Que pensez-vous de la Crosshair?(Asus Motherboard)
Que pensez-vous de la Crosshair?(Asus Motherboard) - Carte mère - Hardware
Marsh Posté le 28-08-2006 à 15:28:53
Que pensez-vous de cette carte mère de Asus? Je viens de tomber la dessus sur le site de Asus, et je n'ai trouvé aucun topic sur cette carte sur le forum
http://usa.asus.com/products4.aspx [...] odelmenu=1
Specifications (from Asus.com)
CPU:Support AMD® Socket AM2 Athlon 64 X2 / Athlon 64 FX / Athlon 64/ Sempron
       AMD Cool 'n' Quiet™ Technology
       AMD64 architecture enables simultaneous 32-bit and 64-bit computing
       AMD Live!™ Ready
Chipset: NVIDIA nForce® 590 SLI™ MCP
            NVIDIA LinkBoost™ Technology
Front Side Bus: 2000 / 1600 MT/s
Memory: Dual channel memory architecture
            4 x DIMM, max. 8GB, DDR2-800/667/533, ECC and non-ECC, un-buffered memory
Expansion Slots: 2 x PCI Express x16 slot with NVIDIA® SLI™ technology support, at full x16, x16 speed
                       1 x PCI Express x4
                       3 x PCI 2.2
SLI: Support two identical NVIDIA SLI-Ready graphics cards (both at x16 mode)
      ASUS two-slot thermal design
      ASUS PEG Link
Storage: NVIDIA nForce® 590 SLI™ MCP supports:
            * 1 x Ultra DMA 133 / 100 / 66 / 33
            * 6 x Serial ATA 3.0Gb/s
            * NVIDIA MediaShield™ RAID supports RAID 0, 1, 0+1, 5 and JBOD span cross Serial ATA drives
            Silicon Image® 3132 SATA controller supports
            * 2 x External Serial ATA 3.0Gb/s port on back I/O (SATA On-the-Go)
            * Support RAID 0, 1, and JBOD
LAN: Dual Gigabit LAN controllers support NVIDIA DualNet® technology
       NVIDIA nForce® 590 SLI™ MCP built-in dual Gigabit MAC with external Marvell PHY
      * Support Teaming and fail-over functions
      * Support TCP/IP Acceleration
Audio: SupremeFX Audio Card
         featuring ADI 1988B 8-channel High Definition Audio CODEC
         Support Jack-Sensing, Enumeration, Multi-streaming and Jack-Retasking
         8 channel audio ports
         Coaxial, Optical S/PDIF out on back I/O port
        * ASUS Array Mic
        * Noise Filter
IEEE: 1394a TI 1394 controller supports 2 x 1394a ports
USB: max. 10 USB2.0/1.1 ports
Overclocking Features:  * ASUS AI NOS™ (Non-delay Overclocking System)
                                 * AI Overclocking (intelligent CPU frequency tuner)
                                 * AI Clock Skew
                                 * ASUS PEG Link - automatically performance tuning for graphics cards
                                 * ASUS O.C. Profile: overclocking configuration-sharing tool
                                 * ASUS C.P.R.(CPU Parameter Recall)
                                 * Extreme Tweaker
                                 ASUS AI Booster Utility
                                 Adjustable FSB/DDR2 ratio. Fixed PCI/PCIe frequencies.
Special Features: LCD Poster
                        EL I/O
                        Onboard LED
                        Onboard switches: Power / Reset / Clr CMOS
                        Q-Connector
                        Q-Fan Plus
                        ASUS CrashFree BIOS3
                        ASUS EZ Flash2
                        ASUS Music Alarm
                        ASUS MyLogo3
Back Panel I/O Ports: 1 x PS/2 Keyboard port
                              1 x PS/2 Mouses
                              1 x Optical + 1 x Coaxial S/PDIF Output
                              2 x External SATA
                              2 x LAN (RJ45) port
                              4 x USB 2.0/1.1 ports
                              1 x IEEE 1394a port
                              1 x onboard LED switch
                              1 x LCD Poster
Internal I/O Connectors: 3 x USB 2.0 connectors supports additional 6 USB 2.0 ports
                                  1 x Floppy disk drive connector
                                  1 x IDE connector for two devices
                                  6 x SATA connectors
                                  1 x CPU / 7 x option Fan
                                  3 x thermal sensor connector
                                  1 x IEEE1394a connector
                                  1 x S/PDIF output connector
                                  Chassis Intrusion connector
                                  Front Panel Audio connector
                                  24-pin ATX Power connector
                                  8-pin ATX 12V Power connector
                                  System panel connector
                                  1 x EL I/O Shield Connector
BIOS: 8Mb AWARD BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3
Manageability:  WOL by PME, WOR by PME, Chasis Intrusion, PXE
Accessories: 1 x SLI bridge
                  1 x ASUS Array Mic
                  1 x ASUS Optional Fan
                  1 x ASUS Q-Connector Kit (system panel; Retail version only)
                  3 x thermal sensor cables
                  1 x UltraDMA 133/100/66 cable
                  1 x Floppy disk drive cable
                  6 x SATA cables
                  7 x Cable Ties
                  3 x SATA power cable for 6 devices
                  1 x 2-port USB2.0 module
                  1 x IEEE1394a module
                  1 x EL I/O Shield
                  InterVideo® Media Launcher (OEM version only)
                  User's manual
Support CD: Drivers
                 ASUS PC Probe II
                 ASUS Update
                 ASUS AI Booster
                 Futuremark ® 3DMark® 06 Advanced Edition
                 Kaspersky®  Anti-Virus
Form: Factor ATX Form Factor, 12"x 9.6" (30.5cm x 24.5cm)
Le prix est un peu élevé mais je crois que ça vaut le coup!Qu'est-ce que vous en pensez?
