[Topic Unique]Thermaltake TMG IA1 : la performance selon Thermaltake
Thermaltake TMG IA1 : la performance selon Thermaltake [Topic Unique] - Air Cooling - Overclocking, Cooling & Modding
Marsh Posté le 02-12-2008 à 09:18:18
Bonjour à tous et bienvenue sur le topic unique du TMG IA1, ventirad tower orienté performance.
Spécifications :
- Utility Tower Structure
  - 51 Aluminum Fins & 4 copper heatpipes
- 12cm VR™ Fan with Blue LED
  - Shinning vision, high performance, & fan speed control available
- Utility Tower Structure with 4 Copper Heatpipes
  - conducts heat effectively from CPU and get more surfaces to dissipate
- 12cm VR™ Fan
  - allows you to adjust the fan speed for your need
- Absolutely Quiet
  - 12cm fan could make good cooling effect at only low fan speed and generate minimum noise at the same moment
- Integrated Airflow Design
  – the heat could be taken off by 12cm sideward fan and system fan from chassis to make dual cooling effects
- Scurve™ Blade Fan with Shinning Visual Effect
  – not only keeps air convention in chassis but also cares about the aesthetics with blue LED light
Modele    CL-P0489
Compatibility  Intel (Socket LGA775) :
Core 2 Extreme
Core 2 Duo Pentium D
Pentium 4 Celeron
Celeron D
AMD (Socket AM2) :
Phenom Athlon 64
Athlon 64 X2
Athlon 64 FX
Sempron
Heatsink Dimension  140mm x 97.37mm x 160mm
Heatsink Material  51 Aluminum Fins + Copper & Aluminum Base
Heatpipe  Ø 6mm x 4
Fan Dimension  Ø 120mm x 25mm
Rated Voltage  12 V
Rated Current  0.12-0.55 A
Started Voltage  7V
Fan Speed  1300-2100 RPM
Max. Air Flow  70.28CFM
Max. Air Pressure  2.51mmH2O
Noise  20dBA
Life Expectation  30,000 Hours
Connector  3 Pin
Weight  648g
Shéma de fonctionnement
http://fr.thermaltake.eu/db/Editor/Assets/cl-p0489_airflow.jpg
Quelques photos
http://fr.thermaltake.eu/db/pictures/modules/PDT/PDT060207001/20081016181374536.jpg
http://fr.thermaltake.eu/db/pictures/modules/PDT/PDT060207001/200810161813786262.jpg
http://fr.thermaltake.eu/db/pictures/modules/PDT/PDT060207001/200810161813737354.jpg
http://fr.thermaltake.eu/db/pictures/modules/PDT/PDT060207001/200810161833398610.gif
http://fr.thermaltake.eu/db/pictures/modules/PDT/PDT060207001/200810161833391097.gif
http://fr.thermaltake.eu/db/pictures/modules/PDT/PDT060207001/200810161833322687.gif
http://fr.thermaltake.eu/db/pictures/modules/PDT/PDT060207001/200810161833369512.gif
http://fr.thermaltake.eu/db/pictures/modules/PDT/PDT060207001/200810161833398001.gif
http://fr.thermaltake.eu/db/pictures/modules/PDT/PDT060207001/200810161833324394.gif
http://farm4.static.flickr.com/3070/2842113320_1f9406b6dd.jpg
Message édité par Fssabbagh le 02-12-2008 à 09:32:36
Messatsu !
Marsh Posté le 02-12-2008 à 09:20:54
Prix de vente de 60 $
Messatsu !
Marsh Posté le 02-12-2008 à 13:01:55
ça ressemble à ce que faisait zerotherm avec les BTF http://www.puissance-pc.net/images [...] f90_02.jpg
ya des nexus dans le genre aussi, des modéles pas terribles en tout cas, on dirait que TT veut continuer à faire dans le design un peu jacky mais avec des perf moisies (cf duoorb, bigtyph14...)
dommage
:o :o :o
Marsh Posté le 02-12-2008 à 13:52:02
Ils auraient pu éviter le sticker tout dégueulasse sur le haut du rad quand même :o
Sinon +1 pour la réflexion de couilleshot ...
