[Topik unique] DFI RS482 Infinity
DFI RS482 Infinity [Topik unique] - Mini PC - Hardware
Marsh Posté le 02-03-2006 à 18:28:06
Voici le topik unique de la DFI au format micro atx: la DFI rs482 Infinity
Avant toute chose je tiens a preciser que c'est mon 1er topic unique donc si il y a des améliorations à faire n'hésitez pas.
http://www.hardwarezone.com/img/data/nnews/2006/3616/Image/8.JPG
Caractéristiques:
 CPU
 AMD Athlon 64 X2 / Athlon 64 FX / Athlon 64 / Sempron
Socket 939
  Front Side Bus
 2000MT/s HyperTransport interface
  Chipset
 ATI chipset
    - North bridge: ATI Radeon Xpress 200 RS482
    - South bridge: ATI SB450
  Memory
 Four 184-pin DDR SDRAM DIMM sockets
Supports dual channel (128-bit wide) memory interface
Supports up to 4GB system memory
Supports PC2100 (DDR266), PC2700 (DDR333) and PC3200 (DDR400) DDR SDRAM DIMM
  Expansion Slots
 1 PCI Express x16 slot
1 PCI Express x1 slot
2 PCI slots
  BIOS
 Award BIOS
4Mbit flash memory
  Power Management
 ACPI and OS Directed Power Management
ACPI STR (Suspend to RAM) function
Wake-On-PS/2 Keyboard/Mouse
Wake-On-USB Keyboard/Mouse
Wake-On-LAN
Wake-On-Ring
RTC timer to power-on the system
AC power failure recovery
  Hardware Monitor
 Monitors CPU/system temperature
Monitors 5V/12V/3.3V/5VSB/Vbat/Vcore/Vdimm/Vchip voltages
Monitors the speed of the cooling fans
CPU Overheat Protection function monitors CPU temperature during system boot-up
  Graphics
 Integrated ATI Radeon X300 GPU
DirectX 9.0 graphics core
Interfaces:
    - VGA to connect VGA monitor
    - DVI-D to connect devices that support DVI-D
    - TV-out to connect a TV with S-Video output, Composite video output or
      HDTV (Y/Pb/Pr component) video output
Dual display using DVI-D + TV-out or DVI-D + VGA interfaces
    - devices connected to these interfaces can be displayed simultaneously
SurroundView allows up to 4 independent displays by adding a graphics card
    (only ATI graphics card supported)
  Audio
 Realtek ALC850 8-channel AC’97 audio CODEC
  LAN
 Realtek RTL8110SB Gigabit PCI LAN
Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
  IDE
 Two IDE connectors support up to four UltraDMA 133Mbps hard drives
  Serial ATA with RAID
 Supports four Serial ATA ports
SATA speed up to 1.5Gb/s
RAID 0 and RAID 1
  IEEE 1394
 VIA VT6307
Supports two 100/200/400 Mb/sec ports
  Rear Panel I/O Ports
 1 mini-DIN-6 PS/2 mouse port
1 mini-DIN-6 PS/2 keyboard port
1 optical S/PDIF
1 TV-out port
1 VGA monitor port
1 DVI-D port
1 IEEE 1394 port
1 RJ45 LAN port
4 USB 2.0/1.1 ports
Center/subwoofer, rear R/L and side R/L jacks
Line-in, line-out (front R/L) and mic-in jacks
  I/O Connectors
 2 connectors for 4 additional external USB 2.0/1.1 ports
1 connector for 1 external COM port
1 connector for 1 external IEEE 1394 port
1 front audio connector for external line-out and mic-in jacks
1 CD-in internal audio connector
1 coaxial S/PDIF connector
1 IrDA connector
4 Serial ATA connectors
2 IDE connectors
1 floppy connector
1 24-pin ATX main power connector
1 4-pin ATX 12V power connector
1 front panel connector
3 fan connectors
  PCB
 microATX form factor
24.4cm (9.6" ) x 24.4cm (9.6" )
(sources dfi.com)
Test en anglais :
http://www.madshrimps.be/?action=g [...] rticID=416
http://www.vr-zone.com/?i=3213&s=1
Ou la trouver?
