4497b.th.jpg
Thankfully the shop is heated, here's one of the heaters - it went down to -8*C that evening!
http://img207.imageshack.us/img207/1623/img4500u.th.jpg
Here's the mess for the night!
http://img208.imageshack.us/img208/4203/img4509h.th.jpg
http://img529.imageshack.us/img529/60/img4511jh.th.jpg
And, the hero of the night! Mastercraft Plunge Router!!
http://img191.imageshack.us/img191/2852/img4498l.th.jpg
Marsh Posté le 30-12-2010 à 16:14:38
One of the main things holding me back right now is the fact that I have not selected the motherboard tray, and template for the motherboard input and outputs, as well as PCI slots. This prevents me from cutting the holes accurately in the back of both of the modules, which prevents me from assembling the actual modules.
I have some "spare" desktop chassis lying around, and will be working to find a solution to that soon.
In the meantime, I started working on the drawers for the right-hand module.
I first took them through the table saw again, trimming off the last 16th or two from some of the boards.
http://img688.imageshack.us/img688/5084/img4517b.jpg
Then went to work sanding all of the pieces down with 150 grit. I will likely go up to a 180 grit before the final stain goes on. I clamped a straight-edge on to the table saw so that it was easier to sand with the grain (Thanks Mike)
http://img149.imageshack.us/img149/7791/img4524t.jpg
http://img716.imageshack.us/img716/7320/img45250.jpg
http://img543.imageshack.us/img543/9288/img45270.jpg
Slowly, but surely, I went through all the pieces for the drawers, except for the faces. Yes, bad things happen when I don't have my sketchup drawings. I start drawing with markers.
http://img413.imageshack.us/img413/4720/img4531x.jpg
http://img262.imageshack.us/img262/1273/img45350.jpg
Mike was doing some work in the shop at the same time as me that day, so there was quite the mess.
http://img222.imageshack.us/img222/3691/img45380.jpg
http://img444.imageshack.us/img444/1089/img45490.jpg
I put together my tools of the trade
http://img152.imageshack.us/img152/1228/img4551.jpg
And here are the gluing steps I went through
http://img560.imageshack.us/img560/5007/img4553.jpg
http://img232.imageshack.us/img232/8535/img4554k.jpg
http://img813.imageshack.us/img813/6683/img4556a.jpg
A few somewhat artistic clamp shots ;)
http://img812.imageshack.us/img812/718/img4557j.jpg
http://img121.imageshack.us/img121/1830/img4560g.jpg
http://img835.imageshack.us/img835/7783/img4561s.jpg
Everything looks pretty straight
http://img690.imageshack.us/img690/3100/img4563b.jpg
http://img257.imageshack.us/img257/8765/img4564y.jpg
http://img208.imageshack.us/img208/4685/img45650.jpg
Glued and clamped together the largest of the drawers, will likely put some hanging folders in there.
http://img152.imageshack.us/img152/2520/img4570d.jpg
http://img822.imageshack.us/img822/9253/img4574zj.jpg
http://img801.imageshack.us/img801/3876/img4576f.jpg
http://img593.imageshack.us/img593/7734/img4579k.jpg
Then I screwed everything together with #8 1.5" screws, all holes pre-drilled and countersunk. Most of the holes will be covered by the actual drawer sliding mechanisms, but the exposed ones will get some wood putty.
It's funny being in someone else's wood shop - I couldn't find the countersink bit anywhere - I tried looking through all the drill bit boxes (There were several) and nothing, so I had been using a small bit, then switching to the big bit to countersink, and then switching to the screw bit to screw in the holes.
Mike walks in half-way through the holes and you could tell he was rather amused - he goes to the back of the shop, pulls out a box, pulls out a box from the box, and then a small medicine container out from the box in a box - "Geez, didn't I tell ya to just look around? Oh. Wait. I guess this one was sorta hard to find eh?".
