Augmentation Ram Pc portable LENOVO Ideapad 330-15ARR AMD Ryzen 5 RAM
Augmentation Ram Pc portable LENOVO Ideapad 330-15ARR AMD Ryzen 5 RAM - Composant - Ordinateurs portables
Marsh Posté le 05-03-2020 à 08:44:16
Bonjour, j'ai ce pc portable depuis près d'un an et demi : https://www.cdiscount.com/informati [...] 09lfr.html
Je souhaiterai ajouter de la Ram, actuellement j'ai 4Go soudé integré a la carte mère et j’hésite a acheter 4 ou 8 go supplémentairement
Voici ce qu'indique CPU-Z:
Socket 1   ID = 0
 Number of cores  4 (max 4)
 Number of threads 8 (max 8)
 Name   AMD Ryzen 5 Mobile 2500U
 Codename  Raven Ridge
 Specification  AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx
 Package   Socket FP5
 CPUID   F.1.0
 Extended CPUID  17.11
 Core Stepping  RV-B0
 Technology  14 nm
 TDP Limit  15.0 Watts
 Core Speed  1596.8 MHz
 Multiplier x Bus Speed 16.0 x 99.8 MHz
 Base frequency (cores) 99.8 MHz
 Base frequency (ext.) 99.8 MHz
 Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, AVX2, FMA3, SHA
 Microcode Revision 0x8101007
 L1 Data cache  4 x 32 KBytes, 8-way set associative, 64-byte line size
 L1 Instruction cache 4 x 64 KBytes, 4-way set associative, 64-byte line size
 L2 cache  4 x 512 KBytes, 8-way set associative, 64-byte line size
 L3 cache  4 MBytes, 16-way set associative, 64-byte line size
 Max CPUID level  0000000Dh
 Max CPUID ext. level 8000001Fh
 Cache descriptor Level 1, D, 32 KB, 2 thread(s)
 Cache descriptor Level 1, I, 64 KB, 2 thread(s)
 Cache descriptor Level 2, U, 512 KB, 2 thread(s)
 Cache descriptor Level 3, U, 4 MB, 8 thread(s)
 FID/VID Control  yes
 # of P-States  3
 P-State   FID 0xA64 - VID 0x35 (20.00x - 1.219 V)
 P-State   FID 0xC66 - VID 0x60 (17.00x - 0.950 V)
 P-State   FID 0xC60 - VID 0x66 (16.00x - 0.912 V)
Chipset
Northbridge   AMD Ryzen SOC rev. 00
Southbridge   AMD Carrizo FCH rev. 51
Graphic Interface  PCI-Express
PCI-E Link Width  x16
PCI-E Max Link Width  x16
Memory Type   DDR4
Memory Size   4 GBytes
Channels   Single
Memory Frequency  1197.6 MHz (1:12)
CAS# latency (CL)  17.0
RAS# to CAS# delay (tRCD) 17
RAS# Precharge (tRP)  17
Cycle Time (tRAS)  39
Bank Cycle Time (tRC)  56
Command Rate (CR)  1T
Uncore Frequency  598.8 MHz
Qu'en pensez vous, voila ce que me propose crucial: https://www.crucial.com/scanview/1E [...] 6C3#memory
Merci de vos avis concernant si je dois et je peux prendre 4 ou 8 Go et quelles caractéristiques de mémoires dois je prendre?
Message édité par wonderfletch le 05-03-2020 à 08:48:45
Marsh Posté le 05-03-2020 à 09:48:21
Voici un tuto
https://www.youtube.com/watch?v=CHBcnnp42K4
Il te faut de la RAM DDR4 2400, donc tout dépend de ton usage pour la quantité. 8 Go au total c'est déjà très bien pour de la bureautique même avec plusieurs fenêtre ouvertes.
Donc un rajout de 4Go de DDR4 PC 2400 (ou plus type 2666) peut suffire.
Tu en trouves facile en occase sur ce forum apacher, ou sinon crucial, amazon, ldlc, cdiscount en proposent. Compte 20€ maxi pour 4 Go (+ port éventuel)
White List de mes transactions Achats/Ventes : cliquez l'icone de ma config !
Marsh Posté le 05-03-2020 à 09:50:28
Exemple :
https://forum.hardware.fr/hfr/Achat [...] 3086_1.htm
Marsh Posté le 05-03-2020 à 10:08:19
Merci pour votre réponse
Mon utilisation est principalement internet et quand j'ouvre beaucoup d'onglet ca traine et ca m'arrive tres souvent d'ouvrir enormement d'onglet....
Quelques fois des jeux..
Il me faut plutôt 4 ou 8 Go supplémentaire à votre avis?
Est ce que je vais voir la différence?
Actuellement ma RAM est toujours pleine et mon pc rame...
Message édité par wonderfletch le 05-03-2020 à 10:08:49
Marsh Posté le 05-03-2020 à 12:44:45
A mon avis 4Go de plus suffisent à ton usage, mais vu le faible écart de prix avec une 8Go à toi de voir... car le seul travail c'est d'ouvrir le pc.
Mais selon moi le plus gros problème c'est de pas avoir de ssd.
Donc le meilleur rapport Q/P selon moi c'est ajout de 4 Go de RAM et remplacement du disque dur par un SSD.
Pour moins de 60€ ça peut complètement changer ton PC.
Et paye toi un boitier externe pour faire un disque externe de 1 To avec ton disque d'origine.
https://www.amazon.fr/PNY-CS900-Dis [...] 481&sr=8-5
https://www.amazon.fr/Crucial-CT4G4 [...] 566&sr=8-3
OU
https://www.amazon.fr/Crucial-CT4G4 [...] r=8-3&th=1
ET
https://www.amazon.fr/GeekerChip-Bo [...] 643&sr=8-7
Message édité par bonk1 le 05-03-2020 à 12:55:03
Marsh Posté le 05-03-2020 à 13:35:13
Merci pour les infos, le ssd peut prendre l'emplacement interne de mon dd 1To?
Ou bien faut il aussi un boitier externe?
Marsh Posté le 05-03-2020 à 13:39:00
non, le ssd prend la place. Il te faudra juste un soft (gratuit) pour cloner ton disque dur sur le ssd. Mais si 256Gà en interne te suffisent, je peux te garantir que c'est plus lui que la RAM qui font ramer ton ordinateur.
Le boitier externe c'est une façon pratique de réutiliser ton disque dur.
Marsh Posté le 05-03-2020 à 14:03:49
ok merci
Marsh Posté le 05-03-2020 à 14:18:55
Merci pour vos reponse, j'ai acheté ca: https://www.cdiscount.com/informati [...] idOffre=-1
Marsh Posté le 05-03-2020 à 14:23:05
Nickel pour la RAM, et bon prix.
Ne néglige pas le SSD qui sera la clé pour les perfs.
Marsh Posté le 10-03-2020 à 17:03:31
Il y a un topic unique sur ce PC si tu as besoin d'aide pour le changement de RAM et de SSD :
https://forum.hardware.fr/hfr/Ordin [...] 5225_1.htm
Configurations type du moment : https://forum.hardware.fr/hfr/Hardw [...] 1331_1.htm  https://www.jouannetphotographe.com
