Stabilitée p5q pro et e8400 - CPU - Overclocking, Cooling & Modding
Marsh Posté le 06-07-2008 à 21:48:01
quelqun ma donner sa cfg bios voila ce que sa donne sa ne boot pasp lus loin que le load screen win xp apres BSOD
AI Overclock tuner: Manual
CPU Ratio Setting: 8
FSB Strap to North Bridge: 333
FSB Frequency: 500 (apres je monte avec speedstep)
PCI-E Frequency: 101
DRAM Frequency: 1000 et quelque ...
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: Manual
1st Information:
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 15
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time: 55
Write Recovery Time: AUTO
Read to Precharge Time: AUTO
2nd Information :
READ to WRITE Delay (S/D): AUTO
Write to Read Delay (S): AUTO
WRITE to READ Delay (D): AUTO
READ to READ Delay (S): AUTO
READ to READ Delay (D): AUTO
WRITE to WRITE Delay (S): AUTO
WRITE to WRITE Delay (D): AUTO
3rd Information :
WRITE to PRE Delay: AUTO
READ to PRE Delay: AUTO
PRE to PRE Delay: AUTO
ALL PRE to ACT Delay: AUTO
ALL PRE to REF Delay: AUTO
DRAM Static Read Control: Disabled
DRAM Read Training: Disabled
MEM. OC Charger: Enabled
AI Clock Twister: Lighter
AI Transaction Booster: Manual
Common Performance Level: 15
All Pull-Ins: Disabled
CPU Voltage: 1.4725
CPU GTL Voltage Reference (0/2): 0.63
CPU GTL Voltage Reference (1/3): 0.67
CPU PLL Voltage: 1.58
FSB Termination Voltage: 1.26
DRAM Voltage: 2.2
NB Voltage: 1.28
NB GTL Reference: 0.63
SBridge Voltage: 1.1
PCIE SATA Voltage: 1.5
Load Line Calibration: Enabled
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
CPU Clock Skew : Normal
NB Clock Skew : Normal
si quelqu un a une idée je suis prenneur ![]()
Marsh Posté le 08-07-2008 à 10:08:03
essaie de monter ton voltage NB >1.28 d'un cran et ainsi de suite sans toucher pour le moment au reste .
il est trop bas pour un tel fsb ( 500 )
c juste mon avis ^^
par exemple pour 424 sur ma P5E3 je suis à 1.31v NB
Marsh Posté le 08-07-2008 à 22:25:37
question jai brancher un connecteur 4 pin sur le 12v connector au lieu d un 8pin ( là jai remis le 8 pin ) tu pense que sa peus vennir de ca ? aussi ( je vais essayer le voltage du nb mais je pense quil est dejas a 1.32 si je me rappel là )
Marsh Posté le 08-07-2008 à 23:00:24
pour le connecteur je ne pense pas , sur ma P5K premium j'avais juste le 4 pin et no pb en o/c 3.6/4 ghz .
tu peux pousser le NB jusque 1.55v en air sans fan supplémentaire . au delà ça chauffe trop ( 1.7v ) et aucun interet normalement pour un fsb jusque 500 mhz
Marsh Posté le 08-07-2008 à 23:14:45
ouais j ai tenter 1.56 tjrs le meme soucis
je desespere de plus en plus là impossible d aller au dela de 420de fsb stable et si je tente de synchro la ram au fsb sa boot meme pas
bon apres une nuit blanche je crois que je vais me foutre au lit .
en esperant que le pere clocking passeras par là pour me donner une idée de ce qui vas pas .
ps : merci au faite ![]()
Marsh Posté le 10-07-2008 à 04:01:24
m@cintosh_
pose la question a Overtech , peut etre pourra t'il t'aider.
http://forum.hardware.fr/hfr/Hardw [...] 509_46.htm
Marsh Posté le 11-07-2008 à 11:55:24
ba c'est bizarre, moi c'est de la même maniere que je suis bloqué mais à 560 d fsb, et changer les tensions de tout n'y fait rien. Je sais que la ram tien facile 620(déja testée), mais la le couple cm+ram est instable dès 560 mhz, peu importe les tensions que j'applique a fsb, nb, pll é tout le bordel
Marsh Posté le 11-07-2008 à 15:20:30
moi jai beau tester elle bloke a 420 de fsb et en plein bench j ai voulus lever un ventilo pendant que le pc etait en marche , j ai fais tomber le clips de maintient du ventilo sur la gfx et piffffffff 8800 gt HS
j aurais gagner ma journée moi today
Marsh Posté le 11-07-2008 à 15:23:14
m@cintosh_
Avec un coef cpu plus bas , 8 par exemple , elle ne monte pas plus
haut en fsb ta carte ?
