Name AMD Athlon XP Code Name Thoroughbred Specification AMD Athlon(TM) XP 2400+ Family / Model / Stepping 6 8 1 Extended Family / Model 7 8 Package Socket A Core Stepping B0 Technology 0.13 µ Supported Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE CPU Clock Speed 2000.0 MHz Clock multiplier x 15.0 Front Side Bus Frequency 133.3 MHz Bus Speed 266.7 MHz L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size L2 Cache 256 KBytes, 16-way set associative, 64 Bytes line size L2 Speed 2000.0 MHz (Full) L2 Location On Chip L2 Data Prefetch Logic yes L2 Bus Width 64 bits
Mainboard and chipset Motherboard manufacturer ASUSTeK Computer INC. Motherboard model A7V8X, REV 1.xx BIOS vendor Award Software, Inc. BIOS revision ASUS A7V8X ACPI BIOS Revision 1006 BIOS release date 09/13/2002 Chipset VIA KT400 (VT8377) rev. 00 Southbridge VIA VT8235 rev. 00
Graphic Interface AGP AGP Status enabled, rev. 2.0 AGP Data Transfer Rate 4x AGP Max Rate 4x AGP Side Band Addressing supported, enabled AGP Aperture Size 64 MBytes
Memory DRAM Type DDR-SDRAM DRAM Size 1024 MBytes DRAM Frequency 166.7 MHz FSB:DRAM FSB + 33 MHz DRAM Interleave 4-way CAS# Latency 2.5 clocks RAS# to CAS# 3 clocks RAS# Precharge 3 clocks Cycle Time (TRAS) 7 clocks # of memory modules 2 Module 0 DDR-SDRAM PC2700 - 512 MBytes Module 1 DDR-SDRAM PC2700 - 512 MBytes
Marsh Posté le 18-01-2006 à 23:25:42
Bonsoir à tous,
que pensez vous des reglages de mon pc et que faudrait il faire pour ameliorer les perf ????
Merci d avance
ST
CPU-Z Report
CPU-Z version 1.31.
CPU(s)
Number of CPUs 1
Name AMD Athlon XP
Package Socket A
Core Stepping B0
Technology 0.13 µ
Bus Speed 266.7 MHz
L2 Location On Chip
AGP Max Rate 4x
Memory
DRAM Type DDR-SDRAM