Message édité par pat la fauche le 28-08-2006 à 19:04:30
Marsh Posté le 28-08-2006 à 19:05:55
http://img.presence-pc.com/news/r/o/rog3_resized.jpg
Dans le noir elle est vraiment belle!
Personne ne l'as tester?
Marsh Posté le 30-10-2006 à 21:42:18
Salut ben je l'ai acheter mais je ne peux encore la tester j'attend la ram et la carte graphique!! je vous dirais!!
Marsh Posté le 31-10-2006 à 08:31:38
si elle clignote les leds ^^ , un air de Awd9-max , elle à l'air sympatoche cette carte mère .
( ps : sympa le pseudo , mais le meilleur c'est joe delgado ^^ Wanted )
Marsh Posté le 15-11-2006 à 10:15:25
Et bien moi je l'ai commandée il y a 1 mois, elle arrive bientôt (config complète) :bounce:  :love:
pourrais t'en dire plus à ce moment là. :sol:
Marsh Posté le 06-12-2006 à 08:16:20
et bien ça y est elle est là et ça rocks
que du bonheur
et cette page ne pourrait elle pas devenir le topic unique de cette mobo ?
Message édité par lauira976 le 06-12-2006 à 08:33:27
Marsh Posté le 11-12-2006 à 03:21:17
je l'aie aussi depuis quelques jours, très satisfaisant pour le mmoment, pas eu le temps de tester beaucoup par contre...
Pas beaucoup d'information dessus ... : /
Monée avec un FX-62, overclock très faible pour le moment, 1.94 Ghz, je vais devoir essayer plus pour voir.
Ceux qui l'ont aussi, amenez vos contributions ^^
Marsh Posté le 11-12-2006 à 03:40:43
Euhhh, il n'y a pas comme un probleme là? [:mlc2]
"La liberté d'expression n'a d'ennemis que ceux qui veulent se réserver le droit de tout faire" - "Seems all have gone insane for gold"
Marsh Posté le 29-12-2006 à 18:59:22
euh presque 2ghz plus c'est tres faible en overclocking !.....wahou ! quesque beaucoup pour toi alors ?
Marsh Posté le 30-12-2006 à 02:40:45
personne ne parle de cette mobo a croire que peut de gens l'ont
Marsh Posté le 30-12-2006 à 02:47:47
core 2 duo mon gars  :whistle:
Qui à internet ici ? Et un boulet, un !!! :D
Marsh Posté le 30-12-2006 à 12:55:06
ouais je pense bien , mais bon j'aurai aimer que se topic devienne le "topik unik de la crosshair " et que tout ceux qui l'ont se manifeste en parlant d'elle car elle n'est pas assez reconnu pour se quel est ! "carte haut de gamme AM2" et tres peu de test sur elle
Marsh Posté le 30-12-2006 à 13:20:08
Moi je me pose la question suivante:
Comment peut-il y avoir des gens assez **** pour acheter cette CM ?!
- Le Nforce 5 est réputé pour être nul en o/c ! (d'ailleurs c'est pour cette raison que la version Intel n'est même jamais sortie)
- A l'heure où les plateformes C2D tiennent la dragée haute en termes de perfs, comment peut-on songer à s'orienter vers un AM2, et surtout avec une CM au rapport perfs / prix aussi naze ?
- Se payer un FX-62 pour le monter sur cette CM ? le comble du gaspillage ! Pour 500€ de moins, on a une plateforme à base de E6600 + P5B Dlx, nettement plus performant
Maitenant si certains sont geeks au point de payer les platerformes marketing par excellence.......c'est leur droit.
