probleme de gravure sur CD et DVD avec nero 7 [resolu] - CD/DVD/BD - Hardware
Marsh Posté le 11-11-2005 à 20:50:43
bonsoir.
si ca peut aider quelqu'un je post ma derniere gravure vue par nerohistory
====== *** Nero Burning ROM, History File *** ======
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02/11/2004 12:54:32
NT-SPTI used
Nero Version: 7.0.1.2
Internal Version: 7, 0, 1, 2
Recorder: <_NEC DVD_RW ND-2500A> Version: 1.0A - HA 1 TA 3 - 7.0.1.2
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <JLMS XJ-HD166S >Version: DIS3 - HA 1 TA 0 - 7.0.1.2
=== Scsi-Device-Map ===
DiskPeripheral : Maxtor 6B200P0 atapi Port 0 ID 0 DMA: On
DiskPeripheral : ST3120023A atapi Port 0 ID 1 DMA: On
CdRomPeripheral : JLMS XJ-HD166S atapi Port 1 ID 0 DMA: On
CdRomPeripheral : _NEC DVD_RW ND-2500A atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
_NEC DVD_RW ND-2500A F: CDRom3
JLMS XJ-HD166S I: CDRom0
AutoRun : 0
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 767MB (785904kB)
Free physical memory: 317MB (324736kB)
Memory in use : 58
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
11.11.2005
Audio CD
15:42:16 #1 CDADOC -1 File Cdadoc.cpp, Line 1507
Audio item log info:
Audio document burn settings:
Burn mode: DAO,
CD Text: On,
Cache disk or network files: No,
Cache small files: No,
Cache files smaller than 65536 bytes.
Audio Multisession: No
List of audio tracks:
Track 01: Length: 05:36.28, Pause frames: 150, Filters: 0, Name: '01-madonna-hung_up.mp3'.
Track 02: Length: 05:30.43, Pause frames: 150, Filters: 0, Name: '02-madonna-get_together.mp3'.
Track 03: Length: 04:43.26, Pause frames: 150, Filters: 0, Name: '03-madonna-sorry.mp3'.
Track 04: Length: 04:51.27, Pause frames: 150, Filters: 0, Name: '04-madonna-future_lovers.mp3'.
Track 05: Length: 04:11.53, Pause frames: 150, Filters: 0, Name: '05-madonna-i_love_new_york.mp3'.
Track 06: Length: 04:18.43, Pause frames: 150, Filters: 0, Name: '06-madonna-let_it_will_be.mp3'.
Track 07: Length: 04:22.22, Pause frames: 150, Filters: 0, Name: '07-madonna-forbidden_love.mp3'.
Track 08: Length: 03:46.38, Pause frames: 150, Filters: 0, Name: '08-madonna-jump.mp3'.
Track 09: Length: 04:40.10, Pause frames: 150, Filters: 0, Name: '09-madonna-how_high.mp3'.
Track 10: Length: 06:03.50, Pause frames: 150, Filters: 0, Name: '10-madonna-isaac.mp3'.
Track 11: Length: 03:57.08, Pause frames: 150, Filters: 0, Name: '11-madonna-push.mp3'.
Track 12: Length: 04:31.74, Pause frames: 150, Filters: 0, Name: '12-madonna-like_it_or_not.mp3'.
Total size: 56:57.47
15:42:16 #2 Text 0 File Burncd.cpp, Line 3008
Buffer underrun protection activated
15:42:16 #3 Text 0 File ThreadedTransfer.cpp, Line 525
ReadBuffer-Pipe got 81920KB of Memory
15:42:16 #4 Text 0 File Reader.cpp, Line 124
Reader running
15:42:16 #5 Text 0 File Writer.cpp, Line 113
Writer F: _NEC DVD_RW ND-2500A running
15:42:16 #6 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
15:42:16 #7 Text 0 File Burncd.cpp, Line 3302
Turn on Disc-At-Once, using CD-R/RW media
15:42:16 #8 Text 0 File DlgWaitCD.cpp, Line 279
Last possible write address on media: 359845 ( 79:59.70)
Last address to be written: 256171 ( 56:57.46)
15:42:16 #9 Text 0 File DlgWaitCD.cpp, Line 291
Write in overburning mode: NO (enabled: CD)
15:42:16 #10 Text 0 File DlgWaitCD.cpp, Line 2578
Recorder: _NEC DVD_RW ND-2500A
15:42:16 #11 Text 0 File DlgWaitCD.cpp, Line 458
>>> Protocol of DlgWaitCD activities: <<<
15:42:16 #12 Text 0 File ThreadedTransferInterface.cpp, Line 847
Setup items (after recorder preparation)
0: TRM_AUDIO_NOPRE (01-madonna-hung_up.mp3)
2 indices, index0 (150) not provided
original disc pos #0 + 25228 (25228) = #25228/5:36.28
relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 25228 blocks [F: _NEC DVD_RW ND-2500A]
1: TRM_AUDIO_NOPRE (02-madonna-get_together.mp3)
original disc pos #0 + 24793 (24793) = #24793/5:30.43
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 24793 blocks [F: _NEC DVD_RW ND-2500A]
2: TRM_AUDIO_NOPRE (03-madonna-sorry.mp3)
original disc pos #0 + 21251 (21251) = #21251/4:43.26
