Thermaltake TMG ND5 ventirad pour 8800 enfin un test !
Thermaltake TMG ND5 ventirad pour 8800 enfin un test ! - Air Cooling - Overclocking, Cooling & Modding
Marsh Posté le 01-08-2007 à 19:20:00
Après des recherches, j'ai pu enfin trouver un test relatif du TMGND5 dot l'ambition est le silence avec les performances. Je vous livre les impressions d'un acheteur de ce ventirad interressant. Tout d'abord il n'est pas du tout fait de la même façon que le rad stock n'en déplaise à certains sur le forum.
voici le ventirad en question :
http://hardwareoc.hu/shop-k/components/com_virtuemart/shop_image/product/2963c299fc9b734117bd577d9f7582f6.jpg
la configuration :
Case: Thermaltake Aguila Mid Tower
CPU: AMD X2 6000+
CPU Cooler: Thermaltake V1
Motherboard: Abit AN9 32X Fatality
Video Card: EVGA 8800GTS 640MB
VGA Cooler: Thermaltake TMG ND5
HDD: Maxtor 160GB SATA
Stock VGA cooler:
http://www.peterstuff.net/images/thermaltake/stock.JPG
ND5 Cooler:
http://www.peterstuff.net/images/thermaltake/ND5.JPG
puis ses propres conclusions :
The design and the air flow of the cooler is drastically different than the stock cooler so it affected the temperature of the entire system. The stock cooler blows out of the back and the TMG blows towards the front... No idea why they designed it like that.
Hmmm... a whole whopping 5 Degrees Celsius.
I dunno about that. I suppose 5 degrees will get you a bit of an over-clock.
Also, as you can tell, from the pictures, this is not the most controlled environment so your mileage will vary. I know the HL team is busy with a other reviews but hopefully there will be a more accurate review from the HL review team.
Installation was straightforward. However, I do recommend that you take a look at the directions because there are some parts that can be missed.
It is however, noticeably quieter and for those that want the silence, this is another plus.
Pros: 5 Degrees better than stock cooler
Noticeably quieter
Fairly easy to install
Cons: Only 5 degrees cooler
Heat sinks for VRM chips could be better
Conclusion: Ill keep it on the card till the DuOrb comes out!
je pense donc que ce système est un bon produit puisque très silencieux, refroidissant la carte mère ainsi que ses composants et que même s'il n'est plus performant par rapport au rad stock que de 5°, cela nous laisse une marge pour l'OC. Par exemple ma GTS qui est maintenent à 596/899 tiens bien le choc sosu Oblivion mais que le ventilo de la carte tourne à 2700trs c'est-à dire à fond.
Encore une image de comparaison :
Messatsu !
Marsh Posté le 01-08-2007 à 19:33:51
Mouais, je trouve ces performances très médiocre quand on compare aux autres systèmes de refroidissement pour 8800. ( exemple type HR-03+ avec un gain de 24 voir 28°c en full et idle)
Marsh Posté le 01-08-2007 à 20:13:29
ce que j'aimerai c'est un ventirad comme le thermaltake mais aussi performant que le thermalright. Ce qui me fait ch... c'est qu'il faut en plus acheter un 92mm :kaola:
Marsh Posté le 01-08-2007 à 20:24:59
Moi je dirais au contraire tu as la liberté de mettre le ventilo que tu voeux.
Marsh Posté le 01-08-2007 à 22:20:48
j'ai pensé foutre un NFR8 sous volté avec le LNA qui le metrai à 1000trs mais je sais pas si c 'est suffisant. Et d'ailleurs y en a un sur le forum qui a mis un 120 comment cela est-il possible ? :love:
Messatsu !