Marsh Posté le 30-12-2006 à 14:32:09
salut
jai commande cette carte mere ya 2 semaines et franchement que demander de mieux?? :pt1cable:
rien a dire elle est parfaite
aucun souci montage facile et bundle tres complet
les diodes et l'ecran sont formidable
j'ai o/c mon 3800 + X 2 a 2600mhz sans probleme
un seul petit probleme les pilotes audio pour ma part jai du telecharger les derniers sur le site
Marsh Posté le 30-12-2006 à 15:25:43
Pourquoi Insulter les gens de se payer cette Carte mére !!!  :pfff:
si il ont un preference Amd par rapport a Intel pourquoi les insultés, se sont leur choix ! tt le monde n'est pas Obliger de prendre du Core 2 duo que je sache !
et tu te goure quand tu parle Overcloking par rapport a cette CM , cette mobo est la meilleur en OC sur le socket AM2 tout les test te le dirons !!!!!
Marsh Posté le 30-12-2006 à 15:26:59
spawn59 a écrit :
salut
Merci de te manifester par rapport a cette mobo ;)
Marsh Posté le 01-01-2007 à 21:23:44
pas de probleme c'est un plaisir
Marsh Posté le 05-01-2007 à 06:16:46
salut tout le monde
voili voilou, çà fait deux mois maintenant que j'ai le joujou est j'apprécie.
quelque soit les choix de chacuns, respectons les. :fou:
la carte est super, j'y branche n'importe quoi, c'est reconnu, est cela fonctionne immédiatement suivant les perf constructeur.
pour un petit OC (moins de 25%), trois ou quatre clic en utilisant le log prévu : AI quelque chose est çà roule
pour gros OC il faut oublier le log est aller voir le bios : une merveille...
je m'explique, déjà tout est en français, ce qui peu interresser certain, et surtout
TOUT est paramétrable, la tension à chaque condo, le nord le sud dans un sens, dans l'autre, bref que l'on soit débutant, ou grand maître de l' hyperfréquençage, cette carte n'est que du bonheur
le conseil du jour, n'associer à cette carte que du matos performant (pas de ddr2 5000 par ex) avec la crosshair c'est de la 6400 au moins, pareil pour la ou les CG pas de 9200 faut tout de suit aller jouer chez 19XX ou 79XX, parce que bcp moins d'intérret sinon.
pour ma part les benchs me servent aux tests de stabilités, de toute manière je suis limité par mon écran 1440*900 : 6100 pts 3dmark06 au premier bout aprés quelques temps 7400 grace au log d'OC et riva, maintenant je vise les 8000, et tout ca avec le ventirad d'origine, et deux 7900gs en passif yhaa :bounce: et surtout farcry hyper fluide avec tout le détails aux max
et pour les nerveux il reste la boxe, le motocross et le paintball, moi ça me detend  :na:
à plus pour les questions
Marsh Posté le 05-01-2007 à 18:06:47
achetée aujourd'hui, elle est en cours de montage dans un antec p180;
Et là je suis face à petit soucis: dans le manuel utilisateur ASUS à oublié de documenter les broches des connecteurs ADFP1.
je suppose que c'est l'audio front panel.
sur la cm il y a le connecteur ADFP1 de 15 broches qui sont disposée comme ça (le x indique l'emplacement du détrompeur.):
oooooxoo
oooooooo
du boitier (p180) j'ai un connecteur marqué audio de 9 broches disposées de la sorte:
oooxo
ooooo
avec 7 fils doublé du connecteur 9 broches, ils sont marqués comme suit:
noir      => AUD GND
jaune   => FPOUT-R
blanc    => FPOUT-L
bleu     => RET-R
vert     => RET-L
rouge   => MIC
orange => MIC-BIAS
j'ai trouvé ça sur le sujet:
http://vip.asus.com/forum/view.asp [...] uage=en-us
http://support.intel.com/support/m [...] 015851.htm
d'après ce qui s'est dit sur le forum d'asus, il vaut mieux éviter de connecter quoique ce soit dessus pour le moment. bien que le possesseur d'un boitier antec sonata II ait réussi à connecter le sien.
si quelqu'un en sait plus...