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21251 blocks [F: _NEC DVD_RW ND-2500A]
3: TRM_AUDIO_NOPRE (04-madonna-future_lovers.mp3)
original disc pos #0 + 21852 (21852) = #21852/4:51.27
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21852 blocks [F: _NEC DVD_RW ND-2500A]
4: TRM_AUDIO_NOPRE (05-madonna-i_love_new_york.mp3)
original disc pos #0 + 18878 (18878) = #18878/4:11.53
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18878 blocks [F: _NEC DVD_RW ND-2500A]
5: TRM_AUDIO_NOPRE (06-madonna-let_it_will_be.mp3)
original disc pos #0 + 19393 (19393) = #19393/4:18.43
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19393 blocks [F: _NEC DVD_RW ND-2500A]
6: TRM_AUDIO_NOPRE (07-madonna-forbidden_love.mp3)
original disc pos #0 + 19672 (19672) = #19672/4:22.22
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19672 blocks [F: _NEC DVD_RW ND-2500A]
7: TRM_AUDIO_NOPRE (08-madonna-jump.mp3)
original disc pos #0 + 16988 (16988) = #16988/3:46.38
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16988 blocks [F: _NEC DVD_RW ND-2500A]
8: TRM_AUDIO_NOPRE (09-madonna-how_high.mp3)
original disc pos #0 + 21010 (21010) = #21010/4:40.10
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21010 blocks [F: _NEC DVD_RW ND-2500A]
9: TRM_AUDIO_NOPRE (10-madonna-isaac.mp3)
original disc pos #0 + 27275 (27275) = #27275/6:3.50
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 27275 blocks [F: _NEC DVD_RW ND-2500A]
10: TRM_AUDIO_NOPRE (11-madonna-push.mp3)
original disc pos #0 + 17783 (17783) = #17783/3:57.8
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17783 blocks [F: _NEC DVD_RW ND-2500A]
11: TRM_AUDIO_NOPRE (12-madonna-like_it_or_not.mp3)
original disc pos #0 + 20399 (20399) = #20399/4:31.74
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20399 blocks [F: _NEC DVD_RW ND-2500A]
15:42:16 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [F: _NEC DVD_RW ND-2500A] for write in CUE-sheet-DAO
DAO infos:
MCN: " "
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 12:
1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 59689056, ISRC ""
2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 59689056 60041856 118354992, ISRC ""
3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 118354992 118707792 168690144, ISRC ""
4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 168690144 169042944 220438848, ISRC ""
5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 220438848 220791648 265192704, ISRC ""
6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 265192704 265545504 311157840, ISRC ""
7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 311157840 311510640 357779184, ISRC ""
8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 357779184 358131984 398087760, ISRC ""
9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 398087760 398440560 447856080, ISRC ""
10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 447856080 448208880 512359680, ISRC ""
11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 512359680 512712480 554538096, ISRC ""
12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 554538096 554890896 602869344, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
-150 | lead-in | 0 | 0x01 | 0x00
-150 | 1 | 0 | 0x21 | 0x00
0 | 1 | 1 | 0x21 | 0x00
25228 | 2 | 0 | 0x21 | 0x00
25378 | 2 | 1 | 0x21 | 0x00
50171 | 3 | 0 | 0x21 | 0x00
50321 | 3 | 1 | 0x21 | 0x00
71572 | 4 | 0 | 0x21 | 0x00
71722 | 4 | 1 | 0x21 | 0x00
93574 | 5 | 0 | 0x21 | 0x00
93724 | 5 | 1 | 0x21 | 0x00
112602 | 6 | 0 | 0x21 | 0x00
112752 | 6 | 1 | 0x21 | 0x00
132145 | 7 | 0 | 0x21 | 0x00
132295 | 7 | 1 | 0x21 | 0x00
151967 | 8 | 0 | 0x21 | 0x00
152117 | 8 | 1 | 0x21 | 0x00
169105 | 9 | 0 | 0x21 | 0x00
169255 | 9 | 1 | 0x21 | 0x00
190265 | 10 | 0 | 0x21 | 0x00
190415 | 10 | 1 | 0x21 | 0x00
217690 | 11 | 0 | 0x21 | 0x00
217840 | 11 | 1 | 0x21 | 0x00
235623 | 12 | 0 | 0x21 | 0x00
235773 | 12 | 1 | 0x21 | 0x00
256172 | lead-out | 1 | 0x01 | 0x00
15:42:16 #14 Text 0 File SCSIPassThrough.cpp, Line 36
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
