[Topic Officiel] eVGA P55
eVGA P55 [Topic Officiel] - Carte mère - Hardware
Marsh Posté le 11-08-2009 à 12:59:28
Powered by
http://img29.imageshack.us/img29/1069/evgap55logo.jpg
La line-up officielle du moment :
http://img132.imageshack.us/img132/8259/lineupevga.jpg
De ce slide commercial on distingue donc :
-2 mobales Micro-ATX
-4 mobales ATX
-1 mobale E-ATX
Les photos des modèles citées :
La P55 Micro
http://img18.imageshack.us/img18/5409/121lfe652krlg1.jpghttp://img18.imageshack.us/img18/5136/121lfe652krlg5.jpghttp://img88.imageshack.us/img88/4300/121lfe652krlg8.jpg
Performance
Based on Intel P55 chipset
Supports Intel Socket 1156 Processors
Memory
4 x 240-pin DIMM sockets
Dual Channel DDR3
Maximum of 16GB of DDR3 2000MHz+
Expansion Slot
2 x PCIe x8, 1 x PCIe x1
1 x 32-bit PCI, support for PCI 2.1
Storage I/O
x UltraDMA133
6 x Serial ATA 300MB/sec with support for RAID 0, RAID1, RAID 0+1, RAID5, JBOD
Integrated Peripherals
8 Channel High Definition
1 x 10/100/1000
Multi I/O
1 x PS2 Keyboard
13 x USB2.0 ports (7 external + 6 internal headers)
Audio connector (Line-in, Line-out, MIC)
FireWire
Form Factor
mATX Form Factor
Length: 9.6in - 243.84mm
Width: 9.6in - 243.84mm
Une carte micro-ATX avec le sli et un overclocking certainement très bon, bien équipée également. Elle fera le bonheur des personnes voulant une carte mère performante et passe partout :love:.
Actuellement référencée à 179.99 dollars sur le site EVGA
------------- :love: :love: :love: :love: :love: -------------
La P55 LE
http://img18.imageshack.us/img18/6588/123lfe653krlg1.jpghttp://img401.imageshack.us/img401/3466/123lfe653krlg2.jpghttp://img514.imageshack.us/img514/596/123lfe653krlg3.jpghttp://img18.imageshack.us/img18/6360/123lfe653krlg4.jpghttp://img406.imageshack.us/img406/7590/123lfe653krlg5.jpghttp://img30.imageshack.us/img30/1659/123lfe653krlg6.jpghttp://img401.imageshack.us/img401/194/123lfe653krlg7.jpghttp://img514.imageshack.us/img514/311/123lfe653krlg8.jpg
Performance
Memory
Dual Channel DDR3
Expansion Slot
1 x PCIe x16, 1 x PCIe x4, 1 x PCIe x1
3 x 32-bit PCI, support for PCI 2.1
Storage I/O
x UltraDMA133
1 x 10/100/1000
Multi I/O
1 x PS2 Keyboard
14 x USB2.0 ports (8 external + 6 internal headers)
FireWire
Form Factor
ATX Form Factor
Length: 12in - 304.8mm
Une carte ATX sympathique pour du mono carte car un seul pci-express 16x certainement très bonne également en oc. Elle fera le bonheur des personnes voulant faire un mod full black, ça me fait penser à quelqu'un tiens il se reconnaitra si il me lis :whistle.