At that point, he also points out that there are several drills in the shop - silly me. So one drill with the countersink bit, one drill with the screw bit. It's been very interesting working in a shop dedicated to this type of work - very, very different from working in the basement with just basic hand tools.
http://img718.imageshack.us/img718/2900/img45830.jpg
I haven't attached the faces of the drawers yet as I haven't determined how I would like to attach them. I would also like to attach the trim to the outer edges of the faces before attaching them to the drawers, since it'll be much easier to clamp all the faces together at once.
http://img840.imageshack.us/img840/7269/img4588u.jpg
And that's it for todays update - a bit short, yes, a lot of pictures of clamps, sorry, I got carried away ;)
I'm spending some time in the shop tonight, so hopefully I'll have another update for all of you tomorrow or the day after!
http://img525.imageshack.us/img525/9947/img4589i.jpg
Marsh Posté le 30-12-2010 à 16:38:06
Good job !
Marsh Posté le 30-12-2010 à 16:43:15
Awesome  [:gum]
[Mon Topic ACH/VDS/ECH]
Marsh Posté le 30-12-2010 à 18:14:32
Keep going dude ;)
Marsh Posté le 30-12-2010 à 21:10:41
:love:
Topic Vente
Marsh Posté le 30-12-2010 à 21:37:33
your project rocks.
As one of our guy here tried to sy, every one has already had this dream once, to fully integrate a computer or two in his home made computer.
Keep going, we'll be a lot to follow his thread.
And writing in english will make for some of us a good training
Quand tu me parles de ton mac, j'ai l'impression de lire "tu sais que je suis en chaise roulante, je peux pas atteindre l'étagère du haut ...mais j'ai des franges sur les poignées alors c'est joli" - DTC.com /// "Vieux, gros, roux et gaucher" :(
Marsh Posté le 30-12-2010 à 21:41:07
Oh yes [:ripthejacker]
Marsh Posté le 01-01-2011 à 20:55:40
Good job, first english topic here, I think, but good job !
Fort et motivé. Sauf parfois.
Marsh Posté le 01-01-2011 à 21:58:49
drapal !! :D
Achats / Ventes Feed-Back ITX Tower
Marsh Posté le 02-01-2011 à 01:12:22
Why don't you turn the PSU fan down?
Je pense donc tu suis. Crois moi, je suis zététicien.
Marsh Posté le 02-01-2011 à 11:52:39
omg thats a part of my dreams!  :love:  :love:  :love:
edit: drap! Flag!
Message édité par mansonic le 02-01-2011 à 11:53:40
si tu lis ça alors c'est que tu surveilles pas ta petite soeur...
Marsh Posté le 06-01-2011 à 00:04:08
Thanks for all the great comments and support everyone! I really appreciate it :)
The reason I am keeping the PSU fan up, is so that it acts like an exhaust fan, pulling some of the hot air out of the enclosure!
I finally got around to putting the second hole in the desk surface area (Since the desk is composed of two sheets of plywood, there are two holes needed, with the "top surface" needing a hole that is .5" larger all the way around, so the "bottom surface" supports the piece of glass which covers the gaming computer).
I took a few more detailed pictures compared to last time.
As with before, I started by cutting out a rough shape with the jigsaw. I was able to get within .5" comfortably of my marked lines. Sometimes if you rush the jigsaw, your cuts can get a little squirrely, so I was playing it safe. This is the top surface, so no screwing up here!!
http://img259.imageshack.us/img259/3015/img4590c.jpg
I then took an extra dose of patience, and went in straight to the corners with the jigsaw. This is a step I did not take last time, and I made a mistake with the router because of this.
http://img841.imageshack.us/img841/8619/img4594ql.jpg
http://img11.imageshack.us/img11/9444/img4593u.jpg
http://img577.imageshack.us/img577/1333/img4595x.jpg
http://img602.imageshack.us/img602/4206/img4599.jpg
I then took the router and pressed the bit right into the corner, and clamped a straight-edge on behind it. This is how I set the distance from the bit to the straight-edge. I repeated the same for the other side.
