Résultats OCCT i5-6600K 4.4GHz - CPU - Overclocking, Cooling & Modding
Marsh Posté le 02-11-2016 à 15:46:16
Est-ce que tu as la moindre idée du voltage représenté par le graph que tu nous link ? ...
Marsh Posté le 02-11-2016 à 16:15:53
Au temps pour moi ^^ c'est bon j'ai édité et mis le cpu Vcore, mais les valeurs sont bizarres ça tourne autour de 0.6.. Je suis loin d'être expert.
Sinon voila pour le VID :
https://imagizer.imageshack.us/v2/9 [...] CeJRun.png
Marsh Posté le 02-11-2016 à 20:44:36
| alex6905 a écrit : Sinon voila pour le VID : |
Oui, c'est le VID...
| Citation : VID (Voltage Identifier) = Voltage Level "request" by the CPU to the motherboard's VR (voltage regulator) to supply it, this is initialized by the CPU and can change accordingly if the CPU is in power saving mode like C1E/EIST features, and also each CPU has an unique max VID internally that was set at factory level while they're running at full load. Turning off power saving features like C1E/EIST will overide and disable those feature and the cpu's VID will be permanently set at their max. VCore = Actual voltage "delivered/supplied" by the mobo to the cpu, this could be automatic from the cpu as the function of C1E/EIST features ... or ... it was manually set and override by user like in OCing, and this "manually set" vcore could be higher/lower than the cpu's VID at mobo with oc-ing capability. About the voltage reading, VID is just a state or information that is in the CPU, while vcore is the actual voltage, and as usual, software based reading on vcore is not very accurate, expecting +/-10 to 20% off for normal condition. |
http://www.overclockers.com/forums [...] ge-and-VID
AI Suite 3 sur Z170 peut perturber la détection du Vcore par certains softs (OCCT, CPUz...). Tu peux utiliser HWiNFO64 (le Vcore traine en bas de la liste, il suffit de le remonter pour le faire figurer à côté des VID) ou AI Suite
Donc quid du Vcore en charge sous Windows ? Bon, a priori c'est trop pour 4.4GHz et on ne teste pas la stabilité d'un OC pendant 4mn hein !
Comment et à combien est fixé le "CPU voltage" dans le BIOS ?
Édit : ah, je n'avais pas vu que la CM était une Asrock. Tu as installé "A Tuning Utility" ?
Marsh Posté le 03-11-2016 à 09:45:49
| nicooo66 a écrit :
http://www.overclockers.com/forums [...] ge-and-VID |
Ok merci pour les infos
''On ne teste pas pendant 4 minutes'' : tu veux dire que c'est trop long et nocif ou que c'est pas assez pour être représentatif ?
Dans mon BIOS je sais pas, dans l'onglet overclock il y a des modes préréglés qui s'appellent ''turboboost'', on choisit juste la fréquence puis le BIOS règle tout du coup je vois pas le CPU voltage..
Et j'ai pas A tuning utility
Je regarderai ce week-end !
Marsh Posté le 03-11-2016 à 09:50:57
4 minutes ce n'est pas du tout représentatif... Un test OC c'est minimum 30 minutes, 1H c'est mieux.
Il y en a qui conseillent plusieurs heures mais ça fait long, en général un OC pas stable tu le vois relativement vite.
Marsh Posté le 03-11-2016 à 11:00:41
Ce sujet a été déplacé de la catégorie Hardware vers la categorie Overclocking, Cooling & Modding par TotalRecall
Marsh Posté le 03-11-2016 à 11:40:24
| Citation : Overclocking, Cooling & Modding - CPU |
Il y même un topic consacré à l'OC du Skylake ("≈≈ SKYLAKE LGA 1151...") mais je te conseille vivement de lire la FP avant de poster.
L'OC automatique n'est pas recommandé à cette fréquence. Il y a de grandes chances que ton Vcore dépasse largement le VID et à 4.4GHz ça doit commencer à piquer.
| nicooo66 a écrit : Comment et à combien est fixé le "CPU voltage" dans le BIOS ? |
Choix du mode de gestion du Vcore : automatique, manuel, Adaptative Mode, offset Mode.
Marsh Posté le 03-11-2016 à 12:31:54
Pour 4.4 ghz le voltage mesuré est élevé.
Ta CM fait monter le voltage à 1.39v inutilement.
En principe 4.4 ça doit être stable à moins de 1.35 voir même moins de 1.30v selon les CPU et les carte mères, à tester.
Si ça tient 1h dans OCCT c'est que ça ne plantera jamais
Marsh Posté le 04-11-2016 à 19:06:41
Alors je viens de passer par mon bios et je constate que c'est en auto :
Il faut utiliser quel réglage ?
