je vends un celeron 900 non overclocke . avec radiateur d'origine + ventilo de taisol cgk760 .
+ carte mere gigabyte :
GA-6OXC (je suis pas sur de la fin, sur c'est que cun i815ep pro, y a aps de son, mais udma 100 et support p3 et c2) Intel 815(E/P/EP) chipset
Processor Socket 370 for Intel® FC-PGA Pentium® III or other compatible processors Supports Auto/66/100/133 MHz FSB (Front Side Bus)
Chipset Intel® 815P AGPset
Intel® FW82801AA (ICH) iTE IT8712F Super I/O & health chip
Memory Supports up to 512 MB SDRAM memory 3 DIMMs 168-pin sockets Supports 32/64/128/256/512 MB SDRAM modules
Expansion Slots 1 x AGP slot supports 2X/4X mode & AGP 2.0 compliant 6 x PCI slots support 33MHz & PCI 2.2 compliant 1 x AMR slot (reversed)
I/O 2 x UDMA ATA 66/33 IDE ports on board 1 x FDD, 2 x COM, 1 x LPT, PS/2 Keyboard, PS/2 Mouse on board 2 x USB ports on board 1 x SCR (Smart Card Reader) connector IrDA TX / RX header
Power ATX power connector Power-on by LAN, RTC, Modem & Switch Power-off by Windows® 95/98/Me/2000/NT shut down & Switch Form Factor ATX form factor , 4 layer PCB (30.5*21.5 cm)
H/W Monitoring Auto speed down and alarm when CPU overheat or fan failure (OS independent & driverless) 3 fan power & speed detection connectors System health status detect & report by BIOS H/W detect & report power-in voltage, CPU voltage and CMOS battery status
BIOS 2M bit flash ROM BIOS, enhanced ACPI feature for PC98/Win98/Win2000/ WinME compliance, Green, PnP, DMI, INT13 (>8.4GB) & Anti-Virus functions
IDE#1~#4, SCSI, LS120, ZIP & CD-ROM bootable Auto-detect & report system health status Supports @BIOS? Live Update
je pensais 115euros fdp in en r3 c correct ou peu ?
Marsh Posté le 17-03-2003 à 16:58:29
combien je peux vendre ça ?
Processor
Chipset
Intel® 815P AGPset
Memory
Expansion Slots
I/O
IrDA TX / RX header
Power
ATX power connector
Form Factor
H/W Monitoring
BIOS