Pour l'instant il n'y a pas beaucoup de magasins qui la vendent en europe.
en France:
http://boutique.3dchips-fr.com/pro [...] ts_id/3365 pour 107e livrée. (site déconseillé)
www.pcshop88.com
Liens Utiles:
Bios:
http://us.dfi.com.tw/Support/Downl [...] =A&SITE=US
Bios Beta:
http://us.dfi.com.tw/Support/Downl [...] =B&SITE=US
http://www.lejabeach.com/DFI/dfirs482i/dfirs482i.html
Forum DFI:
http://www.dfi-street.com/forum/index.php
Mon compte rendu:
http://forum.hardware.fr/forum2.ph [...] =0#t420230
j'ai monter un rad zalman sur le chipset
 http://img105.imagevenue.com/loc318/th_97915_rad_zalman_122_318lo.JPG
voici le rad d'origine:
 http://img25.imagevenue.com/loc472/th_97908_rad_dfi_122_472lo.JPG
gain observé:
rad d'origine en full ---> 50°c
rad zalman en full ---> 44°c
pour 5€ a peut pres 5°c de gagné
Message édité par sdif18 le 02-09-2006 à 13:57:11
Marsh Posté le 02-03-2006 à 20:40:46
et bien ça n'attire pas grand monde
Marsh Posté le 03-03-2006 à 12:58:20
personne???? ro le bide total
Marsh Posté le 03-03-2006 à 13:01:49
ben le southbridge est merdique donc les gens ne sont pas attiré par ce genre de carte d'autant que chez le concurrent on a du 100% fonctionnel avec le support purevideo pour le même prix :/
Marsh Posté le 03-03-2006 à 13:37:36
et puis à titre perso le µATX est encore trop grand...
Pour moi c'est mini ITX (genre DFI-ACP) ou 3"5 (Commell) !!!
Mais courage ca peut en interesser certains...
Marsh Posté le 03-03-2006 à 17:26:19
en fait il y a tres peu de carte micro atx qui permette d'atteindre de haut fsb, il n'y a que celle ci et la biostar tforce
boober pourquoi tu dis que le southbridge est merdique?
Marsh Posté le 03-03-2006 à 17:30:16
Pour le SB450 : pbs de débits en USB 2.0 et taux d'utilisation cpu elevé pour les peripheriques [:spamafote]
Ce n'est pas pour rien que la plupart des fabricants mettent un southbridge uli a la place ;)
Marsh Posté le 03-03-2006 à 17:34:10
ok ok merci de l'info je n'était pas au courant
Marsh Posté le 03-03-2006 à 21:02:59
Merci pour ces infos, mais a priori il y a quelque soucis avec le SB450. Donc quelle est la meilleur entre celle ci et la Biostar TForce 6100 ?
Esce un bon investissement ?
Marsh Posté le 03-03-2006 à 21:50:25
le soucis avec la biostar c'est qu'il n'y a que 2 port sata et moi j'en aurais besoin de 3
le chip ati rs482 est un peu plus evolué et est compatible hdtv alors que le 6100 non
le 6100 a fais ces preuves alors que le rs482 non
Marsh Posté le 04-03-2006 à 02:04:58
je squate :bounce:
Marsh Posté le 04-03-2006 à 16:33:26
uppppppppppppppppppppppppp
Marsh Posté le 04-03-2006 à 20:19:29
malgré les 2-3 probleme cité je crois que je vais quand meme me l'acheter je vais recevoir mon opty 146 dans la mois j'espere pouvoir me payé cette carte le mois prochain
wait and see....
Marsh Posté le 08-03-2006 à 13:32:35
Yop, j'aurais voulu savoir si cette mobo accépter des disques Raptor ?
