probleme grave sur un dur qu est ce
probleme grave sur un dur qu est ce - Linux et OS Alternatifs
Marsh Posté le 13-01-2002 à 17:09:59
Mar 15 16:47:41 server kernel: hda: status timeout: status=0x80 { Busy }
Mar 15 16:47:41 server kernel: hda: drive not ready for command
Mar 15 16:48:12 server kernel: ide0: reset timed-out, status=0x80
Mar 15 16:48:12 server kernel: hda: status timeout: status=0x80 { Busy }
Mar 15 16:48:12 server kernel: hda: drive not ready for command
Mar 15 16:48:47 server kernel: ide0: reset timed-out, status=0x80
Mar 15 16:48:47 server kernel: hda: status timeout: status=0x80 { Busy }
Mar 15 16:48:47 server kernel: end_request: I/O error, dev 03:01 (hda), sector 917530
Mar 15 16:48:47 server kernel: hda: drive not ready for command
Mar 15 16:49:27 server kernel: ide0: reset timed-out, status=0x80
Mar 15 16:49:27 server kernel: hda: status timeout: status=0x80 { Busy }
Mar 15 16:49:27 server kernel: hda: drive not ready for command
Mar 15 16:50:02 server kernel: ide0: reset timed-out, status=0x80
Mar 15 16:50:02 server kernel: hda: status timeout: status=0x80 { Busy }
Mar 15 16:50:02 server kernel: end_request: I/O error, dev 03:01 (hda), sector 917532
Mar 15 16:50:02 server kernel: hda: drive not ready for command
Mar 15 16:50:42 server kernel: ide0: reset timed-out, status=0x80
Mar 15 16:50:42 server kernel: hda: status timeout: status=0x80 { Busy }
Mar 15 16:50:42 server kernel: hda: drive not ready for command
Mar 15 16:51:17 server kernel: ide0: reset timed-out, status=0x80
Mar 15 16:51:17 server kernel: hda: status timeout: status=0x80 { Busy }
Mar 15 16:51:17 server kernel: end_request: I/O error, dev 03:01 (hda), sector 589860
Mar 15 16:51:17 server kernel: hda: drive not ready for command
Mar 15 16:51:57 server kernel: ide0: reset timed-out, status=0x80
Mar 15 16:51:57 server kernel: hda: status timeout: status=0x80 { Busy }
Mar 15 16:51:57 server kernel: hda: drive not ready for command
Mar 15 16:52:25 server kernel: ide0: reset: success
Mar 15 16:52:40 server kernel: hda: status timeout: status=0x80 { Busy }
Mar 15 16:52:40 server kernel: hda: drive not ready for command
Mar 15 16:53:11 server kernel: ide0: reset timed-out, status=0x80
Mar 15 16:53:11 server kernel: hda: status timeout: status=0x80 { Busy }
Mar 15 16:53:11 server kernel: hda: drive not ready for command
Mar 15 16:53:46 server kernel: ide0: reset timed-out, status=0x80
Mar 15 16:53:46 server kernel: hda: status timeout: status=0x80 { Busy }
Mar 15 16:53:46 server kernel: end_request: I/O error, dev 03:01 (hda), sector 917532
Mar 15 16:53:46 server kernel: hda: drive not ready for command
Mar 15 16:54:26 server kernel: ide0: reset timed-out, status=0x80
Mar 15 16:54:26 server kernel: hda: status timeout: status=0x80 { Busy }
Mar 15 16:54:26 server kernel: hda: drive not ready for command
Mar 15 16:55:01 server kernel: ide0: reset timed-out, status=0x80
Mar 15 16:55:01 server kernel: hda: status timeout: status=0x80 { Busy }
Mar 15 16:55:01 server kernel: end_request: I/O error, dev 03:01 (hda), sector 589860
Mar 15 16:55:01 server kernel: hda: drive not ready for command
Mar 15 16:55:41 server kernel: ide0: reset timed-out, status=0x80
Mar 15 16:55:41 server kernel: hda: status timeout: status=0x80 { Busy }
Mar 15 16:55:41 server kernel: hda: drive not ready for command
Mar 15 16:56:16 server kernel: ide0: reset timed-out, status=0x80
Mar 15 16:56:16 server kernel: hda: status timeout: status=0x80 { Busy }
Mar 15 16:56:16 server kernel: end_request: I/O error, dev 03:01 (hda), sector 589862
Mar 15 16:56:16 server kernel: hda: drive not ready for command
Mar 15 16:56:56 server kernel: ide0: reset timed-out, status=0x80
Mar 15 16:56:56 server kernel: hda: status timeout: status=0x80 { Busy }
Mar 15 16:56:56 server kernel: hda: drive not ready for command
Mar 15 16:57:31 server kernel: ide0: reset timed-out, status=0x80
Mar 15 16:57:31 server kernel: hda: status timeout: status=0x80 { Busy }
Mar 15 16:57:31 server kernel: end_request: I/O error, dev 03:01 (hda), sector 589864
Mar 15 16:57:31 server kernel: hda: drive not ready for command
Mar 15 16:58:11 server kernel: ide0: reset timed-out, status=0x80
Mar 15 16:58:11 server kernel: hda: status timeout: status=0x80 { Busy }
Mar 15 16:58:11 server kernel: hda: drive not ready for command
Mar 15 16:58:46 server kernel: ide0: reset timed-out, status=0x80
Mar 15 16:58:46 server kernel: hda: status timeout: status=0x80 { Busy }
Mar 15 16:58:46 server kernel: end_request: I/O error, dev 03:01 (hda), sector 606210
Mar 15 16:58:46 server kernel: hda: drive not ready for command
Mar 15 16:59:26 server kernel: ide0: reset timed-out, status=0x80
Mar 15 16:59:26 server kernel: hda: status timeout: status=0x80 { Busy }
Mar 15 16:59:26 server kernel: hda: drive not ready for command
Mar 15 17:00:01 server kernel: ide0: reset timed-out, status=0x80
Mar 15 17:00:01 server kernel: hda: status timeout: status=0x80 { Busy }
Mar 15 17:00:01 server kernel: end_request: I/O error, dev 03:01 (hda), sector 612854
Mar 15 17:00:01 server kernel: hda: drive not ready for command
Mar 15 17:00:41 server kernel: ide0: reset timed-out, status=0x80
je vous en masi seulement une petie te partie heuresement j etait la et j ai pu faire rebooter mais l uptime :(
ca peut etre grave sinon
debian patato  en ext2
les secteurs qu il met sont des secteurs deffectueux ou les "master" secteurs ?
ca a fait ca pas longtemps apres un dist-upgrade pour la rc5 ...
[edtdd]--Message édité par GUG--[/edtdd]