15:42:16 #15 Phase 36 File dlgbrnst.cpp, Line 1725
Burn process started at 32x (4 800 KB/s)
15:42:16 #16 SPTI -1189 File SCSIPassThrough.cpp, Line 323
F: CdRom3: SCSIStatus(x02) WinError(0) NeroError(-1189)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x30
Sense Qual: 0x02
CDB Data: 0xAD 00 00 00 00 00 00 FF 40 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 30 02
Buffer x0569b000: Len x4000
15:42:16 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
15:42:16 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #25378
15:42:16 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #50321
15:42:16 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #71722
15:42:16 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #93724
15:42:16 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #112752
15:42:16 #23 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #132295
15:42:16 #24 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #152117
15:42:16 #25 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #169255
15:42:16 #26 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #0): write at #190415
15:42:16 #27 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #0): write at #217840
15:42:16 #28 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #0): write at #235773
15:42:16 #29 Text 0 File MMC.cpp, Line 16932
StartDAO : CD-Text - On
15:42:16 #30 Text 0 File MMC.cpp, Line 21611
Set BUFE: Buffer underrun protection -> ON
15:42:16 #31 Text 0 File MMC.cpp, Line 17165
CueData, Len=208
21 00 00 41 00 00 00 00
21 01 00 00 00 00 00 00
21 01 01 00 00 00 02 00
21 02 00 00 00 05 26 1c
21 02 01 00 00 05 28 1c
21 03 00 00 00 0b 0a 47
21 03 01 00 00 0b 0c 47
21 04 00 00 00 0f 38 16
21 04 01 00 00 0f 3a 16
21 05 00 00 00 14 31 31
21 05 01 00 00 14 33 31
21 06 00 00 00 19 03 1b
21 06 01 00 00 19 05 1b
21 07 00 00 00 1d 17 46
21 07 01 00 00 1d 19 46
21 08 00 00 00 21 30 11
21 08 01 00 00 21 32 11
21 09 00 00 00 25 24 37
21 09 01 00 00 25 26 37
21 0a 00 00 00 2a 12 41
21 0a 01 00 00 2a 14 41
21 0b 00 00 00 30 18 28
21 0b 01 00 00 30 1a 28
21 0c 00 00 00 34 17 30
21 0c 01 00 00 34 19 30
01 aa 01 01 00 38 39 2f
15:45:01 #32 Text 0 File WriterStatus.cpp, Line 116
<F: _NEC DVD_RW ND-2500A> start writing Lead-Out at LBA 256172 (3E8ACh), length 0 blocks
15:45:01 #33 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
15:45:13 #34 Phase 37 File dlgbrnst.cpp, Line 1725
Burn process completed successfully at 32x (4 800 KB/s)
15:45:14 #35 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
15:45:14 #36 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Marsh Posté le 11-11-2005 à 21:20:12
Enleve le serial !
Tes fichiers ont une protection DRM ?
Sinon, mets le graveur en maître.
Marsh Posté le 11-11-2005 à 21:52:38
Oups le serial! lol
Merci de ta reponse harel.
Mes fichiers n'ont pas de protection DRM. ils viennent d'un peu tous les horizons et sont sur mon disque dur...donc pas de copie a la volée.
Mon graveur est deja en maitre! J'ai fais le test de le passer en esclave mais comme ca n'a rien donné je l'ai remis en maitre.
Marsh Posté le 11-11-2005 à 22:19:30
Tu es sûr qu'il est en maître ?
Regardes aussi dans Nero Infotools onglet "Configuration"
Marsh Posté le 11-11-2005 à 22:23:20
oui oui completement sur!!!! le log a été fais apres mon essai en esclave!
desolé de la confusion!
c"est donc inversé maintenant
Marsh Posté le 11-11-2005 à 22:50:22
Où il est question
- de graver en DAO et non TAO
- de changer les drivers IDE pour ceux de Microsoft
- d'installer de nouveau la bonne couche aspi ( cherche Forceaspi)
- de feurio et de son diagnosric audio
http://club.cdfreaks.com/showthrea [...] ling+sound
Marsh Posté le 12-11-2005 à 13:49:29
Alors voila, ce matin reinstallation de la couche ASPI avec forceaspi 1.17 puis 1.18 et toujours le meme probleme...
Marsh Posté le 12-11-2005 à 20:41:19
Aucune modif software ? Laisse tomber Nero 7 et retourne en 6.6.0.16 ou 18.
Et puis grave un peu moins vite l'audio : je préfère 16X ou 24X max au 32X/40X.