Marsh Posté le 04-11-2016 à 19:23:02
j'allais te dire adaptive mode mais visiblement y a pas.
du coup ca serait fixed mode.
et tu essaie un voltage inférieur à celui que ta carte mère utilisait en auto.
tu test dans occt
si ca tient une demi-heure, tu redescend un peu. si ca plante tu remonte.
en gardant un oeil sur tes températures, va pas tout cramer XD
ps : et regarde comment on fait un reset du bios sur ta carte mère, si tu baisse trop le voltage et que ca boot plus du tout ça peut servir
Marsh Posté le 04-11-2016 à 20:21:27
Dernière question : J'ai toujours pas compris pourquoi mon CPU Vcore affiche toujours des valeurs autour de 0.6 ?
Marsh Posté le 04-11-2016 à 21:58:30
le vcore par defaut est dynamique et se reduit quand le cpu n'est pas utilisé.
quand tu seras en 'fixed' il ne diminuera plus.
d'ou l'intérêt d'en trouver un pas trop haut stable avec ton oc
Marsh Posté le 05-11-2016 à 17:10:18
Ok je vois !
Sinon j'ai fait des tests de 30 minutes-1h en réglant le fixed mode à 1.250V, 1.240V, 1.230.
A 1.220V ça a planté au bout de 4 minutes..
Du coup je refais un test d'une heure à 1.230V pour être sûr.
Voilà ce que ça a donné pour le premier test à 1.230V :
Ca a l'air correct non ? (toujours à 4.4GHz)
Marsh Posté le 05-11-2016 à 17:32:09
Bon j'ai bien fait de refaire un test, mon pc a planté et dû redémarrer au bout de 20 minutes de test à 1.230V ... Du coup je remonte à 1.25V, je teste 2h et si pas de plantage je laisse comme ça.
Marsh Posté le 05-11-2016 à 17:42:52
Tu peux essayer 1.24V, c'est toujours ça de pris.
Marsh Posté le 05-11-2016 à 18:30:05
Je dis ça parce que j'étais stable sous OCCT/Prime95 à 1.20V mais j'avais de temps en temps un BSOD BCcode 124 "WHEA_UNCORRECTABLE_ERROR"
j'ai mis 1.21V au lieu de 1.20V et c'est bon, je suis tranquille. ![]()
Marsh Posté le 05-11-2016 à 18:43:57
1.24v pour 4.4 c'est déjà pas mal.
Le mien à besoin d' 1.28 pour ça =/
Marsh Posté le 05-11-2016 à 20:22:25
Il semblerait que tout roule à 1.24V !
Et d'après Core Temp je ne dépasse pas 57°C.
Marsh Posté le 06-11-2016 à 00:19:12
En tout cas merci beaucoup pour vos conseils amis geeks
je me sens moins bête !
Marsh Posté le 06-11-2016 à 01:18:20
Ah ben voilà, avec un test de 2h t'es certain que t'auras pas de soucis, les valeurs que tu nous renseignes sont plutôt bonnes ![]()
Marsh Posté le 06-11-2016 à 18:43:23
Le VID ne me paraît pas réaliste pour un 6600K à 4.4GHz. Je serais curieux de voir à combien monte réellement le Vcore en charge OCCT.
Exemple sur une Asus Z170 Pro Gaming en charge OCCT :
- CPU Core Voltage manuel à 1.24V dans le "BIOS".
- LLC Auto
En augmentant un peu la tension et en jouant avec le LLC (4) on arrive à avoir un Vcore fixe à 1.24V en charge OCCT et un VID qui retombe à 1.29-1.30V (OC stable pour ma part). Reste qu'en mettant 1.24V dans BIOS, il y a peu de chance de faire des bêtises. ![]()
Marsh Posté le 12-11-2016 à 20:27:34
Et vraiment je ne comprends pas pourquoi tout le monde a un Vcore qui affiche des valeurs proches de celles réglées dans le BIOS, alors que moi mon Vcore affiche 0.6 et du coup je dois regarder le VID... Quelqu'un sait ?
Marsh Posté le 02-11-2016 à 15:32:24
Salut tout le monde, j'aimerais avoir quelques avis quand à la stabilité de mon processeur, est-ce trop ? Voici le voltage à 4.4GHz en stress test avec OCCT
http://imageshack.com/a/img923/7038/TUmTlu.png
Ma config :
Asrock Z170 pro 4S
Intel core i5 6600k avec ventilo be quiet pure rock
Asus strix gtx960 4gb
HyperX Fury 16Go DDR4 2400 MHz CL15 (4x4Go)
SSD Crucial BX100 250 Go
LDLC QS-650+ Quality Select 80PLUS Gold
Windows 10 64 bits
Je ne dépasse pas les 50-51 degrés
Message édité par alex6905 le 02-11-2016 à 16:12:26