Actuellement référencée à 169.99 dollars sur le site EVGA
La P55 SLI
http://img401.imageshack.us/img401/1983/132lfe655krlg1.jpghttp://img18.imageshack.us/img18/6253/132lfe655krlg2.jpghttp://img402.imageshack.us/img402/6813/132lfe655krlg3.jpghttp://img18.imageshack.us/img18/7/132lfe655krlg4.jpghttp://img260.imageshack.us/img260/5738/132lfe655krlg5.jpghttp://img260.imageshack.us/img260/7258/132lfe655krlg6.jpghttp://img194.imageshack.us/img194/997/132lfe655krlg7.jpghttp://img30.imageshack.us/img30/4444/132lfe655krlg8.jpg
Performance
Memory
Dual Channel DDR3
Maximum of 16GB of DDR3 2600MHz+
Expansion Slot
2 x PCIe x16/x8, 1 x PCIe x4, 1 x PCIe x1
2 x 32-bit PCI, support for PCI 2.1
Storage I/O
x UltraDMA133
8 x Serial ATA 300MB/sec with support for RAID 0, RAID1, RAID 0+1, RAID5, JBOD
2 x 10/100/1000
Multi I/O
1 x PS2 Keyboard
FireWire
Form Factor
ATX Form Factor
Une carte ATX sli compatible certainement très bonne également en oc, avec une sorte de petite lumière au centre pour l'aspect kikoo :D, bundle simple sans fioritures.
Actuellement référencée à 199.99 dollars sur le site EVGA
La P55 FTW
http://img260.imageshack.us/img260/6945/132lfe657krlg1.jpghttp://img194.imageshack.us/img194/5692/132lfe657krlg2.jpghttp://img402.imageshack.us/img402/9643/132lfe657krlg3.jpghttp://img30.imageshack.us/img30/9295/132lfe657krlg5.jpghttp://img18.imageshack.us/img18/7233/132lfe657krlg6.jpghttp://img194.imageshack.us/img194/1287/132lfe657krlg7.jpghttp://img401.imageshack.us/img401/6550/132lfe657krlg8.jpg
Performance
Memory
Dual Channel DDR3
Expansion Slot
Storage I/O
x UltraDMA133
2 x 10/100/1000
Multi I/O
1 x PS2 Keyboard
FireWire
Form Factor
ATX Form Factor
Une carte ATX sli compatible certainement très bonne également en oc, toujours la petite lumière au centre ( kikoo powered ) bundle un peu plus fourni avec l'ECP qui permet de faire pleins de bidouilles :p
Actuellement référencée à 229.99 dollars sur le site EVGA
La P55 FTW 200
http://img260.imageshack.us/img260/2959/141lfe658krlg1.jpghttp://img30.imageshack.us/img30/5707/141lfe658krlg2c.jpghttp://img514.imageshack.us/img514/6728/141lfe658krlg3.jpghttp://img194.imageshack.us/img194/6071/141lfe658krlg4.jpghttp://img194.imageshack.us/img194/5122/141lfe658krlg5.jpghttp://img18.imageshack.us/img18/6283/141lfe658krlg6.jpghttp://img406.imageshack.us/img406/9472/141lfe658krlg7.jpg
Performance
Memory
Dual Channel DDR3
Expansion Slot
3 x PCIe x16/x8, 1 x PCIe x4, 1 x PCIe x1
Storage I/O
x UltraDMA133
2 x 10/100/1000
Multi I/O
1 x PS2 Keyboard
FireWire
Form Factor
ATX Form Factor
Une carte ATX sli et tri certifié avec le nf200 certainement très bonne également en oc, toujours la petite lumière au centre ( kikoo powered ) bundle un peu de malade toujours avec l'ECP.
Actuellement référencée à 299.99 dollars sur le site EVGA
La P55 Classified 200
http://img97.imageshack.us/img97/7492/160lfe659krlg1.jpghttp://img97.imageshack.us/img97/74/160lfe659krlg8.jpg
Performance
Memory
Dual Channel DDR3
Expansion Slot
5 x PCIe x16/x8, 1 x PCIe x4, 1 x PCIe x1
0 x 32-bit PCI, support for PCI 2.1
Storage I/O
x UltraDMA133
2 x 10/100/1000
Multi I/O
1 x PS2 Keyboard
FireWire
Form Factor
EATX Form Factor
Length: ?
Width: ?
Une carte e-ATX sli et tri certifié avec le nf200 à phases numériques forcement d'un très bon niveau en overclocking, toujours la petite lumière au centre ( kikoo powered ) avec la griffe classified, bundle de malade toujours avec l'ECP, même si il est pas présent sur les photos.
