Overclocking & BDD AMD FX-8xx0/FX-6xx0/FX-4xx0 [TOPIC UNIQUE] - CPU - Overclocking, Cooling & Modding
Marsh Posté le 07-05-2011 à 17:11:10
° AMD OROCHI/VISHERA, CPU OverClocking Contest
Hall Of Fame "AMD FX Series CPU" :
OROCHI 4 Cores (8 Clusters) FX-8 :
| Ranking For MAX-Screen on FX-8150 w/ Air-Cooling : |
| Here Your Nick Name | Here Your (Chipset) Mobo | Here your cooling System | Here Your CPU | Here Your Best Screened Clock'n'Volt | Here Your Proof | Here Your Rank |
| Darkad | (990FX) Asrock Extreme4 | ETS-T40-TB + 120 Pull | FX-8150 (B2) | 4900 MHz @ 1.47250V | X86Secret Proof | N.C. |
| Ranking For MAX-H24 on FX-8150 w/ Air-Cooling : |
| Here Your Nick Name | Here Your (Chipset) Mobo | Here your cooling System | Here Your CPU | Here Your Best H24 Clock'n'Volt | Here Your Proof | Here Your Rank |
| Darkad | (990FX) Asrock Extreme4 | ETS-T40-TB + 120 Pull | FX-8150 (B2) | 4800 MHz @ 1.41625V | X86Secret Proof | N.C. |
| Ranking For MAX-Screen on FX-8150 w/ Water-Cooling : |
| Franck7511 | (990FX) Asus Sabertooth | Antec Kuhler 920 | FX-8150 (B2) | 5017 MHz @ 1.46250V | X86Secret Proof | N.C. |
| Ranking For MAX-H24 on FX-8150 w/ Water-Cooling : |
| Franck7511 | (990FX) Asus Sabertooth | Antec Kuhler 920 | FX-8150 (B2) | 4833 MHz @ 1.46375V | X86Secret Proof | N.C. |
________________________________________________________________________________________________________________________________________________________________________________________________
| Ranking For MAX-Screen on FX-8120 w/ Air-Cooling : |
| Ranking For MAX-H24 on FX-8120 w/ Air-Cooling : |
| Ciborg9 | (990FX) 990FXA-UD5 | water-Kit-EK-240 | FX-8120 (B2) | 4400 MHz @ 1.34375V | X86Secret Proof | N.C. |
| Ranking For MAX-Screen on FX-8120 w/ Water-Cooling : |
| Ranking For MAX-H24 on FX-8120 w/ Water-Cooling : |
OROCHI 3 Cores (6 Clusters) FX-6 :
| Ranking For MAX-Screen on FX-6100 w/ Air-Cooling : |
| Ranking For MAX-H24 on FX-6100 w/ Air-Cooling : |
| Ranking For MAX-Screen on FX-6100 w/ Water-Cooling : |
| Mnemosyne3 | (990X) GA-990x-UD3 | Antec Khüler 620 | FX-6100 | 4832 MHz @ 1.39250V | X86Secret Proof | N.C. |
| Ranking For MAX-H24 on FX-6100 w/ Water-Cooling : |
OROCHI 2 Cores (4 Clusters) FX-4 :
| Ranking For MAX-Screen on FX-4100 w/ Air-Cooling : |
| Donny11 | (870) Asrock Extreme3 v2 | Thermalright HR02 Macho | FX-4100 | 5000 MHz @ 1.52500V | X86Secret Proof | N.C. |
| Ranking For MAX-H24 on FX-4100 w/ Air-Cooling : |
| Donny11 | (870) Asrock Extreme3 v2 | Thermalright HR02 Macho | FX-4100 | 4600 MHz @ 1.40750V | JPEG-V Proof | N.C. |
| Ranking For MAX-Screen on FX-4100 w/ Water-Cooling : |
| Kirok | (990FX) Asus ROG CVF | WC Swiftech | FX-4100 | 5009 MHz @ 1.57250V | X86Secret Proof | N.C. |
| Ranking For MAX-H24 on FX-4100 w/ Water-Cooling : |
| Kirok | (990FX) Asus ROG CVF | WC Swiftech | FX-4100 | 4515 MHz @1.45250V | X86Secret Proof | N.C. |
| Spoiler : # N°1 # |
Marsh Posté le 07-05-2011 à 17:11:32
LEXIQUE & AIDE
Marsh Posté le 07-05-2011 à 17:22:04
Q&A POST :
-Question :
Bonjour, je me permet de poser la première question de ce topic, en demandant pourquoi quand j'overclock mon FX-8120, il ne reste pas à cette fréquence et descend rapidement à 3100, puis à 1400 ?