Marsh Posté le 08-03-2006 à 17:38:56
pourquoi elle ne l'ai accepterais pas?
si ils passent sur la dfi laparry crossfire ils passent aussi sur celle ci
Marsh Posté le 08-03-2006 à 17:40:04
ouip, jusqu'à 4 DD sata peuvent être connectés
Слава Україні  Feedback
Marsh Posté le 12-03-2006 à 17:13:44
j'ai commandé ma dfi chez 3dchips avec un adaptateur 20-->24pins j'en ai eu pour 111e fdpin
je dois recevoir la recevoir entre 2 et 5j et je devrais avoir mon opteron samedi prochain
je tiens le post a jour avec des photos
Marsh Posté le 15-03-2006 à 23:16:54
salut! jeune sdif18 skywaker.....
en effet cette mobo est interessante.
dans quelle but cette base de configue????le surroundview...multi ecran
bien j en ai fait lexperience a mes frais et un pietre resultat.....
enfin ca depend de l interet du multi ecran en 2d rien a dire tu peux afficher 3 ou 4 ecran sans problemes mais pour jouer , pas pareil...(niet)...
sinon la dfi semble offrir plus de reglages dans le bios et la prise dv-i chose promise sur le rs480 (arlesienne) quand aux soit disant pb usb ben je vois pas.
  bon @+ jeune padawan
Marsh Posté le 15-03-2006 à 23:25:02
arhhh pas la signature......MSI xpress 200 rs480sb400- A64 3800+  -zalman9500-corsair cmx 2x1 go- x800xl pwr clr -  xfi ftl1ty -logitech z680 -  alim tagan 480w easy conect
Marsh Posté le 16-03-2006 à 07:39:51
c'est clair que le chip integré est celui d'une x300 donc ce n'est pas fais pour jouer
je compte aussi me prendre une x800xl par la suite
Marsh Posté le 16-03-2006 à 13:27:24
re: )
bien sur le x300 pour 2d et video suffit,pour le jeu moins,mais c est le multi ecra qui m interesse,le truc c est qu en branchant 3 ecrans,(2 sur la x800xl et un sur le x 300) je ne reussi pas a afficher (fondre) le jeu sur les 3 ecrans. il semble que ce ne soit pas vraiment prevupour cela....la pourtant j ai essayé mille manieres avec control panel et ati traytool ....une astuce pourtant c est de demarrer le jeu en mode fenetre et de l etirer sur les trois ecran,la ca marche tres bien mais ca fait un image ratatinée....heu ptite precision c est la carte graphique additionelle qui prend en charge le graphisme....j espere etre assez clair dans mes explications...  mais je ne desespere pas de fragger sur 3 ecran un jour....bon @+    ;)
Marsh Posté le 16-03-2006 à 17:16:15
pour du 3 ecran il faudrait plus un sli ou un crossfire avec 2 carte graphique
car la ce n'est pas etudier pour
Marsh Posté le 18-03-2006 à 17:34:19
ma dfi se laisse désiré
il y a des retard d'approvisionnement a cause du cebit apparamment
j'aurais mon pross lundi, esperont que la dfi suive
Marsh Posté le 24-03-2006 à 21:36:51
bon alors j'ai reçu mon opty 146 lundi dernier et je n'ai toujours pas ma dfi
3d chips galere vraiment, je déconseille cette boutique qui est a peine joignable et qui n'a pas l'air très sérieuse (ça fais 1 semaine qu'on me dis que ma commande va etre expédier)
Marsh Posté le 29-03-2006 à 18:05:49
me revoila pour vous tenir au courant.
3dchips ne m'a toujours pas envoyé la carte, d'apres eux elle n'est dispo en europe que le 10/04. J'ai demandé un remboursement mais voila la galere.
Mais j'ai trouvé un autre site qui la vend, pcshop88. J'ai fais la commande ce matin et mon colis a été expédier dans la journée.
Si tout va bien je monterais tout ça ce week end.
sinon j'ai trouvé un forum sympa mais en anglais sur toute les dfi.
je l'ai mis en 1ere page
Marsh Posté le 30-03-2006 à 20:34:13
ça y es j'ai reçu la bete.
je l'ai monté mais j'ai pas eu bien le temps de tout testé
pour l'instant elle est a 250 de fsb sans rien toucher (a part passé le htt en 4x)
voila les photos pour ce week end ou alors demain si je suis courageux
Marsh Posté le 01-04-2006 à 15:35:06
salut tous le monde
voici mon compte rendu de cette mobo.
