creation Chaine Hifi
creation Chaine Hifi - Hardware
Marsh Posté le 31-05-2002 à 19:49:38
Voila est ce qu'il est possible de créer avec son ordinateur une chaine Hifi/lecteur dvd qui prend en charge la lecture de mp3 et lecture de dvd?
Bien sur je veux pouvoir l'utiliser sans avoir d'ecrans, mais juste un petit affichage (comme sur les chaines hifi) pour pouvoir changer les chansons et lire le dvd?
Venez visitez mon site en construction et dites moi ce que vous en pensez.
Marsh Posté le 31-05-2002 à 19:51:23
euh ...jec rois ke HP fais ca  attend je v voir
Marsh Posté le 31-05-2002 à 19:53:55
voila je crois ke c ca
http://storage.hp-at-home.com/images/eps_products/DEC_170.JPG
HP digital entertainment center de100c
experience your digital music from the comfort of your living room
? works with your home stereo system, TV and internet connection* so you can store, organize and enjoy your music
? create personal playlists, sort your music, and burn to CD with built-in cd-writer
CD Drive Type   Play:
Single tray CD drive
Plays standard music CDs (CDDA)
Plays CD-R, CD-RW (standard music tracks and MP3)
Plays standard music CDs while storing
Write:
Rips up to 4x (encoding MP3 compressed audio)
CD-R media: up to 8x
CD-RW media: up to 4x
Disc finalization time: 2 minutes typical at 2X
Music Library   Play stored music
Automatically categorize stored music by artist, album, track and genre
Burn custom CDs (CDDA and MP3) with the built-in CD-writer
Create up to 99 play lists
Transfer music to portable player
Average time to start playing a specific track: 2 sec
Internet Radio   Listen to worldwide internet radio stations
Connectivity, Opt   Front: 1 USB
Back: 2 USB, Composite Video out, S-video out, RCA out, RCA in, S/PDIF (optical and coaxial audio out)
Power Features description   Power Consumption: 65 watts maximum
Input Voltage: 100 - 250 AC ±10%, 50/60 Hz ±3 Hz
Safety   IEC 950-compliant. Safety UL listed, EU LVD & EN 60950 compliant. Certified by Canada CSA.
Warranty Options   One-year limited hardware warranty backed by hp customer care
Control Panel   Controls: Power, CD Library, Internet Radio, Eject, Rewind, Play, Forward, Stop, Pause,
Record, Now Playing, Back, Up, Down, Left, Right, Select
Display: Vacuum Fluorescent Display (VFD); 3-line display, 32 characters/line
Shows the menu options and album information in a simplified view
Allows you to view basic information for music listening without having to turn the TV on.
 useful links
  support and troubleshooting
  drivers and downloads
  warranty upgrades
  supplies
Marsh Posté le 31-05-2002 à 19:55:53
En fait deja je veux pouvoir me le faire avec des pieces d'ordi recup, je veux pouvoir utiliser mon hdd de 40Go.
Mais sinon ce que fait HP ca a l'air pamal, si je comprend bien ca fait aussi ampli?
Marsh Posté le 31-05-2002 à 20:00:34
bien sur ke c possible de transformer un PC ke pour la lecture de MP3/CD/DVD/DivX
je croit k'ont apelle ça un divX box
une adresse a voire -> http://www.jackypc.com/
va faire un tour sur leur forum et pose leur la question ;)
Marsh Posté le 31-05-2002 à 20:00:35
de toute facon avec un ordi t obliger d'avoir un ecran pour controler , sauf si ta carte graphike suporte les vieux ecran tous petit et pourave de 5"  :D
sinon si le truc de Hp f ampli je c pas trop , il n'est pas encore commercialisé en france
Marsh Posté le 31-05-2002 à 20:26:30
ouais mais justement moi je veux unedivxbox sans ecran juste avec un petit ecran LCD de 2"
Marsh Posté le 31-05-2002 à 20:43:26
il existe des écran pour camescope de 8 cm,mais 2" keske tu veut faire avec si petie?? juste foutre le menu pour l'eteindre ?! :pt1cable:
Mieux vaut se taire et passer pour un con que de l'ouvrir et ne laisser aucun doute sur le sujet. (Coluche)
Marsh Posté le 31-05-2002 à 20:48:18
si tu veux faire ça, l'idéal c que tu programmes toi même ton interface à afficher sur le LCD, et ca m'a l'air assez cho  :ouch:
tu peux aussi te faire une interface à afficher sur la télé...
[jfdsdjhfuetppo]--Message édité par kant23 le 31-05-2002 à 20:50:56--[/jfdsdjhfuetppo]
Marsh Posté le 01-06-2002 à 00:08:09
Oui 8cm ca peut le faire je disais 2" c t juste pour dire qu'il me fallait un petit ecran. Mais si possible j'aimerais ne pas avoir l'interface windows car compliquer pour des personnes qui veulent se servir de la divxbox et qui n'y connaissent rien a l'ordinateur.
Marsh Posté le 01-06-2002 à 00:24:01
l'idéal, c'est de programmer un ptit truc en visual basic ou ce que tu veux, qui démarre tout seul quand tu allume ton ordi, comme ça quand tu insère un divx par exemple, ben il t'ouvre le fichier .avi automatiquement... :D
GPIO'4'CARS -=- Mon Feedback
Marsh Posté le 01-06-2002 à 17:55:54
Ouias c vrai ca peut etre pamal mais avec mes notoins en turbo pascal ca va etre dur de programmer quoi que ce soit...