(question rhétorique)
-Réponse :
Bonne question.
Ce problème, soulevé à de nombreuses reprises, vient en réalité d'une nouvelle gestion des 'États Performance' (P state) et 'État Processeur' (C State), qu'AMD a implanté dans ses processeurs FX.
L'état CPU 6 (C6 State) et son dérivé l'état Core 6 (CC6), font appellent aux paramètres avancés de puissance (APM) des plateformes de dernière génération.
La source du problème vient d'une indisposition des chipsets AMD 9x0 à directement gérer ce ou ces paramètres, quand un Overclocking est pratiquer sur le CPU.
Néanmoins pour la bonne marche de certaines catégories de plateforme (et/ou de marques), certaines de ces-dites plateformes possèdent, dans leurs BIOS/EFI une option 'Advanced Power Management' qui peut être désactivée.
Il vous faudra donc vous assurer de disposer de cette option, pour convenir d'un Overclock via Coefficient Multiplicateur. Si ce n'est pas le cas, l'overclock via HTT (FSB) est une autre option viable.
Il est de notoriété commune, que seul le 990FX et quelques rares 990X, possèdent effectivement cette option désactivable dans le BIOS.
-Question :
Je possède depuis 3 mois un fx-8120 refroidi par un Antec Kühler 620 et une Asrock 960GM/U3S3.
J’ai fait tes tests d’OC je me suis rendu compte d’un problème :
Mon processeur d'origine sous OCCT se bride à 1400Mhz (vérifié sur CPU-Z et OCCT) lorsqu'il atteint la température de 51°C.
J’en ai déduit que ce bridage est à cause de la température, en effet en passant à 1400Mhz il perd 8°C, puis le CPU repart, puis se bride à nouveau et ce tout au long du test.
Le BIOS est à jour et les fonctions Cool'&'Quiet, APM, CPU Throttle, Turbo core, C1E et C6/CC6, sont désactivées dans le bios.
J’ai fait beaucoup de recherche, mais je n’ai trouvé aucune réponse satisfaisante pour ce problème. Il est marqué que le CPU supporte 62°C, mais à 51°C cette "sécurité" se déclenche.
Je suis à votre écoute pour m’aider à trouver une solutions à ce problème, je pense avoir tout essayé, ceci m’empêche d’OC et de tester la stabilité.
(De Cerbou)
-Réponse :
Si votre overclock ne tient toujours pas après vous êtes assuré que toutes les options relatives à la consommation, à la protection du CPU ou au TDP, sont désactivées.
Et comme vous indiquez que votre température de fonctionnement est correct, c'est que le problème ne vient pas de votre CPU même.
Il ne reste plus qu'à nous pencher sur votre carte-mère dont son BIOS est à jours.
Donc elle détecte correctement votre CPU (FX-8120), boot sans erreur et reconnait correctement ses fréquences de fonctionnement.
Pourtant à y regarder de plus près son étage d'alimentation est faible, mais surtout sa norme d'alimentation processeur se limite au CPU de TDP 95W.
En effet les cartes-mères munis d'une prise EPS limité à 4 pins, se voient limitées pour la puissance qu'elles peuvent fournir en absolu, au total.
Si votre CPU décélère ainsi, c'est que votre carte-mère se protège d'un phénomène que l'on appel un "effondrement du circuit" d'alimentation.
Voyez vous, l'EPS12V en 4Pins, tout comme le PCIe en 6Pins, sont régis par la même loi :
C'est à dire moins de 50W par ligne 12V. Exemple d'une prise molex n'ayant qu'un seul ligne, peut fournir jusqu'à 50W environs sur le 12V.
Donc un connecteur EPS12V à 4Pins ayant 2 lignes 12V, s'arrête dans les 100W, tout comme le PCIe à 6Pins.