All it took was a good solid pass from right-to-left and I had a very clean straight edge without having to go all the way into the corners, where mistakes can be made, since it is quite difficult to see where the actual router bit is when the tool is running.
http://img220.imageshack.us/img220/7083/img4602d.jpg
http://img577.imageshack.us/img577/9899/img4605.jpg
http://img823.imageshack.us/img823/9738/img46080.jpg
Unclamp, reset router, reset clamps and straight edge, lather, rinse, and repeat:
http://img560.imageshack.us/img560/4071/img4616u.jpg
http://img401.imageshack.us/img401/989/img46170.jpg
This hole had a very small margin of error overall, and I am very pleased with the result. The jigsaw is an incredible versatile tool and can be very accurate, as long as you have patience. This one corner is the only one that will need a touch-up with a file and/or sandpaper, and you can see, it's only going to need less than a 16th of material removal!
http://img26.imageshack.us/img26/9139/img4622l.jpg
And that's all I had time for in the shop that day ;) Enjoy some of my mess!
http://img28.imageshack.us/img28/1451/img4614h.jpg
http://img809.imageshack.us/img809/9601/img4623g.jpg
Until next time - I have some images in the queue, but I haven't quite gotten around to resizing them just yet ;)
Marsh Posté le 06-01-2011 à 00:07:30
Mass mess : achievement unlocked ! :D
I'm waiting for the next step ;)
I love DIY and your project :love:
Marsh Posté le 06-01-2011 à 00:18:33
the mess is nothing if you achieve your goal!!!
very good start mate, continue this way for our plesure and yours especially.
Waiting for the next step.
Marsh Posté le 06-01-2011 à 09:31:32
Marsh Posté le 06-01-2011 à 16:09:27
wao , c'étaient aussi mes rêves depuis 3 ans, mais jamais avoir eu le temps et moyen de réaliser.... :'(
j'attends les prochains avancement de ton workblog avec l'impatience ^^
bidou kidou
Marsh Posté le 06-01-2011 à 23:09:03
Merci beaucoup tout le monde - thanks a lot for the encouragement! I love making a mess! ;)
Here are a few snapshots. As some of you might know, I've been a little held back in the project due to not having selected my motherboard I/O plates and motherboard trays. Without having the actual items, I couldn't make the appropriate measurements to make cut-outs in the back of the cabinets, and therefore, was unable to make the dado cuts due to worry about everything not fitting properly.
So I scrounged through some old desktop systems I had lying around, emptied their components into my bins, and decided to take apart their chassis in search of some good motherboard tray and I/O parts.
So - off to the spooky basement with a pair of chassis, my trusty drill and dremel.
http://img202.imageshack.us/img202/619/img4630k.jpg
http://img694.imageshack.us/img694/2639/img4631f.jpg
Having never drilled rivets out of a case before, I wasn't entirely sure what to expect. At first, I started with a bit that was a little bit small, so the rivets came up onto the drill bit itself and got stuck on there pretty good. Eventually, I moved to a bigger bit, and all it took was one good squeeze of the trigger and the rivet would come right out nice and cleanly.
http://img560.imageshack.us/img560/8980/img4632.jpg
http://img5.imageshack.us/img5/4232/img4635zb.jpg
Starting to rack up some parts here
http://img840.imageshack.us/img840/2571/img4638w.jpg
You can see in the image above that the I/O and PCI Plate is built right into the back of the desktop chassis - this is unfortunate, as you'll see in some future photos, my other case actually had a modular I/O plate. I'll have to take the dremel to that part to get what I need.
Time to grab the pliers...
http://img593.imageshack.us/img593/3348/img4640z.jpg
Here is the shot of the back plate of the other desktop chassis - see how the I/O plate was actually riveted in, and not pressed as a whole back sheet like the other one? Soo much easier to deal with.
http://img254.imageshack.us/img254/156/img4643zk.jpg
That was a pretty fun experience taking apart the cases. I've got a bunch of scrap sheet metal now too - wonder what interesting projects I can come up with to use them...
On to that first I/O plate - I need to dremel out the section that I need
http://img5.imageshack.us/img5/5936/img4649l.jpg
Huh.. that actually didn't work out too well, at least, not the way I would like. I'm going to take these parts to the shop to see if there are any better tools for getting nice clean lines.
Until next time!