Je l'ai commandé sur Pcshop88, livré en 24h.
voici les photos de la bête quand je l'ai reçu:
http://sdif18.free.fr/DFI%20RS482/boite.jpg
http://sdif18.free.fr/DFI%20RS482/bundle.jpg
http://sdif18.free.fr/DFI%20RS482/mobo.jpg
http://sdif18.free.fr/DFI%20RS482/vue%20.jpg
Avec son opteron 146 deçu:
http://sdif18.free.fr/DFI%20RS482/mobo%20opty.jpg
Avec un zalman 7000b cu:
http://sdif18.free.fr/DFI%20RS482/ [...] nt%e9e.jpg
ça passe juste au niveau des barettes:
http://sdif18.free.fr/DFI%20RS482/zalman%20ddr.jpg
voila pour les photos.
Ensuite passons au bios, j'ai mis le derniers bios beta, il reconnait de suite mon opteron et affine les reglages du vcore (0.8v a 1.85v)
Avec j'ai pu booter a 300mhz de fsb mais pas avec mes crucials ballistix car elles n'ont pas l'air d'etre trop aimé par la dfi, impossible de desynchro alors qu'avec mes samsung pc2700 aucun soucis.
J'utilise le chip video intégré, c'est celui d'un x300 mais la memoire est partagé avec la ddr, on peut reglé dans le bios combien on veut partagé (pour ma part 64mo ).
J'ai aussi utilisé un adaptateur 20--> 24pins pour l'alimentation, je n'ai pas essayé sans mais dans la notice il n'est pas écrit qu'il en fait un obligatoirement.
En gros le bilan est plutot positif:
+ fonction du bios
+ permet de mettre un gros rad et refoidit la ram en meme temps
+ completement passive
+ hdtv
+ pas besoin de faire des clear cmos car elle le fait toute seule
- le fait qu'elle n'aime pas mes barettes (crucial ballistix pc4000 chips micron)
- il y aurait pu y avoir des nappes rondes
- placement des slot ddr pour le dual channels (ils sont l'un a coté de l'autre et les barettes chauffent plus)
Voila en esperant vous avoir un peu mieux renseigné sur cette carte
Message édité par sdif18 le 01-04-2006 à 16:57:52
Marsh Posté le 03-04-2006 à 18:09:07
j'ai pousser un peu la bete ce week-end
le max fsb que j'ai fais 9*315
apres il faut toucher au voltage du chipset, j'ai fais 9*320 a 1.3v pour le chipset
Marsh Posté le 08-04-2006 à 15:34:39
sympa cette cm, le nb chauffe pas trop ?
Marsh Posté le 08-04-2006 à 17:17:13
smartguardian me donne 27°c pour le chipset donc y pas a ce plaindre
Marsh Posté le 18-04-2006 à 18:48:44
ajout d'un lien de bios
Marsh Posté le 01-05-2006 à 14:23:45
la sortie tv est bonne? elle gere bien le double affichage
Marsh Posté le 01-05-2006 à 16:50:35
je trouve la sortie tv correct,
je l'utilise sur un lcd thomson 66cm .
Marsh Posté le 02-05-2006 à 15:33:28
au niveau du transfert usb c'est vraiment aussi faible qu'il est dit
ou bien ça reste correct
Marsh Posté le 02-05-2006 à 18:04:38
l'usb je ne m'en sert que pour mon mp3 et le bluetooth
ça va plus qu'avec mon abit an7 c'est une certitude apres faut voir avec du nforce4 mais a mon avis ça doit pas changer des masses.
Marsh Posté le 08-05-2006 à 11:25:56
salut
je voudrai savoir quel est la frequence de proc maxi que l'on peut installer decu la rs482.
merci d'avance
Message édité par harleydavidson le 08-05-2006 à 11:26:12
Marsh Posté le 08-05-2006 à 13:27:28
on peut mettre tous les proc socket 939
Marsh Posté le 08-05-2006 à 19:51:36
Marsh Posté le 15-05-2006 à 00:50:16
up j'suis interessé :D
mon topic de vente
Marsh Posté le 12-06-2006 à 09:41:12
plus de news?
303 Ex-ƒeedßacks à jour + ToPiC  Achète matos ferroviaire HO