Marsh Posté le 07-05-2011 à 17:49:03
Sondage :
-Résultat de la solution BULLDOZER :
-Résultat de l'adoption BULLDOZER :
-Résultat héritage BULLDOZER :
Marsh Posté le 07-05-2011 à 17:59:03
POST 2 Reserved
Marsh Posté le 07-05-2011 à 18:23:43
POST 3 Reserved
Marsh Posté le 14-05-2011 à 20:19:45
Update n°1:
-Réalisation Alpha First Post ;
-Mode D&CO ON
-préparation de l'historique ;
| Citation : ceci "Update n°X" est directement dépendant de vos appréciations, suggestions et questions. Alors n'hésitez plus à formuler demande & recommandation, votre intervention pourra s'avérer bénéfique ! |
Marsh Posté le 14-05-2011 à 23:49:28
Je drapalise, si c'est NORADII, c'forcément bieing ![]()
Marsh Posté le 15-05-2011 à 00:15:01
Que ce soit bieng ne fait aucun doute
L'utilité me semble un rien moins évidente
Mais je peux me tromper
Pour moi, là on est sur du contenu digne de figurer en section Hardware du Forum...
Mais c'est bien écrit, ça
Marsh Posté le 15-05-2011 à 00:16:14
Bah, il c'est déjà fait voler un topikunik, il fait tout pour que ça ne se reproduise pas...
Marsh Posté le 15-05-2011 à 21:23:13
ReplyMarsh Posté le 15-05-2011 à 21:24:41
au lieu de te répéter, comment tu trouve le first ![[:ummon] [:ummon]](https://forum-images.hardware.fr/images/perso/ummon.gif)
Marsh Posté le 15-05-2011 à 21:27:15
J'ai tout coprite
C'est un compliment venant de moi ^^
EDIT: je me suis déjà exprimé juste au dessus, abuzaÿ ![]()
Marsh Posté le 15-05-2011 à 21:27:31
Question con, un HTT en 64b, ce serais pas plus mieux ? Sachant que de plus en plus, la largeur des bus augmente, c'est pas un frein de le garder en 32 ?
Marsh Posté le 15-05-2011 à 21:34:33
| l0g4n a écrit : Question con, un HTT en 64b, ce serais pas plus mieux ? Sachant que de plus en plus, la largeur des bus augmente, c'est pas un frein de le garder en 32 ? |
avec l'Hyper-Transport version 3.x la bande passante cumulées fait 51 Go/s sachant que ce bus sert de passerelle entre les cores vers l’extérieur, on a donc :
le PCIe 3.x donc le lien vers le SPP, le bus mémoire, et les bus EECC (Energy Efficience Control Center), ok ?
donc dans le meilleurs des cas le PCIe prendra 24 Go/s, la mémoire 24 Go/s plus les bus annexes moins de 3 Go/s au global...
alors tu vois on est dedans
et puis je parle du PCie 3.x et de la DDR4, chose que nous ne touchons pas encore de nos dix doigts
pfiou me voilà rassurer, quoique
il y en aura avec qui ça ne passera pas
Désolé de te le demander, mais je préfère être un peu sûr, vu que ce topic m'est particulièrement important !
Marsh Posté le 20-05-2011 à 14:12:22
Drapal.
En espérant qu'il soit toujours présent lorsque BD sera enfin sorti ![]()
Marsh Posté le 20-05-2011 à 14:21:03
Il ne tient qu'à nous de le soutenir !
Puis c'est quoi cette idée qu'il partirait ?
Marsh Posté le 20-05-2011 à 17:25:59
sa sortie est toujour au programme de AMD il faut bien une parade a intel pour son lga 2011
Marsh Posté le 20-05-2011 à 19:46:12
je peut comprendre cette forme de scepticisme.
| Spoiler : Ob1 avait drapalisé dans mon autre topic, qui a eue de longues périodes de sommeil. |
Marsh Posté le 22-05-2011 à 15:47:58
µ Update n°1:
-Passage du First POST en Betâ ;
-Mode D&CO ACCOMPLISHED
-Sondage goes on
-Finalisation de l'historique en cours ;
| Citation : ceci "µ Update n°X" est directement dépendant de vos appréciations, suggestions et questions. Alors n'hésitez plus à formuler demandes & recommandations, vos interventions seront bénéfiques ! |
Marsh Posté le 22-05-2011 à 15:53:02
Tu pourrais donner le plan du contenu
Les questions pourraient se faire + précises...
Marsh Posté le 22-05-2011 à 15:54:29
like what
un sommaire ?
