ActiveCool AC4G-D : peltier ventirad ? - CPU - Overclocking, Cooling & Modding
Marsh Posté le 06-02-2005 à 14:35:43
Aucune idée mais le model P4 m'interesserait fortement !!
Marsh Posté le 06-02-2005 à 16:02:43
je pense que le peletier est en trop, ca ne vaut pas la peine, il faut tout isoler ton socket et tout! vo mieu un bon WC
Marsh Posté le 06-02-2005 à 17:29:19
Tant que le peltier ne fait pas descendre la température à - de 10°c ya aucun raison d'isoler tout ca.
Et d'aprés le descriptif et la faible puissance du peltier, je doute que ca tape des températures assez basse pour condenser.
Marsh Posté le 06-02-2005 à 18:52:05
justement ça me fait assez peur si g besoin de foutre de la mousse partout mais je c pa ! le watercooling c bocou trop cher nan merci !
Marsh Posté le 06-02-2005 à 22:13:42
je t'ai trouvé un site qui l'a testé : rapidement tres bon produit , mais visiblement pour une utilisation intensive ou longue , cela à posé des problèmes :
UK Conclusion
This changing of cooling levels only occurred when my CPU was fully loaded for more than an hour.
It didn't occur for the past 14 days of my "daily-use" testing, not even while playing Far Cry nor when overclocking to 3.4 GHz - and until now I haven't been able to reach more than 3.3 GHz.
So my conclusion must be that it will not occur to the end user, unless the system is totally loaded for a long time - for instance using applications like 3DMax, Maya, benchmark programs or folding@home.
Another factor is that my little apartment has been extremely hot lately - possibly the problem may be caused by that?
All in all I think that Activecool has a really good product here, and I hope that they will fix this level-changing problem under full load, as well as improve the crappy paint job on the front of the control unit.
As it's a beta product I have refrained from listing pros and cons, but if the few bugs I've mentioned are fixed in the final version the product won't really have any disadvantages.
Marsh Posté le 06-02-2005 à 22:16:34
voici les 2 liens :
http://www.overclocking.dk/littera [...] st&id=2745
http://www.teschke.de/heatpipes/Ne [...] ecool.html
Marsh Posté le 06-02-2005 à 14:11:25
Salut tout le monde ! regardez ce que g trouvé ! C'est un ventirad classique sauf qu'il a une plaque peltier !!!
http://www.noiselower.com/achat/pr [...] hp?id=1020
qu'est ce que vous en pensez ? quelqu'un l'a déjà ?