Marsh Posté le 11-07-2008 à 16:23:28
ReplyMarsh Posté le 11-07-2008 à 16:40:03
Avec Strap "auto" c'est pareil ? (n'oublie pas de re selectionner dram frequency).
remet en auto les options concernant les performances du chipset et de la ram.
As tu essayé approche méthodique de ton " soucis " , a savoir avancer le fsb
en séparant chaque paramétre (auto ou manuel en notant les effets bénéfiques ou non ) ?
Marsh Posté le 11-07-2008 à 18:37:18
bin ce que je peu te dire tout les test effectuer c est que separement les composant tiennes le coup , enssemble c la merde , la ram tient le 640mhz et le cpu le 4.1ghz
Marsh Posté le 11-07-2008 à 18:53:04
parfois c'est pas évident et il faut mettre chaque setting du bios en évidence sinon tu peux avoir de grosses
difficultés.
Les X38 en sont un bon exemple niveau gestion de la ram.
Dans certains essais de P45 ,pour l'Oc, certains ont fait des commentaires en ce sens a savoir que
l'approche peut etre confuse a cause des differents setting bios et de leurs influences.
Veux tu une méthode ou pas ?
Marsh Posté le 11-07-2008 à 18:59:41
biensur que je veus uen methode ( pas cauet hein
ps : si tu veus look là c le topic que jai cree sur jmhardware et tout les test que j ai fais
http://www.jmax-hardware.com/forum [...] 746.0.html
Marsh Posté le 13-07-2008 à 13:22:09
Salut, je me lance dans l'overclocking mais je ne suis pas un "pro" et je ne comprends pas toute les subtilités du bios INTEL. (surtout a section voltage)
J'ai à peux de chose près la même config que vous et réussis à faire tourner mon E8400@3.825Ghz avec un FSB@425Mhz et laissé les voltages en "AUTO".
ma config:
Asus P5Q-E (Intel P45)
Intel Core 2 Duo E8400 (3.00Ghz)
Crucial Ballistix 2x1Go PC8500 (5-5-5-15 - 533Mhz - 2.20Volt)
Alimentation - Corsair TX650W (650 Watts)
Cooler Master - Hyper 212 (69.69 CFM)
Je n'ai pas encore fait de test de stabilité très élaboré. J'ai juste lancé SuperPI pour voir ce qui se passe ^^
FSB@425Mhz SuperPI OK
FSB@430Mhz SuperPI fait planter WinXP.
FSB@440Mhz WinXP plante tout seul après le login.
mon overclocking (qui fait "tourner" Super PI) : http://img33.picoodle.com/img/img3 [...] dacc69.png
| Citation : AI Overclock tuner: Manual |
J'aimerai avoir avoir votre avis pour la section voltage, ce qu'il faudrait activer/désactiver ou modifier dans le bios pour atteindre (si possible) les 4Ghz "stable"
merci de votre aide!
Marsh Posté le 13-07-2008 à 14:09:06
dejas je serais toi je lookerais ton fsb max en telechargeant setfsb en te mettant en coef 6 *500 vcore 1.35 ram 1000mhz 5 5 5 15 2.2
arriver sous window tu ouvre setfsb tu cherche la bonne pll tu lance un super pi a 500 de fsb
si sa plante pas tu monte le fsb de 5mhz tu fais un super PI et si sa passe tu refait la manip juska que super PI ne puisse plus calculer correctement arriver là tu reboot et tu leve environ 15mhz a ton fsb et de là tu peus lancer un test de stabilitée de ton pc poru voir si l est stable a un coef de 9* ton fsb max trouver avec setfsb.
si t du genre feignant tu peu test ce ci mais là je te garantit rien ok ....
