Verifying DMI Pool Data - Matériels & problèmes divers - Hardware
Marsh Posté le 25-01-2009 à 15:44:28
salut
après avoir parcouru ce forum et le net, je n'ai trouvé aucune réponse claire à ce sujet.
j'aimerais aussi savoir ce qu'est ce DMI pool data
en quoi ça consiste?
si qqn sait ça, ça serait cool de répondre
Marsh Posté le 25-01-2009 à 20:07:35
http://en.wikipedia.org/wiki/Deskt [...] _Interface
DMI or DesktopManagement Interface is a layer of abstraction between system components and the software that manages them.
The System Management BIOS (SMBIOS) is an extension of the Basic Input Output System (BIOS) that formulates and delivers this information to the operating system. The pool data is the information.
In short, when the BIOS is "Verifying DMI pool data" it is verifying the table of data it sends to the operating system (Windows, etc.).
Usually this is being caused after a hardware change has been made,
did you changed any hardware lately? If so take a look at the steps below:
1. If you changed the hardware just before this problem occurred (e.g., installed a new hard disk drive), unchange it.
2. If you installed a new hard disk drive, set the motherboard CMOS Setup to Auto for the drive type. You may have to disconnect the drive first.
3. Enable "Reset Configuration Data" (may be "Force Update ESCD" in some CMOS Setups) in the motherboard CMOS Setup PNP/PCI configuration. (Rebooting will automatically disabled it after it has done its thing.)
4. The CMOS may be corrupted. Clear it.
5. Disconnect all drives not required to boot the computer. If this fixes it, reconnect one at time.
6. The floppy drive may be bad or not connected properly.
7. Reseat all expansion boards.
8. Pull all boards not required to boot the computer.
Marsh Posté le 31-01-2009 à 13:01:44
urgant en rallumant mon pc
il y a un page noir et écrie en au a gauche VERIFYING DMI POOL DATA
j ai rallumer mon pc après avoir desinstaller avast en anti virus pour réinstaller une version plu récente d avast et la je redémarré le pc et il y a un mon problème de veriftying dmi pool data
pour finir je ne comprend rien au langage informatique
Marsh Posté le 21-10-2008 à 18:11:15
j'ai un petit problème car lorsque je boot j'ai le message suivant : Verifying DMI Pool Data et ça bloque dessus pendant 2 mn avant que le boot ce poursuive.
Ensuite le système démarre normalement.
je désirerais savoir ce qu'est le Verifying DMI Pool Data ce qu'il fait et pourquoi il est devenu si long après une réinstalle compléte de XP .
Ma config
CM asus a7n8x deluxe
Proc barthon 2800+ a 2087 mhz
CG fx 5200
HDD 2 IDE et 2 SATA
merci d'avance pour vos conseils
