help me !!! les pro de exim [URGENT] - Linux et OS Alternatifs
Marsh Posté le 06-08-2001 à 10:29:04
#ton domaine
qualify_domain = cbf.com
queue_remote_domains = ! *.localnet
#les domaines locaux
local_domains = localhost:serveurtest.cbf.com:serveurtest:cbf.com
# Allow mail addressed to our hostname, or to our IP address.
local_domains_include_host = true
local_domains_include_host_literals = true
#les domaines qu'on relaye si t'en as plusieurs tu mets : entre eux
relay_domains = *
# If this is uncommented, we accept and relay mail for all domains we are
# in the DNS as an MX for.
#relay_domains_include_local_mx = true
#tu veux pas de mail pour ces utilisateurs via exim
#never_users = root
#dès que ta une requete smtp tu peux vérifier par le dns l'expéditeur
#host_lookup = *
# Exim contains support for the Realtime Blocking List (RBL) that is being
# maintained as part of the DNS. See http://maps.vix.com/rbl/ for background.
# Uncommenting the following line will make Exim reject mail from any
# host whose IP address is blacklisted in the RBL at maps.vix.com.
#rbl_domains = rbl.maps.vix.com
#rbl_reject_recipients = false
#rbl_warn_header = true
# The setting below allows your host to be used as a mail relay by only
# the hosts in the specified networks. See the section of the manual
# entitled "Control of relaying" for more info.
#host_accept_relay = localhost : 192.168.0.4
# If you want Exim to support the "percent hack" for all your local domains,
# uncomment the following line. This is the feature by which mail addressed
# to x%y@z (where z is one of your local domains) is locally rerouted to
# x@y and sent on. Otherwise x%y is treated as an ordinary local part
# percent_hack_domains=*
# If this option is set, then any process that is running as one of the
# listed users may pass a message to Exim and specify the sender's
# address using the "-f" command line option, without Exim's adding a
# "Sender" header.
trusted_users = mail
# If this option is true, the SMTP command VRFY is supported on incoming
# SMTP connections; otherwise it is not.
smtp_verify = true
# Some operating systems use the "gecos" field in the system password file
# to hold other information in addition to users' real names. Exim looks up
# this field when it is creating "sender" and "from" headers. If these options
# are set, exim uses "gecos_pattern" to parse the gecos field, and then
# expands "gecos_name" as the user's name. $1 etc refer to sub-fields matched
# by the pattern.
gecos_pattern = ^([^,:]*)