DRAM Static Read Control: enabled
DRAM Read Training: disabled
MEM. OC Charger: enabled
AI Clock Twister: enabled
AI Transaction Booster: moderate
Common Performance Level: enabled ( ou auto si tu ne c pas koi mettre )
All Pull-Ins: entre 8 et 10 max vus ke c pas un fsb enorme
CPU Voltage: 1.38 +ou- c suivant ton cpu ca
CPU GTL Voltage Reference (0/2): AUTO
CPU GTL Voltage Reference (1/3): AUTO
CPU PLL Voltage: 1.52 ou 1.6
FSB Termination Voltage: 1.3 MAX
DRAM Voltage: 2.20
NB Voltage: 1.26 juska 1.34 apres faut ventilé
NB GTL Reference: AUTO
SBridge Voltage: 1.2
PCIE SATA Voltage: 1.50
Load Line Calibration: enabled
CPU Spread Spectrum: disa
PCIE Spread Spectrum: disa
CPU Clock Skew : NORMAL
NB Clock Skew : NORMAL
Marsh Posté le 13-07-2008 à 17:36:13
merci m@cintosh_ j'ai finalement atteins les 4Ghz
mon screenshoot : http://img28.picoodle.com/img/img2 [...] d36d81.png
CPU Ratio Setting: 9
FSB Frequency: 445
DRAM Frequency: 1069
1st Information:
CAS# Latency: 5
Row Refresh Cycle Time: AUTO ???
2nd Information :
3rd Information :
DRAM Static Read Control: AUTO ???
DRAM Read Training: AUTO ???
MEM. OC Charger: AUTO ???
AI Clock Twister: AUTO ???
AI Transaction Booster: AUTO ???
Common Performance Level: AUTO
CPU Voltage: 1.375
FSB Termination Voltage: 1.24 ???
DRAM Voltage: 2.20
NB Voltage: 1.28
Load Line Calibration: AUTO
CPU Clock Skew : AUTO
NB Clock Skew : AUTO
j'ai progressivement augmenté le voltage du CPU / Northbridge / Southbridge pour finalement atteindre 4Ghz. Windows n'a pas planté, SuperPI aussi. Me reste plus qu'a lancer OCCT et memetest pour finaliser mon overclocking (je croise les doigts pour pas avoir d'erreur
y a t'il des incohérences dans mes réglages, mon matos risque t'il de morfler avec plus de 1ghz dans les dents? la section AI de la RAm et les options pour améliorer l'overclocking ont-elles une réelle utilités?
Marsh Posté le 13-07-2008 à 18:22:45
met exactement ce que je t mis pour ls reglages de la memoire ,
All Pull-Ins: entre 8 et 10 max vus ke c pas un fsb énorme
envois occt au mini 1h surveille t temps et si sa passe TA GAGNE ![]()
Marsh Posté le 13-07-2008 à 21:40:15
Merci pour tes conseils, j'ai remis les fréquences d'origine, je ferais un "stress test" demain.
Bon allez, faut que j'aille jouer à trackmania ^^
Marsh Posté le 15-07-2008 à 23:59:44
je n'ai pas réussis à stabiliser mon CPU à 4Ghz. Pour y arriver, il faudrait que je monte le vcore au delà de 1.4 volt et je ne pense pas que cela soit une bonne idée. Je me suis donc rabattu sur un E8400@3.825GHz "stable" avec la plupart des valeurs du bios en "standard". C'est pas très glorieux, je sais
, mais 3.825GHz, c'est vraiment très bien pour moi.
le screen OCCT:
http://img37.picoodle.com/img/img3 [...] 60b0b3.png
Température CPU 1: http://img32.picoodle.com/img/img3 [...] 15c79c.png ( ya un problème avec la sonde ?! )
Température CPU 2: http://img33.picoodle.com/img/img3 [...] e13137.png
Le vcore: http://img34.picoodle.com/img/img3 [...] 5d6324.png
les graphiques du volt 3 et 12 sont parfaitement stable.