Marsh Posté le 22-05-2011 à 16:09:00
Ben, notamment ce qu'il y aura comme différences d'avec l'autre Topic par exemple
A part que celui-ci est dédié à Bulldozer je veux dire
Bah ![]()
Marsh Posté le 22-05-2011 à 16:14:04
l'est pas explicite le titre du topal et du first post
sinon rin compris
Marsh Posté le 22-05-2011 à 16:25:21
Si bien sûr mais bon
Les différences ne seront pas si nombreuses que cela entre l'o/c de Thuban et çuici ![]()
Marsh Posté le 22-05-2011 à 16:44:47
m'en fout c'est pô à moâ cuilà
et puis qui te dis que ça sera si proche, hein ?
perso un CPU qui se clock tout seul à 4 gigo ça m''est fort différent qu'un cpu à qui il faut envoyer +0.25V pour y arriver ![]()
Marsh Posté le 22-05-2011 à 16:57:09
Y'aura pitêt bien un modèle doté d'un bouton magique
"4G"
Comme sur la dernière très haut de gamme spécial 'klaucoeurs' de GIGA ^^
Marsh Posté le 22-05-2011 à 17:09:02
oui va savoir
Marsh Posté le 22-05-2011 à 17:11:29
ReplyMarsh Posté le 22-05-2011 à 17:12:15
![[:isofouet] [:isofouet]](https://forum-images.hardware.fr/images/perso/isofouet.gif)
![[:hyperboleske:1] [:hyperboleske:1]](https://forum-images.hardware.fr/images/perso/1/hyperboleske.gif)
Marsh Posté le 22-05-2011 à 17:32:13
µ Update n°2:
-Some correction First Post ;
-Mode D&CO STILL GOES ON
-Sondage still goes on
-Initialisation de la Base Des Données ;
Marsh Posté le 07-05-2011 à 17:10:44
BIENVENUE À VOUS TOUS, OVERCLOCKEURS ET OVERCLOCKEUSES DE TOUT POILS !!!!
Prologue :
Alors ici, qu'est-ce qu'on a ? Hé bien ici sera à la fois, une base de données pour overclocker avec des astuces, un recueil de problèmes et leurs solutions et un lieu pour échanger vos anecdotes sur les CPU AMD FX.
Il y aura donc ici, toutes les choses à savoir pour Overclocker convenablement son CPU, les révisions de cores, les steppings, les semaines plus disposées à monter en fréquence que d'autres, etcetera.
Tout ceci en gardant une certaine marge de sécurité que cela soit, pour la durée de vie de votre CPU, pour vos oreilles ou pour votre consommation électrique.
Et ici sera aussi réunis aides & astuces, expériences et exemples de tous, sur ces CPU AMD FX, dans le but de vous apporter un support viable, dans cette quête aux 5 Gigahertz Rock Stable
'World Record' En France -> FX-8150 B2 Overclocking Hit Video résultat :
8178,18 MHz (282x29) @ 1.94375V - x86-Secret Proof !
Le Processeur Sur le Grill :
Voici donc le Die OROCHI, base de travail contenant le design BULLDOZER, dont le ZAMBEZI représente la première variante basé sur CMT, fameux 4 Cores/8 Clusters (ou 4C/8T).
Ce processeur HdG d'AMD, au nom de code ZAMBEZI, dont les références commerciales sont les 'FX série 100', est accompagné du Chipset RD9x0, pour répondre pleinement au besoin de ce processeur à l'architecture complexe pour un CPU Desktop ! Ce CPU étant le haut de gamme AMD, le reste est confié aux APU (Llanos et Trinity), derniers architecturé autours de STARS (PROPUS aux cores K10.5 légérement amélioré), et aux quelques Athlons.
Voici donc comment se décompose la gamme FX avec en premier la série 100, puis en dessous la série 300:
Ceci est fournis à titre exhaustif. les éventuelles amélioration de process n'étant pas totalement étrangères à tout ceci, il est donc possible de voir surgir d'autre référence pour un même TDP voire un moindre (B3 & C0 Powered).
Cependant quelques déception demeure :
petit rappel l'architecture BULLDOZER était censé inaugurer la technologie HTT dans sa version 3.1 facilitant l'implentation d'un bus à parité simplifiée permettant d'en reduire le coût d'implentation, réduisant les latences internes entre 'traitant' et 'stockant', pour la sortie de résultats de calculs.
Ce bus intervenant dans la capacité du CPU à communiquer entre cores (Internal HT Gate) et vers l'extérieur (I/O Panel Front),avec une puissance brute et des voies de données, accrue.
