problème pour installer flash player 7 sous mandrake 9.2 [résolu] - Installation - Linux et OS Alternatifs
Marsh Posté le 01-09-2004 à 12:01:48
rep où installer -> /usr/lib/mozilla/plugins
si tu es au club mdk, il y a un rpm déjà tout fait de dispo.
Marsh Posté le 01-09-2004 à 12:47:42
texto voici :
[root@amd1800xp tmp]# cd "flash player"
[root@amd1800xp flash player]# ls
install_flash_player_7_linux/
[root@amd1800xp flash player]# cd install_flash_player_7_linux
[root@amd1800xp install_flash_player_7_linux]# ls
flashplayer-installer* libflashplayer.so* Readme.txt
flashplayer.xpt Readme.htm
[root@amd1800xp install_flash_player_7_linux]# ./flashplayer-installer
Copyright(C) 2002-2003 Macromedia, Inc. All rights reserved.
Macromedia Flash Player 7 for Linux
Macromedia Flash Player 7 will be installed on this machine.
You are running the Macromedia Flash Player installer as the "root" user.
Macromedia Flash Player 7 will be installed system-wide.
Support is available at http://www.macromedia.com/support/flashplayer/
To install Macromedia Flash Player 7 now, press ENTER.
To cancel the installation at any time, press Control-C.
NOTE: Macromedia Flash Player requires two font packages
to be installed, ttfonts and urw-fonts.
Press ENTER to continue...
NOTE: Please exit any browsers you may have running.
Please enter the installation path of the Mozilla, Netscape,
or Opera browser (i.e., /usr/lib/mozilla): /usr/lib/mozilla/plugins
WARNING: Please enter a valid installation path.
Marsh Posté le 01-09-2004 à 12:51:06
mets juste /usr/lib/mozilla/
si la 9.2 utilise mozilla 1.6, tu peux essayer aussi : /usr/lib/mozilla-1.6
Marsh Posté le 01-09-2004 à 13:55:20
encoe et toujours
or Opera browser (i.e., /usr/lib/mozilla): /usr/lib/mozilla-1.6
WARNING: /usr/lib/mozilla-1.6 is not a directory.
avec konqueror y a pas moyen ?
j'vais installer mozilla alors
Marsh Posté le 01-09-2004 à 14:11:02
Y'a aussi des paquets officiels ici :
http://macromedia.rediris.es/site_ri.html
| Citation : This is the official mirror system of Macromedia Linux packages. |
Marsh Posté le 01-09-2004 à 14:12:42
j'commence à désespérer j'ai fait urpmi mozilla
et arès l'installation de mozilla ca ne marche toujours pas
Marsh Posté le 01-09-2004 à 15:15:32
donne le résultat de la commande suivante :
ls -l /usr/lib/mozilla*
Marsh Posté le 01-09-2004 à 16:21:40
c assé long
[lepirlouit@amd1800xp lepirlouit]$ su
Password:
[root@amd1800xp lepirlouit]# ls -l /usr/lib/mozilla*
/usr/lib/mozilla:
total 4
drwxr-xr-x 2 root root 4096 aoû 10 00:58 plugins/
/usr/lib/mozilla-1.4:
total 2820
drwxr-xr-x 4 root root 4096 sep 1 14:02 chrome/
drwxr-xr-x 2 root root 8192 sep 1 14:02 components/
drwxr-xr-x 7 root root 4096 sep 1 14:02 defaults/
-rwxr-xr-x 1 root root 165488 aoû 10 00:58 libgkgfx.so*
-rwxr-xr-x 1 root root 142928 aoû 10 00:58 libgtkembedmoz.so*
-rwxr-xr-x 1 root root 15456 aoû 10 00:58 libgtkxtbin.so*
-rwxr-xr-x 1 root root 117168 aoû 10 00:58 libjsj.so*
-rwxr-xr-x 1 root root 179504 aoû 10 00:58 libldap50.so*
-rwxr-xr-x 1 root root 88212 aoû 10 00:58 libmoz_art_lgpl.so*
-rwxr-xr-x 1 root root 552944 aoû 10 00:58 libmozjs.so*
lrwxrwxrwx 1 root root 16 sep 1 14:02 libnssckbi.so -> ../libnssckbi.so*
-rwxr-xr-x 1 root root 15376 aoû 10 00:58 libprldap50.so*
-rwxr-xr-x 1 root root 48588 aoû 10 00:58 libxlibrgb.so*
-rwxr-xr-x 1 root root 127152 aoû 10 00:58 libxpcom_compat.so*
-rwxr-xr-x 1 root root 984848 aoû 10 00:58 libxpcom.so*
-rwxr-xr-x 1 root root 14252 aoû 10 00:58 libxpistub.so*
-rwxr-xr-x 1 root root 229360 aoû 10 00:58 mozilla-bin*
-rwxr-xr-x 1 root root 2378 aoû 10 00:58 mozilla-rebuild-databases.pl*
-rwxr-xr-x 1 root root 9300 aoû 10 00:58 mozilla-xremote-client*
drwxr-xr-x 2 root root 4096 sep 1 14:02 plugins/
-rwxr-xr-x 1 root root 4064 aoû 10 00:58 regchrome*
-rwxr-xr-x 1 root root 52492 aoû 10 00:58 regxpcom*
drwxr-xr-x 9 root root 4096 sep 1 14:02 res/
-rwxr-xr-x 1 root root 10998 avr 19 2003 run-mozilla.sh*
drwxr-xr-x 2 root root 4096 sep 1 14:02 searchplugins/
-rwxr-xr-x 1 root root 30264 aoû 10 00:58 xpicleanup*
Marsh Posté le 01-09-2004 à 16:32:08
c'est mozilla-1.4 sur la 9.2 à ce que je vois.
Marsh Posté le 03-09-2004 à 11:27:43
T'aurais pu le résoudre tout seul quand meme, en regardant les dossiers dispo dans /usr/lib , et identifier celui de Mozilla 1.4.
Marsh Posté le 01-09-2004 à 11:15:18
en me connectant en tant que root je n'arrive pas à installer le plugin de flash player
il met dit soit que lerépertoire n'existe pas soit qu'il n'est pas valide
car il me demande le répertoire ou je veut l'installer
Message édité par lepirlouit le 02-09-2004 à 18:47:38