Marsh Posté le 12-11-2005 à 20:49:08
Ouais, je viens juste d'éditer : je suis en train de la télécharger
Faut penser à décocher la Yahoo ToolBar...
Et pas encore de changelog
Marsh Posté le 12-11-2005 à 22:40:26
ben je suis encore en train de faire des tests et la je suis carrement revenu à la version 6.3.1.6...et ca a l'air d'aller mieux...
mais j'ai aussi rechanger ma nappe idée qui me semblait louche (fils bien trop pliés a mon gout et risque de coupure)
j'ai en stock la 6.6.0.18 mais je verra ca demain! je vous remercie pour vos infos et je vous tiens au courant de l'evolution de mon affaire!
Marsh Posté le 13-11-2005 à 19:45:42
bonsoir a tous...
un petit passage vite fait pour vous comfirmer que pour ma part, c'est nero 7.0.1.2 qui foutait la merde... je suis repassé a 6.6.0.18 et la c'est beaucoup mieux...pour confirmer mes dires j'ai remis la 7 premium puis ultra pour un ultime test et remerdouille.
Du coup si vous aussi vous rencontrez des problemes avec les versions 7, faites le savoir!
Merci à vous qui m'avez ecouté! Ciao et a charge de revanche...
Marsh Posté le 13-11-2005 à 19:50:41
Merci pour le retour.
Beaucoup de vieux briscards recommandent effectivement d'attendre quelques mois avant de passer à Nero 7.
Marsh Posté le 01-11-2006 à 12:06:51
J'ai egalement le meme pb : à l'ecoute du cd, il y a des coupures sur les chansons comme des scratchs.
Je pensais que cela venait de mon graveur ou CDR.
Je reinstalle l'ancienne version et vous tiens au courant.
Marsh Posté le 19-01-2007 à 18:27:31
slt atous!!! mon probleme a moi c'est que le cd se grave sans probleme mais quand je lis avec le pc ou quoi ke soi d'otre il reconnait rien le cd est vide et en + il bousille un cd a chaque fois...la clef de nero 7 marche t-elle avec le 6???? merci d'avance
Marsh Posté le 19-01-2007 à 19:07:18
je ne peut plus rien graver non plus sur mon 2500 A et tout a commence depuis que j ai change de version de nero et que je suis passe du service pack 1 au service pack 2...
j aimerais bien dans un 1er temps essayer avec la version 6.6.6.0.18 voir si tout rentre dans l ordre mais je ne la trouve pas sur le site de nero...
quelqu un aurait le lien sur le site de nero pour la version 6.6.0.18 car je le trouve pas....?
a+
Marsh Posté le 11-11-2005 à 14:10:41
Bonjour à tous et merci d'avance à ceux qui se pencheront sur mon probleme.
Voila donc presque 2 ans que j'utilise un garveur NEC nd-2500A et ce sans aucun soucis: compilation audio, films et copies de sauvegarde de jeux xbox. Mais cela fait maintenant une semaine que les gravures ( cd ou dvd) ne sont plus tres bonnes sans qu'aucune modification materiel ou logiciel soient survenues. Je m'explique.
Pour une gravure audio, tout se passe bien et la gravure se fait normalement sans ausun message d'erreur. Mais à l'ecoute du cd, il y a des coupures sur les chansons comme des scratchs et c'est pas franchement agreable pour mes pitites z'oreilles. Ca se situe plutot en debut de chanson dans les 20 premieres secondes et cela ne se reproduit pas sur toutes. Pour une gravure film sur DVD, pareil la gravure se fait sans probleme mais ma platine (vieille sony) me marque disque non reconnu. Au départ j'ai mis en cause ma platine car il lui faut des DVD propres et bien gravés mais elle arrive sans soucis a me lire mes anciens films et le DVD qui ne passe pas arrive a etre lu par une platine plus recente sans probleme... j'en tire la conclusion suivante: la lentille de mon graveur a perdu de son "mordant". Ca pourrai coller et repondre au probleme des cd audio par la meme occasion. Pour confirmer mon idée, je me fais preter un graveur lg par un copain et l'essaye sur ma tour... Et je m'appercois a mon grand desespoir que le resultat est le meme. toujours les meme defauts. mon graveur est donc a ecarter du probleme je pense. Ayant recuperé un nouvel os, j'ai tenté un formatage histoire
de remettre mon UC toute propre mais le probleme est toujours present. Pour info j'ai aussi tenté de changer la nappe IDE, de passer mon graveur en esclave.... rien rien rien a faire.
Voila donc mon histoire et mes desboires... Je me pause la question de la carte mere qui aurai une merde...je sais plus là
Si quelqu'un a une idée a me soummettre ou une manip a me faire faire, n'hesitez pas. Merci
Message édité par gazafond le 13-11-2005 à 20:19:52