Marsh Posté le 05-01-2007 à 19:03:41
le connecteur en question:
http://img406.imageshack.us/img406/8923/adfp1cg1.jpg
il est situé en bas à droite sur la cm
Marsh Posté le 06-01-2007 à 01:45:12
pour ceux qui souhaitent connecter leur prises audio de façade et qui seraient confrontés au même pb, la solution c'est le connecteur AAFP1 qui est situé sur la carte d'extension supreme FX fournie.
vue de dessus
http://img413.imageshack.us/img413/7356/aafp1kp6.jpg
vue de coté
http://img413.imageshack.us/img413/880/aafp12yp6.jpg
A priori le 'A' dans 'AAFP1' ça pourrait être pour analog et le 'D' dans 'ADFP1' ça serait pour digital. dans le BIOS de la carte mère, pour le son il y a un mode HD et un mode standard.
j'ai désactivé le mode HD et j'ai connecté les broches de l'audio de façade de mon P180 sur l'AAFP1 et ça marche.
Marsh Posté le 07-01-2007 à 18:39:54
merci a tous de parler enfin de cette mobo ;)
Marsh Posté le 12-01-2007 à 09:40:47
vue de dessus
vue de coté
merci pour cette explication qui m aide beaucoup
pourrais tu m indiquer le branchement des fils sur les pins de de la carte ou si tu avait une photo merci d avance
Marsh Posté le 16-01-2007 à 10:32:39
dommage que ya pas plus de monde qui la possede je suis sur que lon pourrait decouvrir pas mal de choses
Marsh Posté le 23-01-2007 à 10:16:47
et le topic [unique] de cette carte ou en est ce ??
Marsh Posté le 24-01-2007 à 20:10:32
je vais bientot balancé les photos de ma carte Mum histoire d'avoir plus d'image
Marsh Posté le 29-01-2007 à 17:13:08
+100000
Marsh Posté le 01-02-2007 à 15:45:37
http://pix.nofrag.com/b9/c9/49d54a95f338a172925ab5d8c4c0t2.jpg
http://pix.nofrag.com/ae/81/b3bc349dfb6982c845f8e050e25bt2.jpg
http://pix.nofrag.com/c7/e9/8826093c08ede779683af3374e25t2.jpg
http://pix.nofrag.com/2b/45/80cb9631024734e699a437a79375t2.jpg
Message édité par sir_jordan23 le 01-02-2007 à 15:48:06
Marsh Posté le 07-02-2007 à 12:44:38
vraiment de la balle je vais mettre des photos de la mienne aussi
6700XT  / Intel Core i5-13400F / Asus Strix Z790 A-WIFI  /Seagate FireCuda 530, 1 TB /Kingston Fury Beast DDR5 RGB 32GB /Sandisk 2 To SSD / Boitier Corsair 570X
Marsh Posté le 09-02-2007 à 08:25:55
bonjour a tous je viens de recevoir cette carte mére elle est vraiment superbe par contre j'ai juste un soucis je n'arrive pas a activer le sli sur cette carte mére pourtant windows m'as bien installer les deux carte video geforce 7800 gtx de méme marque , j'ai installer le connecteur entre les deux cartes mais je ne trouve pas dans le bios l'option pour activer le sli si quelq'un peu m'aidez merçi d'avance
Marsh Posté le 28-02-2007 à 10:03:31
tu la aussi dans les parametre de nvidia je crois
Marsh Posté le 28-02-2007 à 10:04:02
je cherche de l'aide pour le parametrage de la carte son .....quelqu'un peut il m'aide?
Marsh Posté le 14-03-2007 à 11:30:39
je cherche de l'aide pour brancher mon casque sur la carte son ou la prise de la carte mere quelqu'un pourrait m'aider svp :cry:  :cry:
Marsh Posté le 14-03-2007 à 15:58:18
pour ton casque par rapport a tes enceinte tu ne peux pas ?
Marsh Posté le 14-03-2007 à 16:12:36
nan cest un kit 5.1 sans prise casque
Marsh Posté le 15-03-2007 à 00:34:44
aie ben la j'en ai aucune idée vue ke moi le casque je le branche direct sur le kit d'enceinte essaie de voir sur le site asus ou en recherchant bien sur le net avec le type de cart fx qu'on utilise pour cette mobo
Marsh Posté le 17-05-2007 à 11:21:02
salut a tous je cherche si quelqu'un a trouver les pilotes vista pour le chipset de cette carte mere??
Marsh Posté le 28-05-2007 à 15:52:40
normalement sur le site asus
Marsh Posté le 28-05-2007 à 16:56:55
non helas ya que les BETA et ils osnt pas compatibles avec le vista .....
Marsh Posté le 30-05-2007 à 22:24:23
Dommage car je compté installé Vista sur mon PC je vais plus aprofondir les recherche et je te tien au courant ;)
ps: vue que la M2N32-SLI Premium VISTA Edition a le méme chipset que nous je pense que sa pourrai marcher si l'on telecharge les pilote enfin on verra bien on se tien au courant
Message édité par sir_jordan23 le 30-05-2007 à 22:31:29
