Dual channel et Athlon 64 !!! - Carte mère - Hardware
Marsh Posté le 22-04-2005 à 23:21:40
Ben voilà c'est ça que je cherchais à poster pour un gars qui voulait passer en dual channel, je n'arrivais plus à remettre la main dessus ![]()
Marsh Posté le 22-04-2005 à 23:22:32
1°/ Scoop
2°/ Manque la moitié de l'article, là ![]()
Marsh Posté le 22-04-2005 à 23:22:35
Oupps j'ai oublié le lien : http://www.tcmagazine.info/article [...] rticle=128
Marsh Posté le 22-04-2005 à 23:20:12
Batterie de test effectué avec et sans dual channel ====> resultat : le dual channel n'apporte pas grand chose !!!!!!!!
One of the major updates in the most recent Athlon 64 line, previously reserved to the FX models only, was the inclusion of an on-board 128bit dual channel memory controller, which finally brought the Athlon family of processors on a memory speed par with their Intel siblings, and in some cases allowed the to perform better than those smug Pentium chips.
Due to one of those engineering accidents that will be funny once we get past the humiliation, we have recently been able to run a full battery of tests on a single channel Athlon 64 4000+. Since a lot of factory-made PCs these days are shipping with single 256 or 512 MB modules, we thought wed take the opportunity to compare single-channel RAM performance with its double-channel counterpart, to finally answer the age-old question: is the second stick worth it? Lets have a look.
La suite du test : http://www.tcmagazine.info/article [...] rticle=128
Message édité par Druss2 le 22-04-2005 à 23:25:58