Actuellement référencée à 349.99 dollars sur le site EVGA
Toutes les mobales respirent la qualité et le savoir-faire EVGA, très bon produits bien finis et perf. Que ce soit la plus petite carte ou autre elles ont toutes un pcb noir de qualité.
J'attends vos impressions sur ses mobales déchainez-vous ;)
Message édité par TsuM le 23-11-2009 à 10:11:39
Feed-Back   Président du PiseptO (Paidai i7 Owner)
Marsh Posté le 11-08-2009 à 12:59:52
Evbot pour EVGA P55 FTW 200 & Classified 200
http://images.hardwarecanucks.com/image//skymtl/MOBO/P55-FTW/P55-FTW-1.jpg
http://images.hardwarecanucks.com/image//skymtl/MOBO/P55-FTW/P55-FTW-2.jpg
http://images.hardwarecanucks.com/image//skymtl/MOBO/P55-FTW/P55-FTW-24.jpg
ECP Version 2 pour EVGA P55 FTW / FTW 200
http://images.hardwarecanucks.com/image//skymtl/MOBO/P55-FTW/P55-FTW-23.jpg
Détails divers sur le P55 eVGA :
http://images.hardwarecanucks.com/image//skymtl/MOBO/P55-FTW/P55-FTW-18.jpg
http://images.hardwarecanucks.com/image//skymtl/MOBO/P55-FTW/P55-FTW-19.jpg
http://images.hardwarecanucks.com/image//skymtl/MOBO/P55-FTW/P55-FTW-20.jpg
http://images.hardwarecanucks.com/image//skymtl/MOBO/P55-FTW/P55-FTW-21.jpg
http://images.hardwarecanucks.com/image//skymtl/MOBO/P55-FTW/P55-FTW-22.jpg
http://www.hardwarecanucks.com/imagehosting/2404a8c9b0f39e2a.jpg
http://i31.tinypic.com/1f8vnl.jpg
Message édité par TsuM le 11-09-2009 à 15:26:47
Marsh Posté le 11-08-2009 à 13:00:02
Référencement & disponibilitée des eVGA P55:
-http://www.materiel.net/search.htm [...] t=&x=0&y=0
-http://shop.ebay.fr/?_from=R40&_tr [...] w=EVGA+P55
Message édité par TsuM le 11-09-2009 à 16:28:37
Marsh Posté le 11-08-2009 à 13:12:48
Articles / Comparatif :
P55 SLI :
http://www.nokytech.net/evga_p55_s [...] 8-d-p.html
P55 FTW :
- http://www.59hardware.net/dossier/ [...] 819/0.html
- http://gilgameshreviews.com/index. [...] &Itemid=61
P55 Classified 200 :
http://www.guru3d.com/article/evga [...] iew-test/1
Message édité par TsuM le 19-11-2009 à 08:41:10
Marsh Posté le 11-08-2009 à 13:28:26
Drapal.  [:cerveau drapal]
¤ Paix et félicité ¤
Marsh Posté le 11-08-2009 à 13:29:02
que veut tu dire par NDA
il y a combien de carte dans la gamme,c'est le modéle haut de gamme celle la
Marsh Posté le 11-08-2009 à 13:31:06
Non-Disclosure Agreement. :jap:
Marsh Posté le 11-08-2009 à 13:43:06
Drap :)
Marsh Posté le 11-08-2009 à 13:43:50
on voit encore l'emplacement du braidwood qui a été annulé  :sarcastic: , ça le fait pas trop
Message édité par couilleshot le 11-08-2009 à 13:44:05
:o :o :o
Marsh Posté le 11-08-2009 à 13:46:12
C'est quoi ce braidwood d'ailleurs?
Marsh Posté le 11-08-2009 à 13:49:46
pas de photo de la boite et de ses accessoires  :D
Marsh Posté le 11-08-2009 à 13:51:57
très belle bête !