Technologie garder sous le coude depuis '08 lors du développement final des Phenom II X4 en révision C3 donnant suite aux X6 et dont les dévellopeurs n'ont pas jugé utile de valider et donc d'implenter, et ce avant que de nouvelles normes de communications externes au CPU, en ai l'exigence !
Rappel des valeur du Lien Hyper-Transport :
Reste le contrôleur Mémoire qui à subit de profonde amélioration.
Et bien parlons en justement, il est clair qu'il a enfin été révu en profondeur et pas simplement retouché.
DDR3 exclusivement, il monte en fréquence bien mieux que ce que ne permettait celui des THUBAN, bien qu'avec une bonne carte-mère et un peu de travail, de la ram plus véloce pouvait passer.
Celui du K15, accepte officiellement de la DDR3-1866 MHz (PC14933) et officieusement jusqu'a la DDR3-2133 et même jusqu'à de la DDR3-2250 (PC18000) voire de la DDR3-2333 (PC18666), avec un peu de folie.
Pourquoi je dis un peu de folie, tout simplement parce que de la DDR3-3000 a été "flashée" sur un FX-8150 :
Bulldozer meets ADATA XPG : +3GHz DDR3
Hey guys! I was experimenting with Bulldozer over the last few days and was very surprised, that it's not only great for high cpu frequency but also for veryhigh memory overclocks! So I decided to take my latest and greatest ADATA modules out for a spin to get some scores with AMD...
La Base De(s) Données :
Il est donc évident qu'acheter un de ces CPU, dans la précipitation de la joie et de l'envie de tout péter, et en fait indéniable.
Mais le problème est, qu'un CPU aussi bon soit-il à toujours ses séries de faiblesse, ainsi que ses semaine de faiblesse et pire, ses cores de faiblesse.
Alors me diriez-vous :
"ses semaines oui je vois :
Ne pas l'acheter dès sa sortie il s'overclockera moins bien. Mais les séries je vois un peu moins, et puis les cores il n'y en a qu'un, non ?"
Et bien les séries se sont simplement des divisions temporelles de la période de production, notamment en semaine n'est-ce pas !
Rappeler-vous un Phenom II X4 en C3 ça s'overclock plutôt bien, mais si vous prenez un qui est de la 45éme semaine de 2010 ou après, les 4 Ghz se dépasse plus facilement et ainsi de suite.
En "Franglais" c'est le WeekAge, ou l'âge de "naissance" du CPU.
Oui bien est les cores, n'y en a-t-il pas qu'un ? en soit oui, parce que les termes simple nous pousse à employé ce mots dans ce sens, mais en fait un core est unique en soit, alors qu'une chaîne de production en produits des centaines.
Ceci est donc un design de core, dont en découlera d'avantage de version de core, exemple du DENEB qui a des core CACYC et des CACED, etc...
Donc ici y sera listé :
-Les steppings (révision de design);
-Les Weekages (semaine de prod);
-Les cores (révision du die);
-ainsi que les modèles;
Abordons, pour terminer, les identifiants du BULLDOZER.
Il y a donc deux façon de les identifier, l'une, simple, se fait au nom, l'autre plus compliqué, se fait de visu, sur le Processeur, son HS (heat spreader).
Voici donc quelques données de base, sur ce qu'on peut voir et trouver :
-En premier lieu, nous allons examiner "l'étiquette" visible sur le CPU, cette suite de chiffre de lettre gravée à la surface même de l'HS.
Voici avec détails :
Dans l'ordre nous y retrouvons :
-Les P/N ou "Part Number", contraction de l'identifiant du modèle avec le stepping du design ;
-Les tailles de caches avec les permutations possible ;
-La référence du nombre de cores actifs ;
-Le Socket nécessaire pour l'accueillir ;
-La chaîne de fabrication qui l'a conçus ;
-Les références des ES, et peut-être des produits finis, avec leurs fréquences respectives ;
-La référence pour la plateforme d'accueil ;
-Et enfin le type de produit ;
Voilà à l'heure actuelle tout ce que j'ai pu glaner et cumuler, pour vous
ce post reste à votre appréciation, je tiens à ce qu'il soit lisible et compréhensible, et au demeurant peu fatigant, si possible !
Message édité par NoradII le 21-04-2013 à 17:27:27
valid.x86.fr/575505 /842925 /902578