Marsh Posté le 02-12-2008 à 14:17:40
sauf que si vous regardez bien, les ailettes sont beaucoup plus denses et on est sur un 120mm. Mais bon c'est vrai que TT en ce moment est très moisi en perf. On ne peut cependant que saluer TT de sortir un rad tower, design plus perf que les rads horizontals.
Messatsu !
Marsh Posté le 02-12-2008 à 21:26:18
d'autres photos de trèèèèèèèèèès prêt :
http://wwww.pcgameshardware.de/screenshots/original/2008/10/Thermaltake_TMG_IA1_11.jpg
http://wwww.pcgameshardware.de/screenshots/original/2008/10/Thermaltake_TMG_IA1_1.jpg
http://wwww.pcgameshardware.de/screenshots/original/2008/10/Thermaltake_TMG_IA1_10.jpg
http://wwww.pcgameshardware.de/screenshots/original/2008/10/Thermaltake_TMG_IA1_2.jpg
http://wwww.pcgameshardware.de/screenshots/original/2008/10/Thermaltake_TMG_IA1_3.jpg
http://wwww.pcgameshardware.de/screenshots/original/2008/10/Thermaltake_TMG_IA1_4.jpg
http://wwww.pcgameshardware.de/screenshots/original/2008/10/Thermaltake_TMG_IA1_5.jpg
Ils vont encore nous sortir les fixations à la rad box: regardez sur la base !
Messatsu !
Marsh Posté le 02-12-2008 à 21:37:58
au cas où les photos ne linkent plus :http://wwww.pcgameshardware.de/&me [...] yes&page=2
Messatsu !
Marsh Posté le 03-12-2008 à 12:45:20
on  a à peine des infos sur lui qu'on le critique : TT a vraiment la poisse :lol:
Messatsu !
Marsh Posté le 03-12-2008 à 14:43:30
ce que je reproche au rad thermaltake,c'est qu'il sont souvent penser avec ventilo 8-9.2cm intégrer...  :(
on voit bien sur celui la qu'un 12cm était faisable.
Message édité par Cizia le 03-12-2008 à 14:43:45
Un Ami ? C'est quelqu'un à qui on peut téléphoner à trois heures du matin en disant qu'on vient de commettre un crime et qui vous répond seulement : " Où est le corps ?! " ~/~ Alain Delon
Marsh Posté le 03-12-2008 à 14:52:12
je comprends pas, tu parles du ventilo fixé dessus ? C'est bien un 120mm ;)
Messatsu !
Marsh Posté le 05-12-2008 à 18:19:22
pas moyen de le remplacer je parie
:o :o :o
Marsh Posté le 05-12-2008 à 19:59:09
comme les zalman mais il est plus que nickel : c'est un Turbo Fan ;)
Messatsu !
Marsh Posté le 05-12-2008 à 23:47:19
 :heink:  depuis quand c'est nickel un turbo fan?
:o :o :o
Marsh Posté le 06-12-2008 à 00:39:41
:o
mieux qu'u zalman ou tricool parce que ça souffle bien plus a rpm égals
Messatsu !
Marsh Posté le 06-12-2008 à 01:40:27
ok mais ça c'est pas trés dur, c'est des modéles bof qui datent en plus, si on peux pas changer le ventilateur pour ce qui se fait de mieux ça fout les boules quand on veut le top des perfs  :o
Message édité par couilleshot le 06-12-2008 à 01:40:42
:o :o :o
Marsh Posté le 06-12-2008 à 01:42:29
copie du zerotherm nirvana 120  :o
mon topic de vente
Marsh Posté le 06-12-2008 à 02:18:32
+2 :O
Topic Vente
Marsh Posté le 06-12-2008 à 10:18:51
+3 :sweat:
bon ne nous précipitons pas et attendons les tests :jap:
Messatsu !