Marsh Posté le 11-08-2009 à 13:53:01
Braidwood est le successeur du Turbo Memory, qui permet soit par l'ajout d'un module de mémoire NVram externe, soit avec des puces mémoire directement implantées au PCB de la carte mère, de proposer une petite quantité d'espace de stockage permettant diverses utilisations, comme un boot plus rapide un peu à la manière de ce que l'on peut obtenir avec un SSD par exemple. Une fonctionnalité très attendue par les utilisateurs mais... qu'Intel a depuis le début décidé de réserver aux cartes mères P57, celles équipées du P55 devant en être dépourvues. On imagine donc le bras de fer qui a dû être engagé entre Intel et Gigabyte suite à la présentation de la gamme EP55 lors du Computex. Sans surprise, Intel semble avoir eu le dernier mot, et aucune carte de la gamme finale P55 ne possèdera le braidwood, comme en témoigne le cliché ci-dessus.
http://www.puissance-pc.net/les-do [...] ?Itemid=57
:o :o :o
Marsh Posté le 11-08-2009 à 14:05:11
Merci :jap:
Marsh Posté le 11-08-2009 à 14:09:20
y'a du Power Over eSATA?
Marsh Posté le 11-08-2009 à 14:15:52
Beaucoup de modèles vous verrez et de tres prometteur  :jap:
C'était prévu qu'il ne sorte pas sur P55 mais que sur P57 mais la encore .... :whistle:  :whistle:  vous verrez d'ici peu ...
Bonne question , je pense que oui au vu des photos que j'ai faites mais je demanderai confirmation :jap:
Message édité par boblemagnifique le 11-08-2009 à 14:16:09
Marsh Posté le 11-08-2009 à 14:18:58
Chez moi le power over esata c'est un autre port en dessous du esata:
http://img220.imageshack.us/img220/9341/94505731.png
d'ailleur on devrait virer ceux qui ont pas pensé a mettre l'alim dans le esata...
edit: en regardant bien les photos j'ai l'impression que en rouge sous le firewire c'est esata et en noir a sa gauche le power.
Message édité par sixpack le 11-08-2009 à 14:20:53
Marsh Posté le 11-08-2009 à 14:23:12
le port power over sata est compatible avec des périphériques esata standard?
Message édité par couilleshot le 11-08-2009 à 14:23:29
:o :o :o
Marsh Posté le 11-08-2009 à 14:24:50
le moéle P57 va sortir aussi en septembre ?
Marsh Posté le 11-08-2009 à 14:37:29
j'avais vu ca perso :
http://www.fudzilla.com/images/stories/2009/May/General%20News/msi_power_over_esata1.jpg
Et il y a bien 2 ports eSATA sur la eVGA et bien different (comme sur les photos) , donc je pense qu'il y a un eSATA simple et un Power Over eSATA :jap: a confirmer néanmoins ;)
non pas en septembre , vous verrez bien d'ici la sortie du P55 et ce que dira intel  :lol:
Marsh Posté le 11-08-2009 à 14:41:34
et pour les photos de la boite et de ses accessoires ,possible ?
Marsh Posté le 11-08-2009 à 14:43:37
Le bouton rouge à l'arrière c'est un cmos?
Je trouve quand même le tarif pas vraiment justifié comparé au HDG Asus ou Gigabyte, à ce tarif autant prendre du X58.
Le bundle a intérêt à être michto  :o
Peut être qu'on nous livre le braidwood dans le bundle en kit à monter soi même  :D
Message édité par couilleshot le 11-08-2009 à 14:50:47
:o :o :o
Marsh Posté le 11-08-2009 à 14:59:17
J'ai pas , c'est deja bien que j'ai pas un sample rev 1 comme sur la BlackOps X48 ou il fallait finir de souder :D
Oui c'est un Cmos :jap:
On véra les vrais tarifs je les connais pas encore (pas demandé surtout) :jap:
Marsh Posté le 11-08-2009 à 15:03:59
J'ai vu 250$ un peu partout
:o :o :o
Marsh Posté le 11-08-2009 à 15:09:35
C'est du niveau de l'ASUS P55 RoG. On ne verra pas beaucoup plus cher en P55. C'est grosso-modo le prix d'une P6T aux US.