Marsh Posté le 06-01-2011 à 23:18:47
You need a control too for your dremel, some thing like that => http://cgi.ebay.fr/DREMEL-678-GUID [...] 2323wt_902
Marsh Posté le 06-01-2011 à 23:40:19
that doesn't work with the cut off wheels
but you can try with this http://www.dremel.com/en-us/Attach [...] px?pid=670
and change the blade
or use this http://www.dremel.com/en-us/Attach [...] ?pid=MS400
or any oscillating blade with a metal blade.
But anyway, you can continue with those wheels just make it slowly and take your time.
Then finish it with a grinding or sanding tool
Marsh Posté le 07-01-2011 à 18:12:30
Thanks for the suggestions - all 3 of them are great ideas! I ended up taking the pieces to the shop as you'll see below, and I still don't like the result. I will probably order some "custom" motherboard trays and I/O Panels as a result.
I had some time to take those motherboard tray and I/O Plates to the shop to try out a few tools / techniques for shaping them into something I actually like.
First off, yes, Mike and I tried using the nice Dewalt Jigsaw, but the Mastercraft metal blades we were trying to use just wouldn't stay in the darn clamp. It would cut like butter for maybe 10 seconds and then bam, the blade would fall out of the bottom of the jigsaw onto the ground. Not sure what was going on there.
http://img59.imageshack.us/img59/4995/img4655o.jpg
Next up, we tried this neat little Mastercraft oscillating tool with a metal blade as well, but no such luck. Couldn't figure out a good way to clamp down the metal tray, so it just vibrated it like crazy instead of actually cutting.
http://img214.imageshack.us/img214/5602/img4656j.jpg
http://img94.imageshack.us/img94/8665/img4658r.jpg
Our next contestant was an air compressor powered cutting wheel, which, was ultimately less accurate than the dremel, and just as slow.
http://img686.imageshack.us/img686/6139/img4660j.jpg
So we took out the big gun, the sawzall.
http://img697.imageshack.us/img697/5674/img4653i.jpg
Ha, no, just kidding. It wouldn't work even a tiny bit for a piece like this.
In the end, you know what ultimately worked the best?
http://img580.imageshack.us/img580/3956/img4663mr.jpg
Yeah, a hacksaw. Go figure.
Anyways, here you can see my mangled I/O plate for the motherboard. It's not a pretty sight at all in my opinion.
http://img208.imageshack.us/img208/4136/img4666s.jpg
This is the nice I/O plate that I didn't even have to do anything except drill out a few rivets.
http://img844.imageshack.us/img844/5499/img4668w.jpg
I think I'm going to have to come up with a better solution for this. We'll see shortly ;)
Hope everyone who is getting snow is enjoying it, I know here in Ottawa, it's been a pretty crazy few days!
Stay tuned for more updates, will be spending some time in the shop this week and working with WOOD!
Marsh Posté le 07-01-2011 à 18:26:27
No more snow for Paris now, maybe more later :)
Keep on working wood, you rock :D
Message édité par KaiserCz le 08-01-2011 à 03:04:20
Marsh Posté le 07-01-2011 à 21:34:05
Well I'm in Montreal and i'm still wating for the massive snow they announced... what a pity I've should have to Winnipeg...
Keep on mate!
Marsh Posté le 07-01-2011 à 22:40:08
very good job :)
La superstition, c'est comme ceux qui réparent les fauteuils : il faut que le bois qu'ils rajoutent, il soit à peu près comme l'autre bois, sinon ça se voit trop.
Marsh Posté le 08-01-2011 à 11:00:34
Good job and good tools !
Marsh Posté le 08-01-2011 à 14:07:03
so cool ... ! good continuation
G5-yufi - Apple Cube
Marsh Posté le 09-01-2011 à 16:13:39
Drapal, nice project !  :)
Chaîne Youtube | Twitch | Feed-Back
Marsh Posté le 09-01-2011 à 16:38:55
:p Geek Desktop Inside :p Very good job
Message édité par Madwolf70 le 09-01-2011 à 16:39:13
Marsh Posté le 10-01-2011 à 09:13:30
nice project :)
Feedback / Achats/Ventes