Mon BIOS:
FSB Frequency: 425
PCI-E Frequency: 100 (valeur standard)
FSB Strap to North Bridge: 333 (valeur standard)
DRAM Frequency: 1021
1st Information:
CAS# Latency: 5 (valeur standard)
DRAM RAS# to CAS# Delay: 5 (valeur standard)
DRAM RAS# Precharge: 5 (valeur standard)
DRAM RAS# Activate to Precharge: 15 (valeur standard)
DRAM Static Read Control: Enabled
AI Clock Twister: LIGHT (mode compatibilité) c bien ou pas bien ???
Common Performance Level: 10 (avec 5 par défaut, le PC ne boot pas) c bien ou pas bien ???
CPU Voltage: 1.35 (je vais tenter un voltage plus bas)
FSB Termination Voltage: 1.20 (valeur standard)
DRAM Voltage: 2.20 (Crucial Ballistix DDR2 PC8500 )
NB Voltage: 1.10 (valeur standard)
SBridge Voltage: 1.10 (valeur standard)
PCIE SATA Voltage: 1.50 (valeur standard)
Je vais tenté un test de stabilité avec un vcore plus bas (1.315/1.325) et essayé de grappiller un peut plus de fréquence FSB (430/435) et voir si cela passe !
Marsh Posté le 16-07-2008 à 13:10:21
FSB Frequency: 450
DRAM Frequency: 1061
1st Information:
AI Clock Twister: LIGHT ou moderate
Common Performance Level: 10 essaye 8 ou 9
CPU Voltage: 1.4
FSB Termination Voltage: 1.26 28
NB Voltage: 1.3 ou tit peu plus
SBridge Voltage: 1.0
CPU Clock Skew :normal
NB Clock Skew : normal
test avec ceci pour le 4ghz
Marsh Posté le 23-07-2008 à 16:38:40
Des news marcel3d?
J'ai la même config avec quasi tout AUTO je me demande si je dois passé en réglage manual (quitte a mettre ce que tu apelle valeur par défault). Notamment pour le CPU PLL voltage car j'ai lu que lorsqu'on le laissé en AUTO il pouvait monter a + de 1.8 et du coup cramé le proc en mois d'un mois.
Marsh Posté le 23-07-2008 à 16:58:53
oui des new ja istabilisée a 3.9ghz pour le moment a 430 de fsb je suis sous un bios beta 1004 si tu veus je te donne ma config bios
Marsh Posté le 23-07-2008 à 18:01:18
cpu ratio : 9
2. FSB frequency : 430
3. PCIE freq : 100
4. FSB strap : 333
5. DDR-Frequency : DDR2-1030
6. DRAM timing : 5-5-5-15
7. DRAM static read control : Disabled
8. DRAM read training : Disabled
9. mem OC charger : Enabled
10. ai clock twister : moderate
11. ai transaction boster : auto
12.
13. cpu voltage : 1.35
14. cpu pll voltage : 1.5
15. FSB termination voltage : 1.3
16. DRAM voltage : 2.2
17. nb voltage : auto
18. sb voltage : auto
19. pcie sata voltage : auto
20. load line calibration : Enable
21. cpu spread spectrum : Disable
22. pcie spread spectrum : Disable
Marsh Posté le 04-08-2008 à 14:43:39
Mauvaise nouvelle, mon overclocking soit disant stable @3.825GHz avec OCCT ne l'est pas avec CPUStressMT v1.0.4.
J'avais laissé tourner CPUStressMT pendant bien 20 mn, lorsque j'me suis décidé à vérifier si le bousin fonctionnait correctement. Je bouge la souris pour sortir de l'écran de veille (ça rame grave, cpu @ 100% oblige) et là, paff, une grosse erreur qui s'affiche en direct live sous mes yeux ébahis.
Augmenter le cpu voltage @+ de 1.4 pour le 4ghz ne semble pas résoudre mon problème d'instabilité. Dépité, j'ai laissé provisoirement mon overclocking de coté (me demande trop de travail)
Mon objective, reste de "monter le plus haut possible" mon CPU sans être obligé d'overclocker les autre composants de mon PC (Northbridge, Southbridge, PCI-E, etc) c'est pour cela que je désactive le mode "AUTO" et fixe les valeurs usine dans le bios. (c mon CPU qui dérouille, pas le reste)
je ferais des tests avec un FSB plus bas (400/410)
Marsh Posté le 04-08-2008 à 16:14:09
sa viens surement pas du voltage cpu ou autres mais un reglages timming memoire et strap le bordel , car suivant les strap je peut pousser ma ram juska 750 mhz stable .