En tout cas elle serait sublime derrière une vitre.  :love:
Message édité par mikestewart le 11-08-2009 à 15:15:25
Marsh Posté le 11-08-2009 à 17:49:42
la Maximousse 3 , t'inquiete il y aura plus cher :D (mais pas bcp mieux pour autant)
Ca devrait aller jusqu'a 300$ max pour les versions Geekettes (asus , evga , msi & co) [:markdavis]
Message édité par boblemagnifique le 11-08-2009 à 17:50:15
Marsh Posté le 11-08-2009 à 19:12:49
Pourquoi il y a des trous pour un ventirad LGA775 et des trous pour un LGA1156 ??
Marsh Posté le 11-08-2009 à 19:16:00
Bah parce que c'est pas les mêmes fixes et que ça permet aux gens de remettre leur rad 775, sympa de la part d'EVGA.
Marsh Posté le 11-08-2009 à 19:17:32
par contre en regardant les photos c'est pas rassurant quant à la solidité de la fixation  :heink:
Aussi je vois que ça se bouscule pas niveau rad compatibles 1156, faudrait qu'ils se remuent les metallo
Message édité par couilleshot le 11-08-2009 à 19:19:05
:o :o :o
Marsh Posté le 11-08-2009 à 19:20:54
Tu veux exercer combien de tonnes de pression sur ton cpu? Ya aucun risque. Par contre pour une "FTW" les rads font super cheap j'espère qu'il y aura encore mieux dans la gamme!
Marsh Posté le 11-08-2009 à 19:26:10
en effet , le pcb est résistant :jap: il tiendra surement le poids des rads et bon de tte facon c'est la plaque arriere qui supportera le poids des cooling les plus lourd ^^
A part le rad box & qqs autres ptits rads avec leur fixe en plastoque , il y a plus des masses et c'est pas un mal :jap:
Yep ca viendra par la suite , patience :jap:
Marsh Posté le 11-08-2009 à 19:26:28
Pourquoi c'est marqué "Foxconn" sur le cache socket?
Ya eu un rachat ?
Marsh Posté le 11-08-2009 à 19:35:45
Foxconn fait tous les socket intel depuis longtemps.
Marsh Posté le 11-08-2009 à 19:40:27
Ah ouai en effet je viens de regarder sur celui de ma asus, je n'avais pas vu que foxconn était inscrit dessus  :D
Marsh Posté le 11-08-2009 à 19:46:30
Moi j'au une question con .
Je vois de plus en plus la marque EVGA .
Mais au final ca donne quoi ? c'est une bonne marque ?
Merci .
Le tennis et le ping-pong, c'est pareil. Sauf qu'au tennis, les joueurs sont debout sur la table.
Marsh Posté le 11-08-2009 à 19:48:55
La top mobo X58 à l'heure actuelle est une EVGA pour info Turrican.
Marsh Posté le 11-08-2009 à 19:50:22
 Merci , donc je suppose qu'il en va de même pour les cartes graphiques ?
Marsh Posté le 11-08-2009 à 20:04:28
Pour faire des cartes overclocker et les garantir 10 ans, je pense qu'ils doivent avoir confiance en ce qu'il fabrique.
http://www.hardware-pc.fr/index.ph [...] mitstart=7
Marsh Posté le 11-08-2009 à 21:15:28
Merci pour l'info , je crois que je viens de trouver la futur marque de mes cartes graphiques .
Marsh Posté le 12-08-2009 à 14:55:56
C'est bizarre les conecteur fan en noir, difficiile a reperer :lol:
Encore du tres bon topic pour une mobo qui n'est pas encore sorti !!
Le mode sans echec de windows, prouve bien que le mode normal est un echec .