gecos_name = $1
# This sets the maximum number of messages that will be accepted in one
# connection. The default is 10, which is probably enough for most purposes,
# but is too low on dialup SMTP systems, which often have many more mails
# queued for them when they connect.
smtp_accept_queue_per_connection = 100
# Send a mail to the postmaster when a message is frozen. There are many
# reasons this could happen; one is if exim cannot deliver a mail with no
# return address (normally a bounce) another that may be common on dialup
# systems is if a DNS lookup of a smarthost fails. Read the documentation
# for more details: you might like to look at the auto_thaw option
freeze_tell_mailmaster = true
# This string defines the contents of the \`Received' message header that
# is added to each message, except for the timestamp, which is automatically
# added on at the end, preceded by a semicolon. The string is expanded each
# time it is used.
received_header_text = "Received: \
${if def:sender_rcvhost {from ${sender_rcvhost}\n\t}\
{${if def:sender_ident {from ${sender_ident} }}\
${if def:sender_helo_name {(helo=${sender_helo_name})\n\t}}}}\
by ${primary_hostname} \
${if def:received_protocol {with ${received_protocol}}} \
(Exim ${version_number} #${compile_number} (Debian))\n\t\
id ${message_id}\
${if def:received_for {\n\tfor <$received_for>}}"
end
# TRANSPORTS CONFIGURATION #
# ORDER DOES NOT MATTER #
# Only one appropriate transport is called for each delivery. #
# This transport is used for local delivery to user mailboxes. On debian
# systems group mail is used so we can write to the /var/spool/mail
# directory. (The alternative, which most other unixes use, is to deliver
# as the user's own group, into a sticky-bitted directory)
local_delivery:
driver = appendfile
group = mail
mode = 0660
mode_fail_narrower = false
envelope_to_add = true
file = /var/mail/${local_part}
#file = /usr/mail/${local_part}
#file = /var/spool/mail/${local_part}
# This transport is used for handling pipe addresses generated by alias
# or .forward files. It has a conventional name, since it is not actually
# mentioned elsewhere in this configuration file. (A different name *can*
# be specified via the "address_pipe_transport" option if you really want
# to.) If the pipe generates any standard output, it is returned to the sender
# of the message as a delivery error. Set return_fail_output instead if you
# want this to happen only when the pipe fails to complete normally.
address_pipe:
driver = pipe
return_output
# This transport is used for handling file addresses generated by alias
address_file:
driver = appendfile
# or .forward files if the path ends in "/", which causes it to be treated
# as a directory name rather than a file name. Each message is then delivered
# to a unique file in the directory. If instead you want all such deliveries to
# be in the "maildir" format that is used by some other mail software,
# uncomment the final option below. If this is done, the directory specified
# in the .forward or alias file is the base maildir directory.
# Should you want to be able to specify either maildir or non-maildir
# directory-style deliveries, then you must set up yet another transport,
# called address_directory2. This is used if the path ends in "//" so should
# be the one used for maildir, as the double slash suggests another level
# of directory. In the absence of address_directory2, paths ending in //
# are passed to address_directory.
address_directory:
driver = appendfile
no_from_hack
prefix = ""
suffix = ""
# maildir_format
# This transport is used for handling autoreplies generated by the filtering
# option of the forwardfile director. It has a conventional name, since it
# is not actually mentioned elsewhere in this configuration file.
address_reply:
driver = autoreply
# This transport is used for delivering messages over SMTP connections.
remote_smtp:
driver = smtp
end
# DIRECTORS CONFIGURATION #
# Specifies how local addresses are handled #
# ORDER DOES MATTER #
# A local address is passed to each in turn until it is accepted. #
# This allows local delivery to be forced, avoiding alias files and
# forwarding.
real_local:
prefix = real-
driver = localuser
transport = local_delivery
# This director handles aliasing using a traditional /etc/aliases file.
# If any of your aliases expand to pipes or files, you will need to set
# up a user and a group for these deliveries to run under. You can do
# this by uncommenting the "user" option below (changing the user name
# as appropriate) and adding a "group" option if necessary.
system_aliases:
driver = aliasfile
file_transport = address_file
pipe_transport = address_pipe
file = /etc/aliases
search_type = lsearch
# user = list
# Uncomment the above line if you are running smartlist
# This director handles forwarding using traditional .forward files.
# It also allows mail filtering when a forward file starts with the
# string "# Exim filter": to disable filtering, uncomment the "filter"
# option. The check_ancestor option means that if the forward file
# generates an address that is an ancestor of the current one, the
# current one gets passed on instead. This covers the case where A is
# aliased to B and B has a .forward file pointing to A.
# For standard debian setup of one group per user, it is acceptable---normal
# even---for .forward to be group writable. If you have everyone in one
# group, you should comment out the "modemask" line. Without it, the exim
# default of 022 will apply, which is probably what you want.
userforward:
driver = forwardfile
reply_transport = address_reply
no_verify
check_ancestor
file = .forward
modemask = 002
filter
# This director matches local user mailboxes.
localuser:
driver = localuser
end
# ROUTERS CONFIGURATION #
# Specifies how remote addresses are handled #
# A remote address is passed to each in turn until it is accepted. #
# Remote addresses are those with a domain that does not match any item
# in the "local_domains" setting above.
# This router routes to remote hosts over SMTP using a DNS lookup with
# default options.
lookuphost:
driver = lookuphost
transport = remote_smtp
# This router routes to remote hosts over SMTP by explicit IP address,
# given as a "domain literal" in the form [nnn.nnn.nnn.nnn]. The RFCs
# require this facility, which is why it is enabled by default in Exim.
# If you want to lock it out, set forbid_domain_literals in the main
# configuration section above.
literal:
driver = ipliteral
end
# RETRY CONFIGURATION #
# This single retry rule applies to all domains and all errors. It specifies
# retries every 15 minutes for 2 hours, then increasing retry intervals,
# starting at 2 hours and increasing each time by a factor of 1.5, up to 16
# hours, then retries every 8 hours until 4 days have passed since the first
# failed delivery.
# Domain Error Retries
* * F,2h,15m; G,16h,2h,1.5; F,4d,8h
end
# REWRITE CONFIGURATION #
# There are no rewriting specifications in this default configuration file.
# This is an example of a useful rewriting rule---it looks up the real
# address of all local users in a file
# *@serveur ${lookup{$1}lsearch{/etc/email-addresses}\
# {$value}fail} bcfrF
# End of Exim configuration file
ca c le fichier qui marche sur ma machine de test
Marsh Posté le 06-08-2001 à 10:31:45
le fichie qui marche sur ma machine de test marche pas du tout sur mon nouveau serveur (celui que j'essaye de configurer)
alors je l'ai quelque peu modifié
#ton domaine
local_domains = localhost:breva.cbf.com:breva
relay_domains = *
#never_users = root
#host_lookup = *
# "Sender" header.
smtp_verify = true
# by the pattern.
gecos_name = $1
smtp_accept_queue_per_connection = 0
# time it is used.
id ${message_id}\
end
local_delivery:
driver = appendfile
group = mail
mode = 0660
address_pipe:
driver = pipe
return_output
address_file:
driver = appendfile
address_directory:
driver = appendfile
no_from_hack
prefix = ""
suffix = ""
# maildir_format
address_reply:
driver = autoreply
remote_smtp:
driver = smtp
end
# forwarding.
real_local:
prefix = real-
driver = localuser
system_aliases:
driver = aliasfile
file = /etc/aliases
# user = list
userforward:
no_verify
check_ancestor
file = .forward
modemask = 002
filter
localuser:
driver = localuser
end
# default options.
lookuphost:
driver = lookuphost
literal:
driver = ipliteral
end
# failed delivery.
end
Marsh Posté le 06-08-2001 à 10:32:54
est ce que ca vient de mon exim ou alors du serveur smtp relai ?
Marsh Posté le 06-08-2001 à 11:06:12
euh...là g moyenement envie et pas trop le temps de tout lire et de faire du débugging...
sorry
Marsh Posté le 06-08-2001 à 20:23:38
c plus la peine j'ai trouvé
ca venais du loopback
Marsh Posté le 06-08-2001 à 09:53:53
alors la j'ai un drole de pbm mais qui me gave a mort
j'ai tout configuré mon serveur de mail pour que l'envoi se fasse a travers une machine avec un serveur smtp (c mon exim qui stock les mails mais pour les envoyer il contact une autre machine = relaying je pense)
je fais parti d'un domaine (que l'on va appelé bac.com)
ma machine avec un serveur smtp est sur un autre domaine (cbf.com)
alors lorsque j'envoi un mail a une personne local il n'y a pas de pbm
de meme lorsque j'envoi un mail a une personne du domaine cbf.com pas de pbm non plus
mais par contre quand j'envoi un mail a une personne exterieur (ifrance, caramail ....) ben la il me met un message d'erreur :
2001-08-03 16:32:48 15SDuS-00006P-00 == athor25@ifrance.com T = remote_smtp defer (-44) : retry time not reached for any host
c vraiment trop bizzard
vous avez pas une solution, voir meme une explication
merci d'avance
(PS: ce que je capte pas non plus c'est que j'ai une autre machine sous exim qui est sous le meme domaine que le serveur smtpet la il n'y a pas de pbm pour envoyer tous les mails a toutes les @ possiibles)