jusqua 400 de fsb je peut monte ma ram a 666 mhz stable cpustress .
mais a 430 de fsb je peus pas etre stable ratio 1:1 en strap 333 ou 266 je suis obliger de me foutre en strap 400 PK ? j en c rien .
je pense que yas un soucis avec les p5q pro et e avec les ram crucru , donc je me tatea passer au x38 du cou et revendre ma cm
Marsh Posté le 26-10-2008 à 22:43:31
Salut j'ai recu ma config récemment et je viens de faire un premier jet sur mon oc.
P5Q-Pro E8400@4Ghz noctuaNH U12P & corsair dominator 2 x 1Go PC8500.
j'ai fais ces réglages et apparemment je suis table sous cpu stress MT1 Heure. 37° en idle et 58 en burn.
FSB Frequency: 450
FSB Strap to North Bridge: AUTO
DRAM Frequency: 1081
DRAM Timing Control: AUTO
CPU Voltage: 1.325
CPU GTL Reference : AUTO
FSB Termination Voltage: 1.30
DRAM Voltage: 2.20
NB Voltage: 1.40
SBridge Voltage: 1.20
PCIE SATA Voltage: AUTO
Load Line Calibration: ENABLED
CPU Spread Spectrum: DISABLED
PCIE Spread Spectrum: DISABLED
CPU Margin Enhencement : OPTIMIZED
Qu'en pensez vous? que pourrais je améliorer sachant que je souhaite rester le plus bas en T° car H24.?
Peut etre rebaisser mes tensions.?
Marsh Posté le 27-10-2008 à 08:13:32
salut j'ai pas le courage de tout lire... lol. alor moi j'ai une p5q e et je suis stable a 455 mhz. voici mes reglages :
stap 266, ddr2 1141, mem oc charger activé, ai clock twister moderate, v pll 1.5, v fsb 1.2, vdimm 2.26, v nb 1.28, vsb 1.1, cpu et pcie spread spectrum désactivé tous les 2
j'ai vu un autre oc a fsb 500mhz avec comme réglage :
mem oc charger activé, ai clock twister moderate, v pll 1.56, v fsb 1.4, v nb 1.4, vsb 1.3, cpu et pcie spread spectrum désactivé tous les 2
Marsh Posté le 31-10-2008 à 00:06:15
je suis un peu comme vous, mais en moins bcp moins bon, je souhaite overclocker mon 8400 sur ma P5Q Pro, mais par contre, j'y arrive pas.
http://forum.hardware.fr/hfr/Overc [...] 8510_1.htm
le problème, c'est qu'après avoir fait les réglages, je regarde sous CPUZ et AI booster, et ma fréquence reste à 3Ghz, sachant que je devrais être à 3,6.
Savez vous s'il y a des trucs à desactiver?
Marsh Posté le 06-07-2008 à 01:11:25
salut
bon petite question ( même plusieurs ) sur l o/c je suis un peu bloquer .
je vous explique .
j oc mon cpu j usqua 4.05ghz 9*450 a 1.288 de vcore mes barrettes sont a 600mhz en 555 15 2.2v et le soucis viens de la stabilisée a cette fréquence cpu j ai des erreurs sur les barrettes tout les 5% sous memtest , pareil sous occt il tient tout juste 38 minutes en stress cpu et barrette , mais si je stress que le cpu il tient plus de 3 h donc je suppose que le cpu est a ecarté donc sa viendrais de mes barrettes , mais la ou sa coincer c est que a valeurs standard du cpu 3ghz mes barrettes tiennes plus de 1280mhz ( 640mhz) sans aucune erreurs je me dis donc que je dois augmenté les tensions , mais n étant pas super calé non plus je viens demander de l aide , comment régler les valeur du nothbridge et du southbridge et du fsb strap et timming mémoire car là je pêche depuis ce matin et sa commence a me fatiguer sévère
merci d avance .
cpu e8400
cm p5q pro ( 0703)
ram crucial balisttix pc 8000 ( double face old modèle)
alim corsaire 620w hx
