Bonjour, quand je veux faire un lilo -vn, j'ai un message d'erreur:
thierryhome/thierry# lilo -v LILO version 22.5.9, Copyright (C) 1992-1998 Werner Almesberger Development beyond version 21 Copyright (C) 1999-2004 John Coffman Released 08-Apr-2004, and compiled at 15:30:00 on Aug 15 2004 Debian GNU/Linux
Reading boot sector from /dev/hda part_nowrite check:: No such device or address thierryhome/thierry#
Je vous copie colle le contenu de lilo.conf. Merci A+
PS: je suis pas sure qu'il y ait un rapport mais je suis passé au noyau 2.6.8 aujourd'hui.
---------------------------------------------------------------------------------- # /etc/lilo.conf - See: `lilo(Cool' and `lilo.conf(5)', # --------------- `install-mbr(Cool', `/usr/share/doc/lilo/', # and `/usr/share/doc/mbr/'.
# +---------------------------------------------------------------+ # | !! Reminder !! | # | | # | Don't forget to run `lilo' after you make changes to this | # | conffile, `/boot/bootmess.txt', or install a new kernel. The | # | computer will most likely fail to boot if a kernel-image | # | post-install script or you don't remember to run `lilo'. | # | | # +---------------------------------------------------------------+
# Support LBA for large hard disks. # lba32
# Overrides the default mapping between harddisk names and the BIOS' # harddisk order. Use with caution. #disk=/dev/hde # bios=0x81
#disk=/dev/sda # bios=0x80
# Specifies the boot device. This is where Lilo installs its boot # block. It can be either a partition, or the raw device, in which # case it installs in the MBR, and will overwrite the current MBR. # boot=/dev/hda
# Specifies the device that should be mounted as root. (`/') # root=/dev/hda11
# Enable map compaction: # Tries to merge read requests for adjacent sectors into a single # read request. This drastically reduces load time and keeps the # map smaller. Using `compact' is especially recommended when # booting from a floppy disk. It is disabled here by default # because it doesn't always work. # # compact
# Installs the specified file as the new boot sector # You have the choice between: bmp, compat, menu and text # Look in /boot/ and in lilo.conf(5) manpage for details # #install=/boot/boot-menu.b install=/boot/boot-bmp.b bitmap=/usr/share/debian-bootscreen/debian-bootscreen-sid.rle.bmp bmp-colors=1,,0,2,,0 bmp-table=120p,173p,1,15,17 bmp-timer=254p,432p,1,0,0
# Specifies the location of the map file # map=/boot/map
# You can set a password here, and uncomment the `restricted' lines # in the image definitions below to make it so that a password must # be typed to boot anything but a default configuration. If a # command line is given, other than one specified by an `append' # statement in `lilo.conf', the password will be required, but a # standard default boot will not require one. # # This will, for instance, prevent anyone with access to the # console from booting with something like `Linux init=/bin/sh', # and thus becoming `root' without proper authorization. # # Note that if you really need this type of security, you will # likely also want to use `install-mbr' to reconfigure the MBR # program, as well as set up your BIOS to disallow booting from # removable disk or CD-ROM, then put a password on getting into the # BIOS configuration as well. Please RTFM `install-mbr(Cool'. # # password=tatercounter2000
# Specifies the number of deciseconds (0.1 seconds) LILO should # wait before booting the first image. # delay=20
# You can put a customized boot message up if you like. If you use # `prompt', and this computer may need to reboot unattended, you # must specify a `timeout', or it will sit there forever waiting # for a keypress. `single-key' goes with the `alias' lines in the # `image' configurations below. eg: You can press `1' to boot # `Linux', `2' to boot `LinuxOLD', if you uncomment the `alias'. # # message=/boot/bootmess.txt prompt timeout=150 # prompt # single-key # delay=100 # timeout=100
# Specifies the VGA text mode at boot time. (normal, extended, ask, <mode> ) # # vga=ask # vga=9 # vga=normal
# Kernel command line options that apply to all installed images go # here. See: The `boot-prompt-HOWO' and `kernel-parameters.txt' in # the Linux kernel `Documentation' directory. #
# If you have another OS on this machine to boot, you can uncomment the # following lines, changing the device name on the `other' line to # where your other OS' partition is. #
Marsh Posté le 22-08-2004 à 09:16:43
Debian GNU/Linux
A+
lba32
#disk=/dev/hde
# bios=0x81
#disk=/dev/sda
# bios=0x80
boot=/dev/hda
root=/dev/hda11
# compact
map=/boot/map
delay=20
prompt
timeout=150
# prompt
# single-key
# delay=100
# timeout=100
# vga=ask
# vga=9
vga=normal
append="hdc=ide-scsi hdd=ide-scsi max_scsi_luns=1 apm=power-off"
# Boot up Linux by default.
default=Linux
image=/boot/vmlinuz
label=Linux
read-only
# restricted
# alias=1
#image=/boot/vmlinuz.old
# label=LinuxOLD
# read-only
# restricted
# alias=1
other=/dev/hda1
label="Windows"
