Overclocking i7 920 + GA-X58A-UD3R
Overclocking i7 920 + GA-X58A-UD3R - CPU - Overclocking, Cooling & Modding
Marsh Posté le 13-03-2010 à 19:01:12
Configuration :
- i7 920 3.67Ghz D0
- GIGABYTE GA-X58A-UD3R
- G.SKILL PI Series 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7T-6GBPI
- Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive
- Noctua NH-D14
J'ai regarder sur plusieur forum pour m'aider a O.C mon processeur et j'ai utiliser c config pour monter a 4Ghz :
http://forums.tweaktown.com/f69/pl [...] d3r-38298/
J'ai fait quelque motif voila:
  1. Advanced CPU Features:
  2. CPU Clock Ratio ................................ [20x]
  3. Intel(R) Turbo Boost Tech .................. [Disabled]
  4. CPU Cores Enabled ............................ [All]
  5. CPU Multi Threading .......................... [Enabled]
  6. CPU Enhanced Halt (C1E) ................... [Enabled]
  7. C3/C6/C7 State Support .................... [Disabled]
  8. CPU Thermal Monitor ......................... [Enabled]
  9. CPU EIST Function ............................ [Disabled]
  10. Virtualization Technology ................... [Disabled]
  11. Bi-Directional PROCHOT ..................... [Enabled]
  12. Uncore & QPI Features:
  13. QPI Link Speed .............................. x36
  14. Uncore Frequency .......................... (18, mem multi 2x+2)
  15. Isonchronous Frequency ..................[Enabled]
  16. Standard Clock Control:
  17. Base Clock (BCLK) Control ................ [Enabled]
  18. BCLK Frequency (MHz) ..................... 200
  19. PCI Express Frequency (MHz) ........... [100]
  20. C.I.A.2 [Disabled]
  21. Advanced Clock Control:
  22. CPU Clock Drive ..............................
  23.     [700mV]
  24.     PCI Express Clock Drive ................... [700mV]
  25.     CPU Clock Skew ............................. [0ps]
  26.     IOH Clock Skew ............................. [0ps]
  27.     Advanced DRAM Features:
  28.     Performance Enhance ...................... [Standard]
  29.     Extreme Memory Profile (X.M.P) ......... [Profile1]
  30.     System Memory Multiplier (SPD) ........ [8.0]
  31.     DRAM Timing Selectable (SPD) .......... [Expert]
  32.     Channel A + B + C
  33.     Channel A Timing Settings:
  34.     ##Channel A Standard Timing Control##
  35.     CAS Latency Time ......................7
  36.     tRCD .......................................8
  37.     tRP .........................................7
  38.     tRAS .......................................24
  39.     Command Rate (CMD) ................2
  40.     Advanced Voltage Control:
  41.     CPU
  42.     Load Line Calibration ................. [Lvl 1]
  43.     CPU Vcore ............................... 1.31875v
  44.     QPI/VTT Voltage 1.150v ............ 1.335
  45.     CPU PLL 1.800v ....................... 1.88
  46.     MCH/ICH
  47.     PCIE 1.500v ........................... 1.54
  48.     QPI PLL 1.100v ....................... 1.28
  49.     IOH Core 1.100v ..................... 1.32
  50.     ICH I/O 1.500v ....................... 1.60
  51.     ICH Core 1.1v ........................ 1.22
  52.     DRAM
  53.     DRAM Voltage 1.500v .............. 1.64
  54.     DRAM Termination 0.750v [AUTO]
  55.     Ch-A Data VRef. 0.750v [AUTO]
  56.     Ch-B Data VRef. 0.750v [AUTO]
  57.     Ch-C Data VRef. 0.750v [AUTO]
  58.     Ch-A Address VRef. 0.750v [AUTO]
  59.     Ch-B Address VRef. 0.750v [AUTO]
  60.     Ch-C Address VRef. 0.750v [AUTO]
Après un test sur OCCT je suis monté a 76c après seulement 6minutes sur 15 sur le premier cœur et mon pc a redémarrer seul.
Quelqu'un peu m'aider a mieux configurer mon bios pour avoir une température plus bas que 76c a 100% charge et rester a 4Ghz
Message édité par max3f le 13-03-2010 à 19:02:19
Marsh Posté le 13-03-2010 à 19:54:50
Voila j'ai changer le BCLK a 190 pour 3.8Ghz voila le test aprés 10 minutes
http://ups.imagup.com/08/1268553933.png
http://ups.imagup.com/08/1268553973.png
